If you could make a new enemy...
Babble about your incredible affections of ninja puzzle platformers here.
Moderators: raigan, Mare
Postby lord_day » 2009.03.22 (15:52)
The Kitchen Sink wrote:Mortar cannon.
When it sees you, a target appears around where you were (looks like the aura of the alarm drone from NReality), showing where it will hit and its blast radius. It does this on the very first frame it sees you, with a cooldown of 1 second.
One second after the target is marked, there will be an explosion in that exact area, killing you if you're in its blast radius.
It's a cannon, so it doesn't move.
That is a really really good idea, and would work well in the N environment. Unreality, if you haven't already got something like this, could you make one for the next Nreality?
Postby Unreality » 2009.03.23 (02:02)
Probably :)
Postby Amadeus » 2009.03.23 (04:55)
Yay!
NUMA Profile: http://nmaps.net/user/minimap4646
Postby minimap4646 » 2009.03.23 (23:28)
launchpad drones...
┌┴─┴─┐-┘─┘ ●● Peace Out ●●
Postby Unreality » 2009.03.24 (01:39)
minimap4646 wrote:launchpad drones...
launchpads are already movable in NReality
Unlucky
Postby Watermelonz99 » 2009.03.28 (19:20)
Muncher drone
Doesn't do any damage to ninja. But it munches through tiles! However, it is affected by doors
Postby PsychoSnail » 2009.03.30 (00:09)
QFE.
I would add random movement (that actually works) to the existing drones and a way to stop thwumps without using tiles (like some sort of door or something like that).
These Go Up to 11
Postby cheese15624 » 2009.03.30 (00:49)
i would make another ninja that would chase u around. that would be alot more challenging.
he'd be able to push u off cliffs or into drones. and he could beat u up.
Moo :3
Postby Seneschal » 2009.03.30 (11:44)
Amadeus wrote:Hm
Nice thread
probably I would add an underwater element to N...that'd be way cool
And then I'd have torpedos
Underwater would be so cool imo
An underwater map...you mean like this?
Postby bobaganuesh_2 » 2009.04.03 (01:44)
eganic wrote: i would also make a floating platform. the most stereotypical object commonly found in mario games. you should all know what it does.
one-ways? thwumps?
how about a ghost drone, like the ghosts in Mario? if you turn ur back to em, them will go after you. no, that's boring as hell, so what about a tile turret? it will create an area and indicate it (like alarm drone) and the size of chosen area can be changed, and once the area field lines change colour, tiles will appear in that area. if the ninja happens to be in the area at that time, then it willb be killed
NUMA Profile: http://nmaps.net/user/Hanzo
Postby Titanium » 2009.04.11 (19:33)
A gravity well:
These would be activated by switches, and only one can be on at a time.
One switch would turn a grav well on, and another switch would turn any grav well off. The range of attraction would be 4 to 6 tiles. The same size as a gauss turret. When it pulls the ninja you hear something like the flying sound on Heroes.
Examples of the uses of gravity wells:
Scenario 1: If you have to jump over a long line of mines then it can give you a longer jump so you don't fall on them.
Scenario 2: You have to turn it off so you don't get pulled into an enemy. You could put it on a mine in a tunnel or in the middle of four one-way platforms.
Scenario 3: You have a string of them above the ninja in a horizontal line, and its suddenly like walking on the moon. Fun, and you could put them on bounce blocks too.
There are other possibilities, and you could also have something that repels the ninja.
Postby koipen » 2009.04.13 (07:58)
Gravity x 1.5 (Or any other strenght, also can be 0.5 or any else)
Makes gravity a lot more pulling so that you could perform some nafty jumps.
Deadly spot
Put this into your map and everything from drones to thwumps will die if they contact it. Even you. Has 2 square radius. You can lure enemies to this.
Postby Neil_Bryan » 2009.04.20 (06:48)
A 360 degree firing drone. It shoots a laser that forms a circle and gets larger and larger. It is deflected by tiles. Look at the picture below.
The drone sends out a circle, then it goes on the whole area, and unless you're protected by tiles or doors, you can get killed.
(5.82 KiB) Downloaded 3050 times
Postby Amadeus » 2009.04.21 (04:10)
Neil_Bryan wrote:A 360 degree firing drone. It shoots a laser that goes around for 360 degrees.
They have that, in Nreality.
NUMA Profile: http://nmaps.net/user/Alex777
Postby Alex777 » 2009.04.27 (18:04)
A black hole drone. It moves around the map and if you get to close to said drone, you will start to get pulled closer to it killing you on contact.
Or same drone but it fires black holes that last for 4 seconds. also it would suck up gold.
Vampire Hunter D Sig by 29403 ^,...,^
The Rose in Spanish Harlem
Postby Mae » 2009.04.27 (18:38)
I wouldn't. For the same reason I sort of dislike N Reality... It complicates things :$
Postby Alex777 » 2009.04.27 (19:06)
Mae wrote:I wouldn't. For the same reason I sort of dislike N Reality... It complicates things :$
I agree with that. But if they ever made a new freeware N game with new enemies, I would have the black hole drone. (posted above your comment I think) (:
NUMA Profile: http://nmaps.net/user/Viil
Postby Viil » 2009.07.19 (07:54)
i would have a hyper laser cannon.
I would be a movable drone, in which the first frame you are in it's view, it charges for a 2 second period, then fires a Light blue laser, even if it misses you, you get blown back from wind force.
omnomnom
Postby Yoshimo » 2009.07.19 (18:35)
Appearance: Blue, like a zap, but deeper blue. has eye like a chainguns.
Function(s): Has a targeting system like a guass, except faster and and more accurate. When it locks on, there is a 20 frame (half second) pause, then it fires a fast moving profectile that explodes on contact with a tile or door. The explosion creates a splash damage effect, killing the ninja within a certain radius. The drone moves a bit faster then a laser, but not faster then a chaingun. Stops when targeting.
Unreality?
Alos, I vote that we have to use this as a template.
NUMA Profile: http://www.nmaps.net/user/nicoguerreronico
Postby nicoguerreronico » 2009.09.23 (01:03)
I don't know about enemies but a door that had a timer on it and shut after, say, ten seconds. would add a lot to puzzles.
95% of teens today would start crying if they saw Miley Cyrus about to jump off a cliff. 4% of teens would say "JUMP DAMMIT!". Copy and paste this if you are one of the 1% who would climb up and push her off yourself.
Postby Rhekatou » 2009.09.23 (02:18)
A moving guass drone, a "mortar drone" (as mentioned above), a flamethrower that shot a flame in a direction for intervals of time before it shut off, then pause and restart.
Postby MiBeM » 2009.09.24 (12:07)
I'd make a thump that could have spikes on more sides than just one. That would have much more possibilities than a normal thump, for example, you couldn't wall jump using the thump, you couldn't run on it... Endless possibilities, that would be super in puzzles.
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby im_bad_at_n » 2009.09.25 (15:46)
I would make a duel ninja. Basically, if two ninjas are placed on the map, they can both move with the arrow keys and jumping. Will bring some facinating puzzles because one could be running right but the other would be unable to move because a wall is to its right and other things.
its also possible that three ninjas can do it and so on...
In Order:
last updated : 04/29/11
Postby unoriginal name » 2010.03.04 (05:08)
I like the Electric Circuit.
Menstrual
NUMA Profile: http://www.nmaps.net/user/sniperassassin
Postby sniper_assassin » 2010.03.28 (08:10)
a flame thrower drone.
Why would i want to eat your face off...? *licks ice-cream cone*
