:: BLUR: SEASON TWO :: ROUND FIVE HAS BEGUN : 169080
Postby Unreality » 2009.05.01 (12:59)
I have an idea for next round, which is called early bird submission bonus
say, if the contest length is 10 days
Then if your final score submitted is the demo that you submitted at 1st day, your score +5
If you final score submitted is the demo that you submitted at 2nd day, your score + 4.5... and so on
In this case holding your best run and not to submit until the final moment...will not gain that much advantage.
*edited: wait, this idea sucks, it discourage ppl to improve their runs later on
NUMA Profile: http://nmaps.net/user/maximumride
Postby Max_Ride » 2009.05.02 (16:16)
Let me be a reserve, haha. Good luck to all, I wish I could have seen this sooner.
I make music. I like girls. I play sports.I'm Eric.
Postby darkshadow » 2009.05.02 (18:59)
I'm not part of this because I don't have time but I'll still occasionally post something. In this case I just want to say that sub-1050 frame AGD is possible.
Unreality's awesome mod
Postby ska » 2009.05.03 (01:29)
hy was I not told about this? :P
Postby remm » 2009.05.03 (02:16)
darkshadow wrote:I'm not part of this because I don't have time but I'll still occasionally post something. In this case I just want to say that sub-1050 frame AGD is possible.
sub 1050? thats crazy! I assume youre speaking of this weeks map, because I wouldn't think that sub 1100 would be possible. Im getting close, but an extra 50 frames past that seems rather difficult
peking^
MBTI Type: ESTP
Postby kkstrong » 2009.05.03 (02:47)
ska you weren't on IRC ever :(
max_ride, if someone drops, you may take their place, so long as you assume all the points that person has, regardless of if they are in first or last.
Postby darkshadow » 2009.05.03 (02:51)
I'll post the route after the round is over.
Postby ska » 2009.05.03 (07:12)
kkstrong wrote:ska you weren't on IRC ever :(
really? I thought I went on pretty often lately; at least once every 3-4 days.
Edit: I bet $N500 that xaelar wins this comp.
Postby TheRealOne » 2009.05.03 (16:14)
Most likely. Who won last season? seeing as xela's sig says blur runner up.
Postby Izzy » 2009.05.03 (16:28)
mam won last season.
Postby xaelar » 2009.05.03 (19:57)
Aha. And I bet $N500 that you bet too much.
NUMA Profile: http://nmaps.net/user/Infernus
Postby Infernus » 2009.05.05 (07:31)
I think you should update the deadline in your second post. I thought I was going to be disqualified until I checked my pms.
:P
My Maps | Highscores as Dan_K
<LittleViking> Don't expect more than second base on the Dumbo ride.
MBTI Type: ESTP
Postby kkstrong » 2009.05.05 (17:06)
ahaha, thats why xaelar meant in the top of this page! I, for some reason, kept reading that as "previous post." I will change that right now
MBTI Type: ESTP
Postby kkstrong » 2009.05.11 (06:59)
Demo's have now been opened, you can view the demo's now.
Golden Player: romaniac (+1 point)
Who made the cut: 7 out of 20 (+1 point)
Group One:
FIRST - Infernus - 139.350 = 5 points
SECOND - Izzy - 139.200 = 4 points
THIRD - Be_Inspired - 131.775 = 2 point
FOURTH - SlappyMcGee - 129.525 = 1 points
Group Two:
FIRST - xaelar - 141.450 = 5 points
SECOND - esay - 130.275 = 3 points
THIRD - Kablamo_Boom - 124.925 = 2 points
FOURTH - Alex777 - 0.00 = -1 points
Group Three:
FIRST - romaniac - 142.100 = 6 points
SECOND - vankusss - 140.650 = 4 points
THIRD - LittleViking - 137.725 = 2 points
FOURTH - BNW - 136.775 = 1 point
Group Four:
FIRST - golfkid - 139.525 = 5 points
SECOND - ToeFaceKiller - 138.600 = 3 points
THIRD - Avarin - 135.675 = 2 points
FOURTH - Guiseppi - 0.00 = -1 points
Group Five:
FIRST - KinGAleX - 139.150 = 5 points
SECOND - Riobe - 129.825 = 3 points
THIRD - UniverseZero - 87.225 = 2 points
FOURTH - Leaff - 0.00 = -1 points
Also, now seems to be a good time to say how stupid I am! I completely forgot to mention wildcards in my post about how this competition is going to work. If it seems you have have drawn the short end on the straw in group pickings (like it seems in group 3 ;) ), you still have options! There will be 2 wildcards chosed to go onto the rounds after these initial three. This means there will be 12 people in round 4, not 10 as I had previously stated. This will leave 6 people in round 5, and 3 people in round 6. As you might see, this will allow the competition to run alot more smoothly ;). Happy Demo'ing!
