notsteve image inc. - now in black and white!
- Slice of Wisdom
/me blinks.notsteve wrote:the one i have now is my "best" so far
- Can't Touch This
Sigs!
- Slice of Wisdom
- Can't Touch This
Sigs!
- Slice of Wisdom
- Slice of Wisdom
heh, I think you should try out the following things:notsteve wrote:*bump*
1. Experiment with colors. There is nothing better than knowing when and how to use color in your images. Whether or not you're comfortable with using 4 or more colors in a sig isn't the issue. Learning how to break out of what you're comfortable doing is what is. Because you won't forget how to do stuff you already know, but you'll learn how to do stuff you don't.
2. I don't know what program you're using, but it looks like you're doing a lot of experimenting with lighting and such. Filters are my best friend, and I'm sure other imagers would agree that they play a large role in their imaging. Practice using single filters on single objects to begin with, and then practice mixing two filters to create an effect you wouldn't have been able to achieve before.
3. Themes. It's good to have a central idea around your signatures, even if it's just simply "abstract." Finding what themes your good at is fun. (such as T3chno being good with Comic Book Character sigs)
I don't know if any of that is specific enough to help, but it is something that is good to keep in mind. Hope to see more experimental stuff from ya!
- Slice of Wisdom
more colors?
- MBTI Type: ISFP
Please.
- Slice of Wisdom
i made another
behappy ill make yours next
- Slice of Wisdom
is this good? i can do another if you dont like
EDIT: MY FIRST RENDER SIG!
and an animatorish one
Also, don't go crazy with blur! You can ruin a sig with the blur effect, so only use it if you feel like it's extremely important. For the render sigs, try using outer glows with modes such as "pin light" or "color dodge" as these tend to blend the render better without compromising clarity.
A word on blur:
It's a great tool. But there are two things I do to restrict myself on it:
1. I only use it for depth. You know, to show things are far away or close. That adds a whole new level to you sig.
2. The second is that I create a new layer, apply image. Then I run a Gaussian Blur on it - usually about 4-10. It depends on the amount of effect you want. I set the layer on overlay and mess with the settings. It gives you vibrant colors. But also note, the technique backfires often, especially in sigs with multiple colors in a small area. You get mixed colors. Use with caution.
- Slice of Wisdom
for shortshift
i tried to follow you guys advice a little
- Slice of Wisdom
- It Must've Been Love
Be creative, i like some of these so far
eganic wrote:I WUMBLA
YOU WUMBLA
HE SHE ME
WUMBLA
- Beyond a Perfect Math Score
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
- Slice of Wisdom
- Slice of Wisdom
NEW SIG CHECK IT OUT! thoughts?
Too bright.notsteve wrote:DOUBLE POST
- Slice of Wisdom
also: rambo, i'll get yours done soon
