You are a drone, KILL!
Gross
Postby everythingfromatoz » 2009.01.10 (19:55)
LINK
My first game ever! And first time using gamemaker.
Ever wanted to be a drone? Think the drone? Well heres this game!
screenshot for some peeps:
Also, I threw in my second ever pivot animation!
Menu screen
Postby EdoI » 2009.01.11 (16:10)
I was using GM for a month and I made one game. Then I stopped for a year and now I'm using it again. I'm still in learning phase so I don't know how to work in 3D, but since you're using GM Lite you couldn't even if you want to. I work in GML so if you need some help, you can ask me some stuff. You're using drag&drop? Try using horizontal/vertical speed instead of move fixed option. That will make your motion smooth. Feel free to ask anything but don't forget that I'm still learning.
Gross
Postby everythingfromatoz » 2009.01.11 (17:47)
Thank you! I'll keep that in mind!
Postby Exüberance » 2009.01.11 (23:09)
EdoI wrote:I was using GM for a month and I made one game. Then I stopped for a year and now I'm using it again. I'm still in learning phase so I don't know how to work in 3D, but since you're using GM Lite you couldn't even if you want to. I work in GML so if you need some help, you can ask me some stuff. You're using drag&drop? Try using horizontal/vertical speed instead of move fixed option. That will make your motion smooth. Feel free to ask anything but don't forget that I'm still learning.
Using the motion tool should be no different than adjusting it's coordinates. All the motion thing is, is really a built in "class" (if GM had classes, it would be one) that adjusts co-ordinates every fram based on the set variables speed and direction. Ever since I started using GML instead of the drag-and-drpo (so pretty everything exept half of a game) I've just manually changed co-ordinates every frame based on my own _speed and _direction variables.
*sigh& GM would be so much awesommer if it supported classes and objects. Instead you have to use only static functions and pass pointers to them. Actually, you just past integers to them that have nothign to do with memory locations. Oh well, I guess it IS a learning language, not a high-level OOP language. Too bad it's not both :D (though it does pretty well)
Nmaps.netNmaps.net
Gross
Postby everythingfromatoz » 2009.01.11 (23:28)
What about my GAME!?!?!
Oie.
Postby EdoI » 2009.01.12 (13:19)
everythingfromatoz wrote:What about my GAME!?!?!
Oie.
Well, drones don't get killed by mines :)
Gross
Postby everythingfromatoz » 2009.01.12 (13:36)
I know. But what else is there?
Postby EdoI » 2009.01.12 (22:30)
Few pixels around the (every) mine is little lighter than the background of your game. You know, there is a 'Transparent' checkbox. It shall be turned on. That way any pixel that is like the first pixel(that is left-down) won't be visible.
Gross
Postby everythingfromatoz » 2009.01.12 (23:38)
Yea, the transparency wasn't working.
Postby heatwave » 2009.01.14 (22:16)
everythingfromatoz wrote:I know. But what else is there?
I would have taken this in the direction of a puzzle. Mines shouldn't kill drones, however, normal doors, locked and trap doors should impede the drone, making it harder to catch/kill the ninja.
Postby Exüberance » 2009.01.15 (04:15)
everythingfromatoz wrote:Yea, the transparency wasn't working.
The bottom-left pixel must be the same colour as the background. This is how it determines what the background is. Also the background must be ONE solid fill, not a jpeg'd textury semi-solid colour.
Another possible cause is that it MIGHT not allow transparency in the free versino if that's what you;re using.
Nmaps.netNmaps.net
Postby isaacx » 2009.01.15 (14:01)
Exüberance wrote: Another possible cause is that it MIGHT not allow transparency in the free versino if that's what you;re using.
No it does, i've made about a couple dozen crappy games until i quit about 3 months ago
Postby blackbelmoral » 2009.01.19 (19:34)
you forgot to add a loading bar picture
you forgot to add a homing turbo
you forgot to have an animation change depending on direction
drones can go through mines
drones cant go through doors
you forgot to make the
YAR HAR!
X2
Sigs:
29403|?NicNac?| Kablamo
Postby unoriginal name » 2009.01.21 (20:03)
blackbelmoral wrote:you forgot to add a loading bar picture
last words.
Postby Donfuy » 2009.01.21 (20:37)
blackbelmoral wrote:you forgot to have an animation change depending on direction
This.
And diagonal movement.
AND I GOT SPAMMED WITH TEXT BOXES.
Gold is evul.
Gross
Postby everythingfromatoz » 2009.01.26 (23:35)
Yea.
It's blah.
Postby Superpok » 2009.02.10 (03:23)
the game would be hard enough even without mines, you could record variying levels of speed for the ninja
and you should also change the drone's picture cuz normal drones don't do this
i have used gamemaker and made a basic maze game...
Signature Bars
NUMA Profile: http://nmaps.net/user/RedSham
Postby RedSham » 2009.02.24 (23:59)
I've worked with this program for about a day, so I can't be too helpful, but...
I'm pretty sure that there's a command that changes a sprites animation frame, so you could use that to rotate the eye, each sprite frame having a different direction.
Sig by GTM
Postby Zephyr » 2009.02.25 (19:58)
Wont work for some reason
I have GM...and ive never used it.
Clickme
Postby Lenny » 2009.02.27 (12:13)
You know, this is actually pretty cool. Well done.
For constructive criticism... diagonal movement, and no stop-start movement would be great. Also, maybe restart the demo level as opposed to having a message box, because then it doesn't allow movement and all sorts of things happen.
Also, bit pixel-y, an it would be cool if the drone turned depending on which way you were going (and he can't really be homing, can he?).