Round one began and ended with romaniac. Romaniac was the first competitior to break all the barriers in this round (except the "make the cut" barrier, which was broken by vankusss). He was the first above 140, 141, and the only to get above 142! He must have liked this map very much to improve him demo to the point of where even xaelar was nearly a full second under him. Innovation was key on this map. When I set the "make the cut" mark, I thought about 139.500 would be about the max score you could get! After seeing all the innovations possible, I was astounded! You all sure are smart <3. There was at least one big innovation on the way up to the trapdoor switch. You can see that in romaniac and vankusss' demos. Just when I thought you couldn't get over 140 without that innovation, xaelar gets over 141 without it! Crazy! Golfkid, Dan_K, Izzy and KinGAleX also made the cut, all by a good margin. I was dissapointed by TFK's participation this round, he is obviously good enough to make the cut, but missed it by about 3 frames. Where is that highscoring spirit? Haha. I was impressed by the outshowing of group 3! They all got scores above 136.750, which is quite a margin over all the other groups. Three people did not even bother to play the map :(. All three of those players have started off the competiton with negative points now. Thats a hole no one wants to climb in!
MBTI Type: ESTP
Postby kkstrong » 2009.05.11 (07:00)
Round Two:
Map: End of Comfort By Cerberus[]
Map ID: 166738
To Make the Cut: 131.250 (1150 frames)
Pacific Standard Time (GMT -8) : Sunday, May 17, 11:59PM
Grenich Mean Time (GMT +0) : Monday, May 18, 8:59PM
Brisbane Time (GMT +10) : Monday, May 18, 11:59PM
Any demos submitted after these times will earn the 0 points for the round, regardless of time.
Postby Nexx » 2009.05.11 (07:11)
Hold on a sec, there. I submitted a perfectly valid run under my NUMA username, Nexx. I would have mentioned the name difference from the outset, but you and I have seen each other around for so long that I assumed you would remember. It's no biggie that you didn't - after all, you know what they say about making assumptions...
But yeah, check again, and then make those negative points go away. :)
MBTI Type: ESTP
Postby kkstrong » 2009.05.11 (07:19)
okay, I will fix that, Avarin.
also, I accidentally deleted the demo's on the round 1 mapthrough a bug in NReality, I pm'd Unreality about it, hopefully he will be able to fix.
Postby remm » 2009.05.11 (08:31)
im not gonna do so well here, I cant do that first corner jump at all :(
but still I beat the 'cut' by a second without a cj. maybe it was a bit too low this time? we'll see
peking^
Postby xaelar » 2009.05.11 (11:49)
I cant watch any demos on the old map :/
Postby Unreality » 2009.05.11 (15:05)
please enjoy round 1 demos by watching them repeatedly until you die
Postby darkshadow » 2009.05.11 (16:21)
By the way the 1050 frame route is just romaniac's route except for the second group of gold running down the right side and doing a perpendicular jump off the left side. It's possible but difficult to get all the gold in that cluster using that method and it saves about two seconds.
MBTI Type: ESTP
Postby kkstrong » 2009.05.11 (19:25)
I tried that in FBF, and its even hard there. I saw that during the round though :(
Maybe since the cut off point is so low this week, more people can make the cut
MBTI Type: ESTP
Postby kkstrong » 2009.05.17 (20:23)
About 10.5 hours till deadline, sorry for the confusion all.
Postby Nexx » 2009.05.18 (07:23)
Whoops, I kept pushing this off until about 15 mins ago (which turned out to be the deadline, once I checked). Sorry for the lateness. :\
MBTI Type: ESTP
Postby kkstrong » 2009.05.19 (04:05)
Golden Player: xaelar (+1 point)
Who made the cut: Everyone who submitted a demo. 11 out of 20 (+1 point)
PLACE - PLAYER - SCORE = POINTS THIS ROUND = OVERALL POINTS
Group One:
FIRST - Infernus - 133.200 = 5 points = 10 points
SECOND - Izzy - 132.175 = 4 points = 8 points
THIRD - Be_Inspired - 0.00 = -1 point = 1 point
FOURTH - SlappyMcGee - 0.00 = -1 points = 0 points
Group Two:
FIRST - xaelar - 134.950 = 6 points = 11 points
SECOND - esay - 131.525 = 4 points = 7 points
THIRD - Kablamo_Boom - 0.00 = -1 points = 1 point
FOURTH - Alex777 - 0.00 = -1 points = -2 points
Group Three:
FIRST - romaniac - 134.200 = 5 points = 11 points
SECOND - vankusss - 132.025 = 4 points = 8 points
THIRD - LittleViking - 0.00 = -1 points = 1 point
FOURTH - BNW - 0.00 = -1 point = 0 points
Group Four:
FIRST - ToeFaceKiller - 134.475 = 5 points = 8 points
SECOND - golfkid - 132.875 = 4 points = 9 points
THIRD - Avarin - 132.175 = 3 points = 5 points
FOURTH - Guiseppi - 0.00 = -1 points = -2 points
Group Five:
FIRST - KinGAleX - 133.425 = 5 points = 10 points
SECOND - Riobe - 132.100 = 4 points = 7 points
THIRD - UniverseZero - 0.00 = -1 points = 1 point
FOURTH - Leaff - 0.00 = -1 points = -2 points
ATTACHED IS EVERYONES DEMO:
BLUR Round 2 demos.txt
(41.01 KiB) Downloaded 163 times
Users browsing this forum: No registered users and 42 guests
