PLEASE HELP!
Postby lolzers » 2009.01.10 (05:24)
ok so I got the training levels a little bit back and I added them to both my nreality and nv2pc userlevels .txt.and now when I go to userlevels It's not there! PLEASE HELP ME!
Make this smaller? Blizzy do!
Sig by BE_nSPIRED(He Owns)
Nedeter Nation number 49!
Postby George » 2009.01.10 (13:53)
Can you try to be a little more descriptive? What exactly disappeared? Everything, or just the training levels? Have a look inside your document to see if all the data has been formatted correctly. If you still can't resolve your problem, post you file here and I'll see what I can do to help.
Postby Pikman » 2009.01.10 (16:28)
Put &userdata= before your level data.
Postby lolzers » 2009.01.10 (16:46)
just the training levels dissepeared and I already have &userdata= before my levels,and when I got the nlimpics the worked! but these won't!
Postby TribulatioN » 2009.01.10 (18:19)
Are you sure that the files aren't corrupt?
Or have things out of order?
Postby lolzers » 2009.01.10 (18:21)
I'm sure I put them in like every other map
Postby TribulatioN » 2009.01.10 (18:24)
Well if you did it properly, then it should work..
Did you have two &userdata = 's?
Did you forget to save it?
Cause the way I see it, it's not that they "disappeared", it's cause N won't read the files.
Postby unoriginal name » 2009.01.10 (20:53)
Wait, wait.
lolzers wrote:nreality and nv2pc userlevels .txt.
First, NReality doesn't have a userlevels.txt. You play NUMA maps in the userlevels menu of NReality. Second, Nv2?! The latest version is 1.4.
Explain yourself.
Postby lolzers » 2009.01.10 (21:24)
when I downloaded it It said nv1pc whoops,well anyway I copyed my userlevels txt to my nreality folder and it wored fine but it wouldn't load the training levels
Postby TribulatioN » 2009.01.10 (22:03)
lolzers wrote:when I downloaded it It said nv1pc whoops,well anyway I copyed my userlevels txt to my nreality folder and it wored fine but it wouldn't load the training levels
Ohhh I think I know your problem.. NReality doesn't work with userlevels.
You have to use the original n_v14_b to play userlevels.
Postby lolzers » 2009.01.10 (22:26)
should I get rid of the userlevels file in nreality?
Postby TribulatioN » 2009.01.10 (23:12)
it's not necessary.
Postby lolzers » 2009.01.10 (23:15)
I don't thinkI can do it because i've done everything possible and it won't work.please coninue to help
Postby TribulatioN » 2009.01.10 (23:22)
Okay.
From the original N folder that you downloaded, there should be a Text Document named userlevels.
You only put the user levels you want into that document. Save & Close.
Then open the original N, not NReality, click user levels, and it should all be there..
Postby lolzers » 2009.01.10 (23:50)
that's what I do and it doesn't work
Postby Riobe » 2009.01.11 (01:20)
lolzers wrote:that's what I do and it doesn't work
Ok, you need to have Nv1.4pc installed/downloaded on your computer. Open up the folder, and paste the userlevels text there (as said above).
If that hasn't worked, is the name of the text document userlevels? Because if it's not named userlevels, it won't work. I've also learned from experience that you can't have two text documents with the phrase "userlevels" in the same N folder, because it won't upload correctly, or something like that.
In NReality, userlevels do work, but the demo's don't always show once you beat a level. So I would not recommend using NReality userlevels anyway.
If all your other levels work besides the level data you recently posted, they this could be because of two reasons:
1. The data you posted was already corrupted, so none of the levels work. This could also possibly mean that the most recent data you posted before you posted the training levels could have been corrupted, in which none of the levels below that particular level would load. So that means there could be a bad seed in the userlevels. Look through the levels in Nv1.4pc just incase, and if theres a level that isn't numbered, or missing a category, or has the level data as the type of map, cut and paste it somewhere else, or try to fix the problem.
2. You you could have copy pasted it wrong. Try it again, maybe even do it level by level if you have to.
Well, hope that helps.
Sonnet
NUMA Profile: http://nmaps.net/user/Rdy-kun
Postby Rdy-kun » 2009.01.11 (17:58)
Riobe wrote: I've also learned from experience that you can't have two text documents with the phrase "userlevels" in the same N folder, because it won't upload correctly, or something like that.
Really? I have a 'userlevels.txt' and an 'atillas userlevels.txt' in the folder, and it parses the data fine, and switching them is easy. The only thing I can possibly think of is that once it deleted all my demos, but it hasn't done it again.
Perhaps if userlevels is at the beginning of the file?
Userbars are anti-dial-up.
Good thing I don't see signatures. :)
Postby Riobe » 2009.01.11 (19:53)
I'm not sure about that one, it could be dependant on where it is placed in the folder though.
Postby Pikman » 2009.01.11 (22:35)
TribulatioN wrote:NReality doesn't work with userlevels.
Yes it does.
Postby Superpok » 2009.01.13 (00:42)
yeah, all advice has been given, could you post your userlevels.txt so we can see? there might also be two &userdatas
Signature Bars
