Post a Run!
Postby xaelar » 2009.01.08 (17:30)
66-0 by half a sec. That was damn easy ;)
EDIT: Tied 66-1. I lost my nhigh lately and can't reload it, how many 0ths do I have? Excluding cheaters/hackers?
Postby eru_bahagon » 2009.01.08 (20:31)
You have 209 0ths ! (and you won't stop here :O) With the same ignore list as yours. ;)
Postby xaelar » 2009.01.08 (22:31)
Hehe thanks :D My next aim is 250, which might be reachable.
36-0 by 0.7, still needs half a sec more to be a great run :)
Improved my 0th on 36-1 by 4 frames, nearly matching kryx.
Postby ska » 2009.01.10 (03:37)
xaelar wrote:Hehe thanks :D My next aim is 250, which might be reachable.
nice xela, don't take too many of mine though ;)
Postby aids » 2009.01.11 (02:55)
woop-woop! woop-woop!
Postby xaelar » 2009.01.11 (11:56)
Congratz on ep 03 speedrun!
I took 69-1 by 1 frame ;D
Postby ska » 2009.01.11 (14:04)
xaelar wrote:Congratz on ep 03 speedrun!
Wow! Nice, I am genuinely impressed by that... Good stuff.
Postby xaelar » 2009.01.11 (16:40)
Thanks ;D
Tied 49-3. Still, .575 is possible, did it with missed gold. Stupid drone ;/
EDIT: Tied 49-2. Why do I only tie? Crap.
Almost as Bad as One
Postby keithgmccall » 2009.01.11 (18:19)
I got 92.850 on 129-4. How do I get it put on the high score list?
Postby xaelar » 2009.01.11 (19:40)
First you need to create an account, look under configure. After your login is successful you just press submit when you're watching the highscore list for ep 129.
Postby keithgmccall » 2009.01.11 (20:25)
Is there anyway to see if you have high scores without going through every single level?
Postby aids » 2009.01.11 (22:09)
keithgmccall wrote:Is there anyway to see if you have high scores without going through every single level?
yes. the NReality site.
on this image, the submit button is in the top leftmost corner, next to the <personal bests> listing. the episode score at the top represents the demos submitted when you play the episode through the main page (play the game) from level 0 to level 4. alternately, if you only want to play a single level, the <view scores> listing, located mid-top of the page will allow you to do that.
anything else?
Postby Izzy » 2009.01.12 (13:47)
I just took 60-2 speedrun 0th with a very improvable run.
Postby xaelar » 2009.01.12 (14:15)
Cool corner kick Izzy ;D But you should say if it's a speedrun, everytime you post a map number or a metanet level.
I took 44-1 from j_f, he's still loosing his best scores.
EDIT: BWHAHAHAHAHA!!! Improved my run by one second and KRYX BITES THE DUST; SORRY KRYX ;/
Postby eru_bahagon » 2009.01.12 (15:26)
Amazing 44-1 !
I saw your 155.675 yesterday. And today, it's a amazing 0th. Nice job ;)
Postby xaelar » 2009.01.12 (15:52)
Thanks ;D I like this sort of level, I knew I could take at least the 0th from j_f.
I have one more: Improved my 0th on 97-3 by 4 frames, stealing the tie from 7aMaDX ;)
EDIT: johnny again, 67-0 by 7 frames ^^
Postby golf » 2009.01.12 (19:54)
15-4, by just over a second. Essentially an entire route change, except that wedgie has a run up there going the same way, except that I do mine by over a second and a quarter faster.
Also, 85-1 only 6 frames back from Lim, I think that's not too bad.
Postby xaelar » 2009.01.12 (20:09)
Woah, you're 15-4 is awesome, I was working on that level just 2 days ago.
Btw: 36-2 is annoying me. I beat kryx with the normal route, getting .975 three times. Then I tried Analu's route, dying on the ground only 1 pixel near the exit with 385 frames or 80.325! .... I will try my best ;D
EDIT: I didn't use the innovation but got 80.200. Well it sucks but I still have the 0th O_o 80.500 should be easy with the innovation and a clean run.
Postby darkshadow » 2009.01.12 (20:53)
Wow nice 15-4 and in particular nice 85-1. If you had smooth right and left sides you would have had 0th easily since your center is just so perfect.
Unreality's awesome mod
Postby golf » 2009.01.12 (21:01)
Nice runs on 15-4 already, xaelar and darkshadow. Didn't think it would be challenged so much that quickly. Glad I didn't stick with my 132.250.
darkshadow wrote:Wow nice 15-4 and in particular nice 85-1. If you had smooth right and left sides you would have had 0th easily since your center is just so perfect.
Thanks! Problem is, I can't get that perfect center again, and my run up the left side is really about as good as I can consistently get it done. Everybody else up there near the top probably does either side .3 to .5 seconds faster than I do. Watching Lim's and lookatthis's runs, I think 182 is definitely possible here.
Also, I think your way down on 15-4 may be slightly faster than my and xaelar's way. Have to test it to see.
Postby aids » 2009.01.13 (04:04)
Izzy wrote:I just took 60-2 speedrun 0th with a very improvable run.
funny, I was thinking the same thing. I just couldn't do it.
Postby xaelar » 2009.01.13 (13:42)
Retook 15-4 by 0.425 and took 38-3 by 0.450 ;D
EDIT: Tied crappitrash on 38-4 :P
Postby ska » 2009.01.13 (15:47)
xaelar wrote:Retook 15-4 by 0.425 and took 38-3 by 0.450 ;D
oh and 67-0 you cheeky speedster.
Postby ToeFaceKiller » 2009.01.13 (21:00)
xaelar wrote:and took 38-3 by 0.450 ;D
Grrr...
Postby Nexx » 2009.01.13 (22:21)
