Compare CPUs using CPU-Z
Postby Snuggletummy » 2009.03.04 (18:07)
Ok, so there's this neat little program that shows your CPU and whatnot. So.. yeah, that's about it.. here's mine at the moment.
Next time, on CPU-Z, Intel finally transforms into i7, and AMD has something to say about it..
Postby a happy song » 2009.03.04 (18:33)
My first foray into the wonderful world of Core 2 Duo.
Postby Donfuy » 2009.03.04 (19:30)
Desktop
Eee 701
Yet, this pc runs pretty fast. Much faster than what I would think.
Postby smartalco » 2009.03.04 (22:09)
Currently says my clock is 1600mhz (1.6ghz) because my CPU is idle, so it scales back the multiplier from 9 to 6 (as well as scaling the voltage from 1.22 to 1.12)
Added mainboard and memory panes for fun, CPUZ seems to think I have DDR3 memory (which is wrong, it is DDR2)
Postby scythe » 2009.03.04 (22:48)
Postby Luminaflare » 2009.03.05 (21:38)
I'm curious if I get a processor with a bus speed of 800Mhz (Pentium 4 3GHz) and put the multiplier to say 5 will it overheat the processor or what? Since my current processor has a multiplier of 11.5.
Postby Vyacheslav » 2009.03.05 (22:29)
and
Postby smartalco » 2009.03.06 (05:28)
Luminaflare wrote:I'm curious if I get a processor with a bus speed of 800Mhz (Pentium 4 3GHz) and put the multiplier to say 5 will it overheat the processor or what? Since my current processor has a multiplier of 11.5.
1) comparing the way AMD chips work to how Intel chips work (as far as with the bus) doesn't work that well
2) Intel's FSB (Front Side Bus) is what Intel calls 'quad pumped', an 800mhz bus is really 200 (200*4 = 800, notice the 'rated FSB' box on all the intel cpu screenies), so all you would do with that P4 is knock it down to 1ghz
Postby T3chno » 2009.03.06 (06:45)
Qui si castrano ragazzi
Postby GamingWolf » 2009.03.06 (17:35)
Alpha dogs don't know it's not fakin'!
Postby faemir » 2009.03.08 (17:41)
So that's why my pc can't run modern games ;D
How fatal? - Peter Sellers
Postby Chase » 2009.03.11 (21:13)
Voila. Pentium 4 :D
Users browsing this forum: Google [Bot] and 11 guests
