n help
- NUMA Profile: http://nmaps.net/user/Ncouraging
Also, right click and go to local storage, then drag to the bar to Unlimited storage space.
If all else fails, (and you're using Vista), Run As Administrator.
- NUMA Profile: http://nmaps.net/user/Technochocolate
My main game has also lost all data, but its not my concern.
Since I ever downloaded this game onto my computer, user-levels has never worked. I can access it on flashplayer N, but no levels have ever appeared on the list. I've read everything I could, on the Notepad documents and on the FAQs on the website and I can't figure out why I don't have any user levels. Even if I'm not entering data into it right, I should at least have the levels that came with userlevels.txt.
I have not tried re-downloading N, but I don't want to if I don't have to. But if I have to, that's alright.
Anyone got any helpful info?
- Oops Pow Surprise
ehhe sorry.
Anyways, you could have a number of problems
- your sol file corrupted in a matter of minutes. wow. In that case, that's kinda too bad.
- did you use the same account, and same file location for N?
- vista will screw up. cause it sucks.
- try running as administrator
- right click and select settings. are you letting N store enough?
@technochoc
ok. your userlevels.txt should have this line of code at the BEGINNING: &userdata=
if that &userdata= is missing, no userlevels will show up. then, as long as the levels are in the correct format, I don't see why it isn't working. Oh, and put the userlevels.txt in the SAME FOLDER as your game.
If that doesn't work, your best bet is to redownload.
Blame Vista. I had this problem too.Technochocolate wrote:I have a similar problem, and I might as well post it here, rather than starting a new thread to add to the useless threads littered all over this forum.
Vista is allergic to common sense, and blocks some types of programs while in program files or my documents. I don't know why, but it is impossible to acess a text file located in my documents. Move N to the C drive. This will cause the location of your SOL file to change however (it will be the same up to localhost, but then it should change), but you can just move it to the correct folder.
1. It does have the &... line, but not at the beginning. More specifically, it has Instructions, then the following:Daikenkai wrote:
@technochoc
IMPORTANT: changing the following line in any way will screw everything up. Don't do it!!
&userdata=
*** ALL LEVEL DATA MUST BE ENTERED BELOW THIS LINE ******************************************
then the level data. Is that why then? should I delete the instruction up to the &... line?
2. Yes, it is in a folder called n_v1pc
If number one doesn't matter, then I guess I'll have to re-download.
@Exüberance
yes, I know how to make ü's.
My n_v1pc folder is in my C drive.
And I'm almost positive my computer software is Windows XP, not Vista. lol, XP is a smiley! XP
- Oops Pow Surprise
the userlevels have to be in a correct format.
$levelname#Author#type#cooooooooodeeeeeee0000011111111111#
$level2#Author2#type2#morecooooodeeeeeeeeee0111111EIASHGORI#
etc. etc. etc.
N comes in a compressed folder (.zip). For the game to work properly, you need to unzip it. If you're running Windows, just right-click on the .zip, go to "Extract all..." and follow the prompts.
- MBTI Type: ISFP
It was in a compressed folder, so I unzipped it.
But now I figured out that unzipping the folder creates a new folder, not converting the old one. So now I have to go to another folder. Yay!
- Steam: What's Steam
Don't bump topics.Technochocolate wrote:After all this time I figured it out.
I started this side-topic many months ago; I know. I came to explain now because I found out that people were still responding and I wanted them to know that I figured it out so there's no point.29403 wrote:
Don't bump topics.
