Should I Submit This To NUMA Thread
Postby remm » 2009.02.01 (03:22)
I believe this to be a rather good map already, but i almost always overlook something basic, so can someone tell me what to add/remove. Did I do too much to the tiles? does the little minejumper bit fit in? What about the enemies that dont do anything. Is it too hard...etc
tell me what you think
peking^
Postby koipen » 2009.02.01 (10:14)
So i took advice and rounded up some things. I also found Exit button so it's complete. i changed the floorguard tunnel on the top because it was too hard the way it was. So here is my first map: Rocker
The Loneliest Number
Postby 01123 » 2009.02.04 (18:54)
I've got an N= map i want to submit to NUMA, but the submit page keeps telling me I need a vertical bar in the map data. The thing is, i have a vertical bar, right where it's needed.
Postby 29403 » 2009.02.04 (19:00)
If you're using N+, it won't work. You can only submit maps from the original N.
And numbers FTW!
NUMA Profile: http://nmaps.net/user/Eternal_Boredom
Postby DoctorAperture » 2009.02.05 (22:33)
err okay, this is one of my longest maps, and i really want to make it look nice, so if anyone could playtest, tell me what they like, and gime tips on object, i would love it...
random stuff
obligatory ad for my comic(s)
Awww, so cute!
MBTI Type: ESTJ
Postby Kablamo » 2009.02.07 (23:14)
EVALUATE MINE!
Hi Everybody!
Postby ska » 2009.02.22 (12:49)
Kablamo_Boom wrote:EVALUATE MINE!
Not bad!
Here's an agd
I think you shoiuld rework some of the tiles, but aesthetically i really liked the oneway/normal door comb worked and the the top left rocket was really well positioned. ATM a high 3, bordering a 3.5.
Postby koipen » 2009.02.22 (15:51)
Numa doesn't work but this is my newer map. Call it Tech style.
Postby Fraxtil » 2009.02.23 (00:56)
koipen wrote:Numa doesn't work but this is my newer map. Call it Tech style.
AGD:
Postby chume14 » 2009.02.23 (16:47)
Ok this ones a bit bizarre I've created a concept map but it has some issues and it hard to make it work if your willing to try it make sure you read the instructions
Instructions
1 Open ned and press h (load full map)
2 Post this map data
3 Press p to play
4 You are a rocket hold left to turn clockwise right to turn anti-clockwise
5 just fly around and stuff there is no aim yet
If you give me feedback I'll rce 3 maps on numa (bribes) please be sure to follow instructions
MBTI Type: ESTJ
Postby Kablamo » 2009.02.24 (04:47)
chume14 wrote:Ok this ones a bit bizarre I've created a concept map but it has some issues and it hard to make it work if your willing to try it make sure you read the instructions
Instructions
3 Press p to play
:0 :) :D
That is AWESOME!!!
how did you figure that out??
i think you should add a door and make a rule be that you have to get the door key and then get to the door.
Hi Everybody!
Postby Riobe » 2009.02.24 (07:44)
Instructions
3 Press p to play
Dude, that's insane. I'm not sure what you could do with it really, though the concept is fantastic.
Postby Why Me » 2009.02.25 (04:20)
Wow, I can't believe that I've never noticed this thread. I'll have to use this much more often.
Postby Tunco » 2009.03.02 (16:25)
Instructions
3 Press p to play
Awesome!How did you figured that out???
But anyway,great concept,just like RRR,couldn't compare with that but you can make awesome map out of it.
And can you please write your ideas about this map:
Postby chume14 » 2009.03.02 (18:54)
Cool thanks guys thats persuaded me to work on It I'll post a link to the numa map when I finish also the 3 RCE's go to Kablamo_boom since he was first (I didn't realize I'd get feedback from more than one person I'll do them tomorrow)
Tunco123 I played your map heres a AGD demo
I put it in the map box cause I wasn't sure what to do with it. I like it as a map its fun and challenging. Points I would work on the very left hand side its ugly and doesn't consist of much even if its just a better tileset work on that also some of the mines are unnecessary it seems over the top and makes movement cramp playtest it and try and find out which ones you can remove
What does RRR mean
Some people will complain about the amount of gold I didn't mind it this map is definitely numa worthy and with a couple of touches could get a solid 4.something =)
MBTI Type: ESTJ
Postby Kablamo » 2009.03.06 (10:14)
chume14 wrote: What does RRR mean
Rocket Rocket Revolution
Hi Everybody!
Postby Tunco » 2009.03.09 (16:36)
Please tell me your ideas about this map.
NUMA Profile: http://nmaps.net/user/gr_8
Postby gr_8 » 2009.03.13 (12:15)
ok, first off - get rid of the trapdoors hidden under the gold, no one will like them.
the tileset, was a little bland if nothing else. maybe try using a veriety of tiles, not just 'e' tiles, but the map you have made here
fitted well with the tiles it was given.
The laser and zap drones were placed extremly well, and the drone paths were just a little off awesome, so thats good.
however the beginning was a little bit of a rush, which then slowed down to almost nothing in the middle of the map.
some good jumps were incomperated into this map, but i don't know what getting an agd is like as i avoided basically all gold because of those trapdoors.
if nothing else, get rid of the traps.
otherwise, its an ok map.
sig by Jackass77. | avvie by GTM
Postby Tunco » 2009.03.16 (17:11)
Tell me what you think about this map:
Postby MattKestrel » 2009.03.31 (21:04)
Constructive criticism: It's too repetitive, laggy and cramped. Try and work on those things and try again.
Since Chaostar's left NUMA and possibly the forums, I decided to make a little going away gift in his style, of sorts. Not sure whether it's NUMA worthy, but I had a lot of fun making it for him :P
Postby koipen » 2009.04.08 (18:26)
Newest prsoner map Feway. Not sure about it's difficulty scale. Multipath BTW. It has actually six different paths to go.
GTM: Nice gameplay, truly. But some of the gold was akward to get. looked also nice,
NUMA Profile: http://www.nmaps.net/user/godless
Postby Godless » 2009.04.29 (21:07)
Can I get some ideas as for the plotline for this tileset? I'm having some trouble being creative =\
Postby Rhekatou » 2009.06.03 (02:27)
I have worked a while on this, and need a playtester.
please pm me =)
oh, and godless:
Spiteful...
Spikes...
Hate the light
Can't stand...
See my life...
flashing down on me
A star
Curves
But not a circle...
Unbroken
True
To me, a lie
to them.
Face....
Turn...
A Destiny for the fallen...
Lies in a circle broken...
Seek the lining...
should mine and fall win.
NUMA Profile: http://www.nmaps.net/user/nicoguerreronico
Postby nicoguerreronico » 2009.06.25 (18:50)
Person wrote:Ok this ones a bit bizarre I've created a concept map but it has some issues and it hard to make it work if your willing to try it make sure you read the instructions
Instructions
3 Press p to play
THAT IS AWESOME!
You should really make an actual map out of it like this one.
Reason: There you are. Also, just edit your post rather than double posting.
95% of teens today would start crying if they saw Miley Cyrus about to jump off a cliff. 4% of teens would say "JUMP DAMMIT!". Copy and paste this if you are one of the 1% who would climb up and push her off yourself.
Postby Rhekatou » 2009.06.26 (14:56)
nicoguerreronico wrote: THAT IS AWESOME!
Naw, sweep would get all angry-ish at you, if he were still around.
