Post a Run!
Postby Izzy » 2009.03.03 (01:35)
1st on 185-4 with a different route. It seems faster, but then again, fancy jumps aren't always better.
I've had 2 frames faster, but died at the fall.
Postby golf » 2009.03.03 (06:54)
Taken NUMA map 4 highscore by a significant margin. According to current NReality scores, I have it by 7.125 seconds with a time of 54.025. However, I know TFK had a 50.something before the NReality problems, so I consider it by only 3.5 to 4 seconds.
This is thanks to an innov that I have to give credit to TFK and TheRealOne for. Me and TFK saw it originally last fall, but after some brief testing, decided it was impossible to survive. Then TRO comes along and says that he's survived the fall, so I play around some. Eventually, I end up with what is now up there.
Along the way, I ended up with a couple other strange/humorous demos. So, here they are.
On this one, somehow I triggered a trapdoor switch under a piece of gold without collecting the gold. I may have seen this once before somewhere, but I'm not sure.
Then on this second one, I end up being bounced all around by the exit switch by the trapdoors.
Postby Raif » 2009.03.03 (10:54)
mohamedraif wrote:
mohamedraif wrote:NReality Highscores:-
79900 (maybe maxed)
56097 (maybe maxed)
444 (by 63 seconds)
120 (by 1.325 seconds)
122 (by 0.625 seconds)
Edit:- 94 (by 0.05, xaelar bites the dust)
xaelar wrote:xaelar bites nothing by 0.125!
Oh yes you do.
xaelar bites the dust on 444 highscore by 3.425 !!!!!
xaelar wrote:And I said xaelar bites nothing by 10.100!
Takes 120 highscore from xaelar by 0.750
Postby ToeFaceKiller » 2009.03.03 (21:17)
golfkid wrote:Taken NUMA map 4 highscore by a significant margin. According to current NReality scores, I have it by 7.125 seconds with a time of 54.025. However, I know TFK had a 50.something before the NReality problems, so I consider it by only 3.5 to 4 seconds.
Oh no way! That's awesome man, I thought we concluded that that was impossible. I'm at school right now so I can't submit my score, but I'll check what it is when I get home.
Postby kryX » 2009.03.04 (02:44)
i r sloppy, but i still gots it >>>>>>:D
Postby darkshadow » 2009.03.04 (04:35)
Sick run kryX. I'm surprised it wasn't a full 2 seconds faster.
Unreality's awesome mod
Postby golf » 2009.03.04 (06:00)
Thats got some pretty insane trapdoor chimneying in there as is. I'd hate to see a clean run, pretty sure it would last forever barring any other massive innov.
Postby TheRealOne » 2009.03.04 (20:08)
golfkid wrote:Thats got some pretty insane trapdoor chimneying in there as is. I'd hate to see a clean run, pretty sure it would last forever barring any other massive innov.
That I have. Now how possible is this innov time will tell, but it is pretty crazy.
Postby ska » 2009.03.05 (02:47)
Gah, another run of mine lost due to unreality losing his data :(
At least this one wasn't a 0th.
Postby golf » 2009.03.05 (06:18)
Took 136604 from Izzy by 6 frames. It was tough though.
NUMA Profile: http://nmaps.net/user/Infernus
Postby Infernus » 2009.03.05 (13:39)
golfkid wrote:Took 136604 from Izzy by 6 frames. It was tough though.
Beaten by .575 with an alteration.
My Maps | Highscores as Dan_K
<LittleViking> Don't expect more than second base on the Dumbo ride.
Postby bluenin » 2009.03.10 (23:16)
You guys should take a look at my speedrun on 65-0. I come in 6th, but I'd bet with some finesse it'd be pretty easy to take 26 frames off of it. Anyway, that corner jump is a bitch to pull off, and I'm kind of proud of it.
Postby ToeFaceKiller » 2009.03.10 (23:44)
Got 12 frames off yours, I'm not sure if 14 more is possible :/ Cool innovation though.
Postby darkshadow » 2009.03.11 (01:57)
I'm pretty much certain that route is slower. It does look cool however.
Postby golf » 2009.03.11 (07:18)
Took a few early NUMA maps tonight.
37 by 0.3 (a submission from back when NReality wasn't working all the way)
51 by 0.075
65 by 3.625
Postby Raif » 2009.03.11 (14:16)
golfkid wrote: 51 by 0.075
Retaken by 0.075
Postby xaelar » 2009.03.11 (16:11)
Took all 3 levels.
Postby bhz » 2009.03.11 (20:20)
golfkid wrote:Took a few early NUMA maps tonight.
51 by 0.075
65 by 3.625
37...is it possible to perform a couple reverse jumps?
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
Postby ska » 2009.03.12 (10:59)
51 by 0.075
65 by 3.625
How would that help?
Postby Raif » 2009.03.12 (14:41)
Retook 51 highscore from xaelar by 0.200
Postby xaelar » 2009.03.12 (18:01)
mohamedraif wrote:Retook 51 highscore from xaelar by 0.200
Nonono
Postby ska » 2009.03.13 (10:41)
ZOMG!Lok at these rocket close calls! O_o
Postby xaelar » 2009.03.13 (19:37)
Because NReality is down, I couldn't make a death demo.
This happened to me today, I couldn't believe it.
Has anyone seen this before?
I'm standing on the edge, a rocket is coming from the top right going under me.
The rocket goes right between me and the tile I am standing on. I didn't die and the rocket didn't explode.
Postby ska » 2009.03.14 (02:03)
WTF?!
man, you should have recorded that!
Postby Infernus » 2009.03.14 (03:55)
Hah, that's pretty cool. I've only ever seen that in ddas, never in actual gameplay.
EDIT: I attached a picture of a strange rocket incident. I'm guessing I didn't die because of the launch pad, even though it wasn't undeath.
(7.42 KiB) Downloaded 767 times
Users browsing this forum: Bing [Bot] and 18 guests
