:: BLUR: SEASON TWO :: ROUND FIVE HAS BEGUN : 169080
say, if the contest length is 10 days
Then if your final score submitted is the demo that you submitted at 1st day, your score +5
If you final score submitted is the demo that you submitted at 2nd day, your score + 4.5... and so on
In this case holding your best run and not to submit until the final moment...will not gain that much advantage.
*edited: wait, this idea sucks, it discourage ppl to improve their runs later on
- NUMA Profile: http://nmaps.net/user/maximumride
Unreality's awesome mod
sub 1050? thats crazy! I assume youre speaking of this weeks map, because I wouldn't think that sub 1100 would be possible. Im getting close, but an extra 50 frames past that seems rather difficultdarkshadow wrote:I'm not part of this because I don't have time but I'll still occasionally post something. In this case I just want to say that sub-1050 frame AGD is possible.
peking^
- MBTI Type: ESTP
max_ride, if someone drops, you may take their place, so long as you assume all the points that person has, regardless of if they are in first or last.
really? I thought I went on pretty often lately; at least once every 3-4 days.kkstrong wrote:ska you weren't on IRC ever :(
Edit: I bet $N500 that xaelar wins this comp.
Most likely. Who won last season? seeing as xela's sig says blur runner up.ska wrote:really? I thought I went on pretty often lately; at least once every 3-4 days.kkstrong wrote:ska you weren't on IRC ever :(
mam won last season.TheRealOne wrote:Most likely. Who won last season? seeing as xela's sig says blur runner up.ska wrote:really? I thought I went on pretty often lately; at least once every 3-4 days.kkstrong wrote:ska you weren't on IRC ever :(
Aha. And I bet $N500 that you bet too much.ska wrote:really? I thought I went on pretty often lately; at least once every 3-4 days.kkstrong wrote:ska you weren't on IRC ever :(
- Doublemember
- NUMA Profile: http://nmaps.net/user/Infernus
:P
- MBTI Type: ESTP
- MBTI Type: ESTP
Golden Player: romaniac (+1 point)
Who made the cut: 7 out of 20 (+1 point)
Group One:
FIRST - Infernus - 139.350 = 5 points
SECOND - Izzy - 139.200 = 4 points
THIRD - Be_Inspired - 131.775 = 2 point
FOURTH - SlappyMcGee - 129.525 = 1 points
Group Two:
FIRST - xaelar - 141.450 = 5 points
SECOND - esay - 130.275 = 3 points
THIRD - Kablamo_Boom - 124.925 = 2 points
FOURTH - Alex777 - 0.00 = -1 points
Group Three:
FIRST - romaniac - 142.100 = 6 points
SECOND - vankusss - 140.650 = 4 points
THIRD - LittleViking - 137.725 = 2 points
FOURTH - BNW - 136.775 = 1 point
Group Four:
FIRST - golfkid - 139.525 = 5 points
SECOND - ToeFaceKiller - 138.600 = 3 points
THIRD - Avarin - 135.675 = 2 points
FOURTH - Guiseppi - 0.00 = -1 points
Group Five:
FIRST - KinGAleX - 139.150 = 5 points
SECOND - Riobe - 129.825 = 3 points
THIRD - UniverseZero - 87.225 = 2 points
FOURTH - Leaff - 0.00 = -1 points
Also, now seems to be a good time to say how stupid I am! I completely forgot to mention wildcards in my post about how this competition is going to work. If it seems you have have drawn the short end on the straw in group pickings (like it seems in group 3 ;) ), you still have options! There will be 2 wildcards chosed to go onto the rounds after these initial three. This means there will be 12 people in round 4, not 10 as I had previously stated. This will leave 6 people in round 5, and 3 people in round 6. As you might see, this will allow the competition to run alot more smoothly ;). Happy Demo'ing!
Round one began and ended with romaniac. Romaniac was the first competitior to break all the barriers in this round (except the "make the cut" barrier, which was broken by vankusss). He was the first above 140, 141, and the only to get above 142! He must have liked this map very much to improve him demo to the point of where even xaelar was nearly a full second under him. Innovation was key on this map. When I set the "make the cut" mark, I thought about 139.500 would be about the max score you could get! After seeing all the innovations possible, I was astounded! You all sure are smart <3. There was at least one big innovation on the way up to the trapdoor switch. You can see that in romaniac and vankusss' demos. Just when I thought you couldn't get over 140 without that innovation, xaelar gets over 141 without it! Crazy! Golfkid, Dan_K, Izzy and KinGAleX also made the cut, all by a good margin. I was dissapointed by TFK's participation this round, he is obviously good enough to make the cut, but missed it by about 3 frames. Where is that highscoring spirit? Haha. I was impressed by the outshowing of group 3! They all got scores above 136.750, which is quite a margin over all the other groups. Three people did not even bother to play the map :(. All three of those players have started off the competiton with negative points now. Thats a hole no one wants to climb in!
- MBTI Type: ESTP
Map: End of Comfort By Cerberus[]
Map ID: 166738
To Make the Cut: 131.250 (1150 frames)
Pacific Standard Time (GMT -8) : Sunday, May 17, 11:59PM
Grenich Mean Time (GMT +0) : Monday, May 18, 8:59PM
Brisbane Time (GMT +10) : Monday, May 18, 11:59PM
Any demos submitted after these times will earn the 0 points for the round, regardless of time.
- Beyond a Perfect Math Score
But yeah, check again, and then make those negative points go away. :)
- MBTI Type: ESTP
also, I accidentally deleted the demo's on the round 1 mapthrough a bug in NReality, I pm'd Unreality about it, hopefully he will be able to fix.
but still I beat the 'cut' by a second without a cj. maybe it was a bit too low this time? we'll see
peking^
- MBTI Type: ESTP
Maybe since the cut off point is so low this week, more people can make the cut
- MBTI Type: ESTP
- MBTI Type: ESTP
Who made the cut: Everyone who submitted a demo. 11 out of 20 (+1 point)
PLACE - PLAYER - SCORE = POINTS THIS ROUND = OVERALL POINTS
Group One:
FIRST - Infernus - 133.200 = 5 points = 10 points
SECOND - Izzy - 132.175 = 4 points = 8 points
THIRD - Be_Inspired - 0.00 = -1 point = 1 point
FOURTH - SlappyMcGee - 0.00 = -1 points = 0 points
Group Two:
FIRST - xaelar - 134.950 = 6 points = 11 points
SECOND - esay - 131.525 = 4 points = 7 points
THIRD - Kablamo_Boom - 0.00 = -1 points = 1 point
FOURTH - Alex777 - 0.00 = -1 points = -2 points
Group Three:
FIRST - romaniac - 134.200 = 5 points = 11 points
SECOND - vankusss - 132.025 = 4 points = 8 points
THIRD - LittleViking - 0.00 = -1 points = 1 point
FOURTH - BNW - 0.00 = -1 point = 0 points
Group Four:
FIRST - ToeFaceKiller - 134.475 = 5 points = 8 points
SECOND - golfkid - 132.875 = 4 points = 9 points
THIRD - Avarin - 132.175 = 3 points = 5 points
FOURTH - Guiseppi - 0.00 = -1 points = -2 points
Group Five:
FIRST - KinGAleX - 133.425 = 5 points = 10 points
SECOND - Riobe - 132.100 = 4 points = 7 points
THIRD - UniverseZero - 0.00 = -1 points = 1 point
FOURTH - Leaff - 0.00 = -1 points = -2 points
ATTACHED IS EVERYONES DEMO:
- Attachments
- BLUR Round 2 demos.txt
- (41.01 KiB) Downloaded 163 times
