user levels
user levels
Postby dude=warren » 2009.01.25 (14:58)
i put the user levels thing in on the userlevels text and it doesnt work all that comes up on the userlevels is one level with 0 on it and when i go on it my player is invisible.what have i got to do to get more userlevels on it?why is N invisible?how do i get N to not be invisible?
Postby Pixon » 2009.01.25 (15:02)
Do you have the Level Data as $Level Name#Author#Type#Level Data# ?
Re: user levels
Postby dude=warren » 2009.01.25 (15:05)
yes i do have the level data.
Postby lord_day » 2009.01.25 (15:09)
Attach your userlevel.txt to your post so we can have a look at it, and perhaps find out why it isn't working.
Re: user levels
Postby dude=warren » 2009.01.25 (15:21)
ok this is the userlevel thing...
$Fluxgate#Yahoozy#action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|5^432,552!12^252,564!12^252,414!12^246,396!12^276,378!12^324,366!12^336,390!12^306,390!12^300,444!12^276,504!12^636,228!12^180,252!12^60,150!12^96,144!12^108,168!12^54,180!12^78,168!12^144,240!12^132,258!12^192,318!12^204,330!12^78,36!12^96,24!12^132,30!0^306,558!0^294,564!12^270,576!0^306,546!0^234,486!0^234,498!0^240,510!0^234,306!0^228,318!0^234,282!0^222,276!0^126,282!0^738,270!0^726,276!0^738,258!0^582,198!0^582,186!0^594,204!0^618,162!0^606,156!0^618,174!0^510,174!0^516,162!0^522,180!0^570,138!0^558,132!12^552,192!12^516,144!12^666,180!12^636,180!12^672,240!12^744,240!0^102,270!0^114,276!0^78,198!0^78,210!0^84,222!0^90,60!0^102,66!0^114,66!0^690,78!0^678,84!0^684,66!0^666,30!0^654,30!0^672,42!0^606,30!0^594,36!0^618,30!12^564,30!12^540,24!12^516,24!12^528,48!12^732,162!12^756,168!12^768,144!12^768,120!12^762,84!12^732,78!12^744,108!11^528,552,708,144!12^348,264!0^354,318!0^342,324!0^354,306!12^666,468!0^660,510!0^666,498!0^654,522!12^696,480!12^720,480!0^738,426!0^726,420!0^738,438!0^678,438!0^678,450!0^684,462!0^498,138!0^486,132!0^498,150!0^288,102!0^300,102!0^276,102!0^366,114!0^378,114!0^390,120!6^132,132,2,0,0,1!6^132,132,2,0,0,3!6^468,252,2,0,0,1!6^588,348,2,0,0,3!6^324,492,2,0,0,3!12^378,516!12^492,570!12^468,576!12^540,204!12^504,192!12^552,492!12^564,516!0^348,354!0^354,342!0^366,342!12^288,144!12^168,312!12^732,222#
Postby a happy song » 2009.01.25 (15:24)
You need to add the &userdata= command to your file. Your userlevels text file needs to read like this:
&userdata=
$Break#littleviking001#action#150000000000000GK50061050000000000000K15000010000000000000001500000:000K11111111LOK500000000OO1MI0000C1115000000000QQ503111111MI00000000000000100000000000000000?0000100000000000000000>0000100000000000000000000001A00000000000000000@0000000000000000000000P0000000000000000000000A0000000000000000000000000000000000000000000000<00000000000000000000?0100000000000000000000N0100000000000000000000>0=00000000000000000000000000000000000000000000@0000000000000000000000P0000000000000000000000A0000000000000000000000000000000000000000000000000000000000000000000?0000000000000000000000>000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000;00000000000000000000001000000000000000000000710|5^204,72!7^132,180,3!2^132,228,0,-1!7^155,84,0!7^155,108,0!1^516,204!6^300,396,2,1,0,3!6^708,492,2,1,0,2!6^204,228,2,1,0,0!9^96,564,0,0,3,23,0,0,0!9^72,564,0,0,3,23,0,-1,0!9^696,564,0,0,29,23,0,-1,0!9^720,564,0,0,29,23,0,0,0!2^36,564,7.8,-5.25!2^756,564,-60,-5.25!12^564,144!10^204,204!10^36,468!10^726,78!4^228,570,1!4^564,570,1!0^252,564!0^264,564!0^324,564!0^312,564!0^540,564!0^528,564!0^468,564!0^480,564!0^564,192!0^564,168!0^564,180!1^432,264!0^384,276!0^384,288!0^384,300!12^384,324!7^372,36,2!11^396,552,372,36!9^432,240,0,0,15,1,1,0,0!9^516,180,0,0,18,1,1,0,0!9^732,516,0,0,17,1,1,0,0!9^180,204,0,0,16,1,1,0,0!0^756,204!0^756,252!0^756,300!0^756,348!0^756,396!0^756,444#
Just make sure the first line of code is above all the actual level data and it will work just fine.
Postby Erik-Player » 2009.01.25 (15:25)
No no no. If you go down far enough when your replying you'll see "Add The File". Here's my userlevels.
userlevels.txt
Here's my userlevels.txt file (this is right).
(47.68 KiB) Downloaded 306 times
Re: user levels
Postby dude=warren » 2009.01.25 (15:46)
when i go on the userlevels text theres already levels on there bu theres no levels on the game.
Postby Spawn of Yanni » 2009.01.25 (15:51)
Go ahead and attach your userlevels file to a post. That'll make it easier for us to help you.
Re: user levels
Postby dude=warren » 2009.01.25 (15:54)
how do i attach my userfiles to a post?
Postby Spawn of Yanni » 2009.01.25 (15:57)
When you're posting, look below the first submit button. In the row that says "Filename", click on "Choose" and find your file. Then click "Add the file" and once it's done, submit your post.
Re: user levels
Postby dude=warren » 2009.01.25 (16:00)
ok this is the userfiles...
userlevels.txt
this is userlevels.
(410.62 KiB) Downloaded 289 times
Postby lord_day » 2009.01.25 (16:23)
While I can't find the level (by Yahoozy) you posted in there, the text file seems to be fine. Is it in the same folder as n_v14 is? That could be the problem.
Re: user levels
Postby dude=warren » 2009.01.25 (16:31)
it says its in n_v1pc
Re: user levels
Postby dude=warren » 2009.01.25 (16:36)
oh its suddenly gone on like theres 152 on there.i dont know who helped me but thank you very much!
