O_oTheRealOne wrote:166905 highscore
I missed one jump, and a hold at the end, but I still think it is pretty good. I am glad I finally got sub-100.
Dayum.
I am now 1st 12 frames behind you. ;_;
O_o x 2Izzy wrote:O_oTheRealOne wrote:166905 highscore
Dayum.
Taken by 9.5 seconds.Unreality wrote:168311
well kinda for the sake of appreciating the 3 x tile drones here
have you logged in the game while you are making that run? if you haven't logged in when making that run, the demo data won't be registered to NReality server (security issue)MyCheezKilledYours wrote:Just got my first speedrun score on 92-0! 290 frames!
I clicked "Submit" but it isn't showing me there. Help me please?
yes, remember login and turn practise mode offMyCheezKilledYours wrote:I'll try it when I get home. Currently at my Nana's house.
It will still submit if you are clicking the "Play Level #" button, right?
Ha ha. I knocked you off top20 before you even got there!!!MyCheezKilledYours wrote:Just got my first speedrun score on 92-0! 290 frames!
Alright then.999_Springs wrote:Ha ha. I knocked you off top20 before you even got there!!!MyCheezKilledYours wrote:Just got my first speedrun score on 92-0! 290 frames!
[Edit: Checking "score times", it seems that ToeFaceKiller AND Izzy AND vankusss did all of the preliminary work but I delivered the final blow...]
I really can't figure out what level your referring to as there doesn't seem to be anything special in any of kryX's episode 150 runs. Also, next time please edit your post instead of double posting.MyCheezKilledYours wrote:I believe kryX's run on 150-0(?) contains the most f-ed up walljump I've ever seen.
It's kryx's highscore 160-0 on non-legitdarkshadow wrote:Was it highscore or speedrun? I wouldn't have a problem with that if it was a bump for a useful post but when your just posting to say check out __'s run theres no reason to bump the thread it makes more sense to do it like this:
Edit: especially if you aren't giving enough information for anyone to actually look at it.
Real Edit: also it's generally unnecessary to post just to bump the post a run thread because the thread itself doesn't need bumping (unless you have something you really want to be seen immediately like, "I just took 0th on __-_" or "xaelar submit your damn 25-3 run already", not really true of the second one although it needs to be said).
Might be even faster than that if you do one of those hieghtless cjs kryX does.darkshadow wrote:My route on 16-3 can be maxed to around 180.750, beating kryX.
You can't without missing a gold. (It works for kryX because his route allows him to pick up the missed gold later)TheRealOne wrote:Might be even faster than that if you do one of those hieghtless cjs kryX does.darkshadow wrote:My route on 16-3 can be maxed to around 180.750, beating kryX.
Nice run though!
2 frames behind you! Oh, can't beat kryX, btw.cheesemonger wrote:168648
Speedrun and Highscore.
