Adventures of the Exüberant (Comic #90) {Jan 9}
NUMA Profile: http://nmaps.net/user/player_03
Postby player_03 » 2008.12.15 (03:13)
So if you divide by zero, all that happens is you wake up?
Tsukatu wrote:Now, making sure Caps Lock is ON, make sure that Caps Lock is on. Now that Caps Lock is actually on, check again to make sure that Caps Lock is on. Now press the P button. To play, make sure that Caps Lock is on.
!Reality
My achievements
My N video
Postby Exüberance » 2008.12.17 (17:47)
Well not really. Dividing by zero is just an error. It doesn't mean anything. See? I'm-
*poof*
Wow, that was an... odd dream. Well dividing by zero can't actua-
*poof*
That was a strange drea- waaaiiiittt a minute! Whenever I-
*poof*
It's a hearthstone!
Nmaps.netNmaps.net
Postby Exüberance » 2008.12.23 (22:00)
The storyline is back!
We last left off with our heroes inside the enemy base, and Ancaladar the evil mage has been sent to capture Wannas by the Master Drone. However, Ancaladar has different plans, and wishes to destroy Wannas in a contest of power instead of obeying his master's command....
#89: "Mistaken Spell"
I guess his polymorph is next to his portal in his action bar :D
Also, on an unrelated note:
╞════════Exüber-advertisement════════╡
Exuberance now has another contest, which is updated realtime more frequently! It's a puzzle to uncover the identity of my secret N-related project (it's not another level editor or comic) Letters are filled in to a hang-man type puzzle every time someone solves a riddle. At that time, a new riddle is posted, which will place another letter if solved in time! There's sig tags to be won for solving riddles and for solving the whole thing! What are you waiting for, head on over!
Nmaps.netNmaps.net
Postby Turiski » 2008.12.24 (18:50)
I'm not sure.
Your comic has always given me mixed reactions... but I hope you've re-thought the storyline for this time because I didn't really like where it was going before.
Other Project
Alive
Postby Shadow » 2008.12.26 (23:21)
Finally, the storyline is back. I can get back to reading the real N comic.
Alive
Postby Shadow » 2008.12.27 (00:38)
There is something wrong. Everytime I download the Exuberance comic flash file it never works, why?
Postby isaacx » 2008.12.27 (14:58)
i'm not sure, it doesn't work for me either, and the last comic seems a bit wierd (i don't understand it)
Postby Exüberance » 2008.12.30 (06:03)
Shadow wrote:There is something wrong. Everytime I download the Exuberance comic flash file it never works, why?
hhhmmm. Works for me.
Unfortunately, even if I knew why it didn't work for you, I couldn't fix it because I accidentally deleted the source file >_<
I'll probably just make a new one (and hopefully get rid of the slight blurring of text while I'm at it)
Nmaps.netNmaps.net
Postby Turiski » 2008.12.30 (17:39)
You accidentally deleted the flash file?
What were you doing?
Other Project
Postby bhz » 2008.12.30 (21:40)
Err....Your sig says you are Over Active (~2 comics a week) but there has been no comic for a week!!!
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
Alive
Postby Shadow » 2008.12.31 (03:21)
I just downloaded the file again and it still dosen't work.
Anyway, I have another idea, just make a new flash file of the N comics.
Postby Exüberance » 2009.01.05 (03:39)
Turiski wrote:You accidentally deleted the flash file?
completely redoing both my old computer and my fail laptop (not my current laptop, a different one- the fail one). I thought I grabbed everything off them I wanted.
I was wrong.
Anyways, I'll see if I can find a decent decompiler. The compiled version is still good. I also figrued out how to fix the images so they don't get blurry, but I don't have the source yet >_<
Also, about the over-active: I had some ideas for comics to do, but never got around to them for a whole bunch of reasons. I changed my sig to a more reasonable level now :D
About the SWF not working: make sure you have Flash Player 9 or 10 installed. You should actually only need 8. Works fine for me. What exactely does it do? Does it just show a blank white nothingness or does it show up but no buttons work?
Nmaps.netNmaps.net
Postby Exüberance » 2009.01.10 (05:51)
Time for an epically late Christmas special. Just cause Christmas was 17 days ago doesn't mean I can't make a comic about it now!
Comic #90
"EULA Christmas"
Nmaps.netNmaps.net
Postby isaacx » 2009.01.10 (23:32)
Exüberance wrote:Time for an epically late Christmas special.
I think you mean "epicclly"
Anyways, will you ever be continuing the Fernat Epic?
Postby Exüberance » 2009.01.11 (00:10)
isaacx wrote:will you ever be continuing the Fernat Epic?
Probably. Not a high priority right now though
Nmaps.netNmaps.net
Gross
Postby everythingfromatoz » 2009.01.11 (14:30)
=] MERRY CRISTMAS!
Sounded like a contract!
Alive
Postby Shadow » 2009.01.12 (23:10)
Exuberance, what kind of flash player do I need. Macromedia 8, 9 or 10, I'm not sure.
Anyway, when will you be doing another comic.
Gross
Postby everythingfromatoz » 2009.01.15 (00:55)
You need flash 8.
Postby Exüberance » 2009.01.15 (01:35)
I attempted to decompile the Flash using 3 proffesional-looking programs...
...turns out that just because a program has a good website, high cost, and looks proffesionally done, doesn't mean it's not complete crap.
They all 1) didn't export Actionscript in the trial version 2) Did about everything wrong (movie clips are now graphics, text is now graphics, bitmaps are now solids filled with a bitmap fill of the image, placed inside a graphic, which is then places inside another graphic, which is placed inside a movie clip. (ok, that last one was a bit specific to one of the programs...)) and 3) increased the size of my library 3-fold... at least.
So... new plan.
Completely redo the comic viewer from scratch.
And now that I've figured out how to use SOL files, I can add bookmarking and favourites.
I'm planning on posting 2 versions: a large one that looks nicer and is intended for screens of resolution 1440x900 or higher, and a squishied one that works on monitors of size 1024x768. If you have a resolution lower than that, it's about time for an upgrade... actually it was time for an upgrade a long long time ago!
Things that will be added to Adventures of the Exuberant Comic Viewer Reloaded Plus Edition Director's Cut 2.0 Extended Edition Plus Plus:
Note: It's possible some features may be cut in the 1024x768 resolution version so to size limitations. I'll probablu just make them pop out from tiny icons on a toolbar or something though
  • Ability to bookmark a page, meaning you can go to another comic, then instantly flip back to it. Also, when you open the comic viewer, it will automatically go to the bookmarked comic if the bookmark is set.
  • Ability to mark comics as favourites, which puts them in another list. I'll probably just mash this in with the tag feature.
  • Ability to use random, previous, and next buttons for a subset of comics instead of all of them (so you can choose a random comic out of your favourites etc.)
  • Each comic will contain comments by me.
  • Preset and editable tags on each comic for easy searching
  • The bluryness of images will be fixed
  • Possibly (I might not, but probably) uposted comics
  • Possibly some alternate endings to comics (of course there will also be the original version too)
Updating the comic viewer will not interfere with your saved favourites. Opening up an older version might though.
((I haven't actually made this yet.))
Nmaps.netNmaps.net
Postby beethoveN » 2009.09.22 (02:55)
need more comics!
If we shadows have offended,
William Shakespeare
Postby beethoveN » 2009.09.25 (18:02)
*ahem* I said, we want more!
William Shakespeare
