Map "Demo" Packs
Moderator: zoasBE
So here is the idea:
Post a mappack that you have downloaded,
and post the demos,(completion demos,please)of the levels in that map pack.
Well I start with ChrisE's map pack So Simple.
And here is my completion demos:
(please specify that if you posted completion demos for every map in map pack,if you didn't,specify it as;"Except 5th map's demo,it has all other maps demos in this Map Demo Pack)
ChrisE's So Simple Map Pack,Map Demo Pack.(Except the demo of map "So Simple 2"):
Note:Completed So Simple 2.
Note: You can pm me if you want some map demo packs for specific map packs.
Another Note:To download map packs, search in posts, and find your map demo pack, there should be a link to download it also.
- Attachments
- St. Atilla's Map Pack Map Demo Pack.txt
- (48.99 KiB) Downloaded 225 times
- Map Demo Pack of Strange Effects Of İmagination.txt
- A Map Demo Pack of Map Pack of me
- (4.73 KiB) Downloaded 212 times
- Blackson's The BlackPack's Demo Pack.txt
- Blackson's Map Pack's Map Demo Pack
- (24.08 KiB) Downloaded 222 times
- Map Demo Packs.txt
- ChrisE's map pack So Simple Demo Pack.
- (6.17 KiB) Downloaded 215 times
Since I'm the only one uploads demo packs,I will continue to post demo packs.
This time I will post Blackson's The BlackPack Map Packs Demo Pack.The BlackPack.
Completion for all of the demos.
The BlackPack Demo "AGD"pack(it means that all the demos are agd):
- Attachments
- Blackson's The BlackPack Map Packs Agd Completion Demo Pack.
- (24.08 KiB) Downloaded 223 times
- Odd
How about instead of doing double posts, you put the demo pack into the main post?
I like the idea, but it all looks messy. I think you should think of a better layout to post it in. Also, maybe even a competition on this would be interesting :) It would be fun and you would be posting the demo's to map-packs the same time.
A map pack of Me.
Map Demo Pack of Strange Effects Of İmagination- By Me.
- Attachments
- Map Demo Pack.
- (4.73 KiB) Downloaded 209 times
- Commodus
You should place all the demo's in a first main post, so people will be more likely to use them.
For example, I don't want to search a 7 page topic for a demo that isn't even there ^^
Just an idea though.
- Attachments
- So Simple Map 2 Demo.txt
- The Completion on So Simple Map 2, that Tunco couldn't do.
- (247 Bytes) Downloaded 211 times
By the way I edited the 1st post, I completed So Simple 2 map, you can look to it. There İS that demo.Rule wrote:You should place all the demo's in a first main post, so people will be more likely to use them.
Quite off topic, I know, but how do you make that uppercase -i with a dot on top of it?Tunco123 wrote:By the way I edited the 1st post, I completed So Simple 2 map, you can look to it. There İS that demo.
St. Atilla's Map Pack Map Demo Pack is here!
-And if you want some specific map pack map demo packs, you can pm me.
And link to the map pack topic to download it:St. Atilla's College For Ninja
- Attachments
- (48.99 KiB) Downloaded 213 times
- Attachments
- ChrisE's Map Pack Map Demo Pack.txt
- (18.98 KiB) Downloaded 247 times
