How do you write replies?
NUMA Profile: http://nmaps.net/user/turtles
Postby Turtle » 2008.10.15 (06:05)
I usually put letters into the box, and when I feel there is no need for more, I click the submit button. Not much to it.
Postby Pixon » 2008.10.16 (20:41)
Like this.
Postby Zora_S_Kenneth » 2008.10.17 (00:19)
You don't think when you type? You may or may not be when you type!
Postby otters » 2008.10.17 (02:24)
I don't make that many misitehsiakes, so I just psot before editheign it and resubmeisittting ishte.
Postby NicNac14 » 2008.10.17 (18:32)
jean-luc wrote:I almost always type out my response, post it, then read it. I think hit Edit and correct any mistakes. I often actually edit the post and add a paragraph with additional thoughts shortly after posting it for the first time, if no ones made a new post yet.
I agree with jean-luc i do the same
Postby fingersonthefrets » 2008.10.21 (10:22)
gloomp wrote:In ecvrer rew3orite, ui juyst knoew it's per fecct the firtst time, I FAont evemn klokm at the scareebn,
i can't believe i understood that. anyway
i type as i would talk using commas and full stops not always where they should be, but moved to other places where there would be one if i was talking
oh and i seem to finish it all often with a 'yeah' or 'mm' or something
heh.
Postby kai » 2008.10.27 (07:18)
im used to FPS chatting (stopping in a first person shooter to talk, knowing full well that if you take too long your life is forfeit) so i dont stop to check for errors, except when im posting about something in serious discussion. it really doesn't matter too much whether im grammatically correct or not, as long as im clear enough so that u understand what im saying.
i do, however, tend to check for things that would get me warned or rub someone the wrong way. i say what i think, and i dont suger coat things. i love making awkward situations (as long as im not involved) and im against political correctness.
ps. god i love firefox spell check XD
NUMA Profile: http://nmaps.net/user/lookatthisisgoodatn
Postby lookatthisisgoodatn » 2008.11.11 (17:22)
I type like I write: Proper English, make loads of mistakes but quickly correct them and I do it all as fast as a hot snot.
Postby jean-luc » 2008.11.13 (02:42)
I've recently discovered that I write my replies at about 130wpm. I think I should get some kind of trophy for this.
I'm noticing now how frequently I go back and edit posts to add additional thoughts that I think of after I submit.
Postby PsychoSnail » 2008.11.13 (07:14)
I edit my replies as I write them, usually going back to read what I've written after each phrase. If it's a long post, I read over what I've written after I've submitted it (usually, I just glance at it to make sure it actually appeared).
Users browsing this forum: Google [Bot] and 43 guests
