Should I Submit This To NUMA Thread
I believe this to be a rather good map already, but i almost always overlook something basic, so can someone tell me what to add/remove. Did I do too much to the tiles? does the little minejumper bit fit in? What about the enemies that dont do anything. Is it too hard...etc
tell me what you think
peking^
- Maxwell Smart
So i took advice and rounded up some things. I also found Exit button so it's complete. i changed the floorguard tunnel on the top because it was too hard the way it was. So here is my first map: Rocker
- The Loneliest Number
I've got an N= map i want to submit to NUMA, but the submit page keeps telling me I need a vertical bar in the map data. The thing is, i have a vertical bar, right where it's needed.
- Steam: What's Steam
If you're using N+, it won't work. You can only submit maps from the original N.
And numbers FTW!
And numbers FTW!
- NUMA Profile: http://nmaps.net/user/Eternal_Boredom
err okay, this is one of my longest maps, and i really want to make it look nice, so if anyone could playtest, tell me what they like, and gime tips on object, i would love it...
random stuff
Awww, so cute!
- MBTI Type: ESTJ
EVALUATE MINE!
Hi Everybody!
Not bad!Kablamo_Boom wrote:EVALUATE MINE!
Here's an agd
I think you shoiuld rework some of the tiles, but aesthetically i really liked the oneway/normal door comb worked and the the top left rocket was really well positioned. ATM a high 3, bordering a 3.5.
- Maxwell Smart
Numa doesn't work but this is my newer map. Call it Tech style.
AGD:koipen wrote:Numa doesn't work but this is my newer map. Call it Tech style.
Ok this ones a bit bizarre I've created a concept map but it has some issues and it hard to make it work if your willing to try it make sure you read the instructions
Instructions
1 Open ned and press h (load full map)
2 Post this map data
3 Press p to play
4 You are a rocket hold left to turn clockwise right to turn anti-clockwise
5 just fly around and stuff there is no aim yet
If you give me feedback I'll rce 3 maps on numa (bribes) please be sure to follow instructions
Instructions
3 Press p to play
- MBTI Type: ESTJ
chume14 wrote:Ok this ones a bit bizarre I've created a concept map but it has some issues and it hard to make it work if your willing to try it make sure you read the instructions
Instructions
3 Press p to play
:0 :) :D
That is AWESOME!!!
how did you figure that out??
i think you should add a door and make a rule be that you have to get the door key and then get to the door.
Hi Everybody!
Dude, that's insane. I'm not sure what you could do with it really, though the concept is fantastic.chume14 wrote:Ok this ones a bit bizarre I've created a concept map but it has some issues and it hard to make it work if your willing to try it make sure you read the instructions
Instructions
3 Press p to play
Wow, I can't believe that I've never noticed this thread. I'll have to use this much more often.
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
Sigs made for me
My competitionMy writing forum
Awesome!How did you figured that out???chume14 wrote:Ok this ones a bit bizarre I've created a concept map but it has some issues and it hard to make it work if your willing to try it make sure you read the instructions
Instructions
3 Press p to play
But anyway,great concept,just like RRR,couldn't compare with that but you can make awesome map out of it.
And can you please write your ideas about this map:
Cool thanks guys thats persuaded me to work on It I'll post a link to the numa map when I finish also the 3 RCE's go to Kablamo_boom since he was first (I didn't realize I'd get feedback from more than one person I'll do them tomorrow)
Tunco123 I played your map heres a AGD demo
I put it in the map box cause I wasn't sure what to do with it. I like it as a map its fun and challenging. Points I would work on the very left hand side its ugly and doesn't consist of much even if its just a better tileset work on that also some of the mines are unnecessary it seems over the top and makes movement cramp playtest it and try and find out which ones you can remove
What does RRR mean
Some people will complain about the amount of gold I didn't mind it this map is definitely numa worthy and with a couple of touches could get a solid 4.something =)
What does RRR mean
- MBTI Type: ESTJ
Rocket Rocket Revolutionchume14 wrote: What does RRR mean
Hi Everybody!
Please tell me your ideas about this map.
- NUMA Profile: http://nmaps.net/user/gr_8
ok, first off - get rid of the trapdoors hidden under the gold, no one will like them.Tunco123 wrote:
the tileset, was a little bland if nothing else. maybe try using a veriety of tiles, not just 'e' tiles, but the map you have made here
fitted well with the tiles it was given.
The laser and zap drones were placed extremly well, and the drone paths were just a little off awesome, so thats good.
however the beginning was a little bit of a rush, which then slowed down to almost nothing in the middle of the map.
some good jumps were incomperated into this map, but i don't know what getting an agd is like as i avoided basically all gold because of those trapdoors.
if nothing else, get rid of the traps.
otherwise, its an ok map.
sig by Jackass77. | avvie by GTM
Tell me what you think about this map:
Constructive criticism: It's too repetitive, laggy and cramped. Try and work on those things and try again.
Since Chaostar's left NUMA and possibly the forums, I decided to make a little going away gift in his style, of sorts. Not sure whether it's NUMA worthy, but I had a lot of fun making it for him :P
- Maxwell Smart
Newest prsoner map Feway. Not sure about it's difficulty scale. Multipath BTW. It has actually six different paths to go.
GTM: Nice gameplay, truly. But some of the gold was akward to get. looked also nice,
- Member
- NUMA Profile: http://www.nmaps.net/user/godless
Can I get some ideas as for the plotline for this tileset? I'm having some trouble being creative =\
- Radio Douchebag
I have worked a while on this, and need a playtester.
please pm me =)
oh, and godless:
Spiteful...
Spikes...
Hate the light
Can't stand...
See my life...
flashing down on me
A star
Curves
But not a circle...
Unbroken
True
To me, a lie
to them.
Face....
Turn...
A Destiny for the fallen...
Lies in a circle broken...
Seek the lining...
should mine and fall win.
please pm me =)
oh, and godless:
Spiteful...
Spikes...
Hate the light
Can't stand...
See my life...
flashing down on me
A star
Curves
But not a circle...
Unbroken
True
To me, a lie
to them.
Face....
Turn...
Seek the lining...
- NUMA Profile: http://www.nmaps.net/user/nicoguerreronico
InstructionsPerson wrote:Ok this ones a bit bizarre I've created a concept map but it has some issues and it hard to make it work if your willing to try it make sure you read the instructions
3 Press p to play
THAT IS AWESOME!
You should really make an actual map out of it like this one.
Reason: There you are. Also, just edit your post rather than double posting.
- Radio Douchebag
Naw, sweep would get all angry-ish at you, if he were still around.nicoguerreronico wrote: THAT IS AWESOME!
