Google SketchUp Help (Advice needed urgently!)
I would like to get advice as soon as possible. Thank you for your help.
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
My writing forum
- Mr. Glass
The axes should always be visible, maybe if you go to "View" and then check "Axes"?
Yes, I've tried that, and all it does is go to the top view (or whichever one I chose), but it's still zoomed out way too far.Donfuy wrote:Have you tried going to "Camera" and then "Standard views" and then choose one? (not sure if it zooms to a default too)
I've tried checking and unchecking the axes button several times, but it hasn't changed a thing.Donfuy wrote:The axes should always be visible, maybe if you go to "View" and then check "Axes"?
@Tunco: thanks for the link, but it doesn't have a solution the problem that I'm dealing with.
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
My writing forum
1) you didn't accidentally just delete all your stuff?
2) that you actually aren't zoomed in way too far?
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
My writing forum
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
My writing forum
Tell them about your problem.
Umm, I just did what presumably you did, that was zooming out waaay too far (the axes disappear, yes)
I've done many things, like the stuff you did, but zoom extents fixed me. Zoom extents puts your model like... maximized at full, so it fits your window. It worked quite well with me. The only thing that went wrong at first was that I firstly, in my attempts of correcting your problem, clicked the "Top" view. As the model I have has no depth at all, all I saw was a black line xD.
Meh, hope it helps, because if it doesn't, your file must have an error.
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
My writing forum
Yeah.Donfuy wrote:...does that mean that what I said didn't work?
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
My writing forum
Hehheh. :DWhy Me wrote:Actually Donfuy, I didn't see your last post, because it must've been posted as I was replying to tunco's post. And the guy who helped me told me to do the same thing that you did Donfuy, I just didn't see it. And, luckily enough, it worked. I just wish that I saw your post Donfuy before I replied.
Though, thanks Donfuy.
- Sonnet
L
