Universezero's Olde Tileset Shoppe
Postby Universezero » 2008.10.11 (09:15)
Thanks to Eiturlyf for ideas and inspiration.
Welcome to My Tileset thread! I'll make anything for anyone! If you would like a tileset, simply fill out the following form:
Primary tiles : eg. Mainly dark, Rounded, Sharp etc.
Theme : eg. Fire, Cave, Alien, Simple, Robotic, etc.
Text : eg. Name, Phrase, etc. that will appear in the map (0-16 words)
Title : What the map should be called on numa. (1-39 words) *
Playable : Y/N/E, Details (default = Y) (E = Exit & Ninja) *
* = optional
Or, you can simply ask for a tileset with your name and I'll figure out the rest.
  • • If you don't fill in a category, I will probably use the default, depending on the map.
    • You can order more than one, but only one at a time.
    • Please be patient if I'm taking a long time on your tileset; it's possible I may be busy.
    • Make sure to add any other details you may want.
    • If you put "None" or "Nothing" as your text, please tell me if you want that written or for me to put literally nothing. Simply put: "Text : -"
    • I'm better at themed name tilesets. If you order a tileset with a person, character, image, render etc. then it may take longer to make, and may not be as good as some of my other tilesets.
    • Note, you may also use this thread to discuss my tilesets or other tilesets, tileset methods, etc.
    • Also note that I'm semi-retired, so don't ask why your tileset isn't done. I'll get round to it eventually.
Finished Tilesets :
Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net Nmaps.net
If you ordered one of these maps, you can have this userbar; DO NOT THIEVE THIS USERBAR LIKE I DID THIS SENTENCE.
Simply paste this into your signature:
[url=http://forum.therealn.com/viewtopic.php?f=18&t=331][img]http://img151.imageshack.us/img151/4553/universezeromademeatileeu5.png[/img][/url]
To-Do Tilesets :
  1. Neil_Bryan
  2. saff10
  3. jasdanu
  4. DarkN
  5. MReality
  6. McFizzle
  7. Hero
Postby origami_alligator » 2008.10.11 (09:24)
Moved from Images because this has little to do with graphic design programs or the creation of graphic images with something other than N.
MBTI Type: ESFJ
Postby jackass » 2008.10.11 (09:54)
Primary tiles: Any
Theme: Open area
Text: JA77
Title: Jackass is Awsum
[align=center]Image
Postby Universezero » 2008.10.11 (23:02)
Done
Also, thanks for moving this southpaw. I wasn't sure exactly were to put it.
MBTI Type: ESFJ
Postby jackass » 2008.10.11 (23:14)
Haha Thanks thats awsum
[align=center]Image
Postby origami_alligator » 2008.10.12 (03:56)
Primary Tiles: Silhouettes of paws, repeated throughout the map, but make it possible for playability.
Theme: Paws
Text: I don't want text.
Title: South Pawzific
Postby Universezero » 2008.10.12 (05:01)
Not fantastically tilesetish, but I'm happy with it.
Can't Touch This
Postby BNW » 2008.10.12 (06:53)
Primary tiles: 6 and 7 tiles
Theme: Black and White
text : none
Title: Reverse-Technicolor.
Sigs!
Postby Universezero » 2008.10.12 (08:04)
I'm not sure what Reverse Technicolor is. I need a little more information.
MBTI Type: ESFJ
Postby jackass » 2008.10.12 (08:40)
UniverseZero wrote:I'm not sure what Reverse Technicolor is. I need a little more information.
Umm UZ thats the map title
[align=center]Image
Re: UZ's Tilesets
Postby Evil_Sire » 2008.10.12 (19:57)
Pawz, that was classic.
I don't like these.
Postby Universezero » 2008.10.13 (03:18)
>.< *Headslap*
BTW BNWN, your tileset's almost done.
Evil_Sire wrote:Pawz, that was classic.
I don't like these.
*shrug* Each to his own.
Postby TribulatioN » 2008.10.13 (03:23)
Primary Tiles: Slanted.
Theme: Rough and Sharp.
Text: TribulatioN
Title: Kryne. Why? I don't know, sounds fitting to the theme.
Postby Universezero » 2008.10.13 (04:54)
I hope you likes.
I'll get right to work for you, TribulatioN.
EDIT: Done!
Also, I can redo any maps if you don't like them and I won't take offense. All, take note to make a 'Playable: Y/N' category when requesting.
Postby Eiturlyf » 2008.10.13 (07:47)
I love these threads.
Postby Universezero » 2008.10.13 (08:30)
Eiturlyf! You honour me by coming here. I one day wish to be as good as making tilesets as you are.
Postby ChaoStar » 2008.10.13 (17:11)
may I have one? i would be insanly happy if you made me one.
Postby TribulatioN » 2008.10.13 (18:37)
Ooh not what I had in mind, ahah, I still like it, well done.
I actually had somewhat of a vision that it'd look somewhat like BNWN's. When you first posted BNWN's, I didn't know who's it was and thought is was mine, cause that's what I thought it might come out as. Heh.
Postby Universezero » 2008.10.13 (19:42)
Firstly, wht kind of tileset do you want ChaoStar? (See first post for form)
Secondly, TribulatioN, if you want something like BNWN's, you can just ask! The more detail you give me, the easier it is to make. BNWN's was actually one of the hardest btw.
Postby TribulatioN » 2008.10.13 (19:56)
No no, it's fine, I was just saying that was my vision.
Lol. No worries.
Postby ChaoStar » 2008.10.13 (20:10)
Primary tiles: eg. old ChaoStarian
Theme: ChaoStarian
Text: ChaoStar
Title: a simple complexity
Playable: Yes
Postby Universezero » 2008.10.14 (07:10)
Postby isaacx » 2008.10.14 (12:34)
Primary Tiles: Pointy
Theme: Yoshi
Text: Isaacx
Title: The True Meaning of Math
Playable: Yes
Postby Universezero » 2008.10.15 (07:53)
I had a lot of fun designing the playable part of this map.
The Loneliest Number
Postby Threshold » 2008.10.15 (08:50)
hey this is Revolsion. could i please have a maelstrom (whrilpool)? they look awesome :) if u could do it, it would be great.
primary: all
theme: maelstrom
text: [above the tiles] Revolsion
title: Revolve
playable: meh
Users browsing this forum: Baidu [Spider], Google [Bot] and 36 guests
