Essentially cheatable.numa_ninja wrote:
My edit:
Gold! =]
submit?
y/n
O__OBionicCryonic wrote:This just in, I've registered a channel on IRC for The Melting Pot. It's #meltingpot for anyone who's interested.
You see those boxes with the ext in them? That's N level data. What goes on in this topic is someone posts a basic map, then someone else calls 'dibs' and edits that map, and then edits his post with the data. This goes on until a good map has been made, and will usually have more then 5 authors. If you would like to participate, copy the data, put it in N, and edit it. If it's hard, don't dampen t to much, becasue some of us are really good at N, and have beaten all 100 episodes, so the difficulty is right for some. Afterwards, press the edit button that's found on your post, use map tags and then paste the level data in the map tags and press submit.raptor331 wrote:are we sending in a whole bunch of levels? mind explaining to a noob anyone?
Oh, that. Of course. How could I forget. *cough. Heh.heatwave wrote:Also, is map 5 on NUMA? I can't find it.
