My computer is loading transparent update almost normally now and I can get to see highscores!
BUT...
It is loading highscores
VVVVVVVVVVVVVEEEEEEEEEEEEEEEEEEERRRRRRRRRRRRRRRRRRRYYYYYYYYYYYYYYYY SSSSSSSSSSSSLLLLLLLLLLLLLLLOOOOOOOOOOOOOOOOOOOWWWWWWWWWWWWLLLLLLLLLLLYYYYYYYYYYYY.
It takes a minute or so after I click on the episode number for the scores to load.
Slight improvement with n.infunity.com as well. The pages now load! But they also load
The homepage takes about half a minute, the ranking pages about one and the people's scores about one and a half to load... but I am STILL getting the problem that only 15-20 lines of scores load.
And, worst of all, after a few minutes and clicks of the "Refresh" button, Internet Explorer completely stalls and I have to close all windows and reload it. AAAAAAARGH!
- Oops Pow Surprise
Maybe I just am bad with Nreality, but I would appreciate some assistance with creating various new types of drones. Say, I want a Force Field Drone in my map. The list of mods from that Wiki page just gives me:
6^x,y,path,0,16,direction^detectRadius,forcePower,forceDelayTimer,forceMaxCount,forceMaxCountDelay,alwaysMove
Just for some clarification, do I replace x and y with a number to position it, and do I need to replace all the words with numbers too? I just don't understand. Any help would be appreciated, as apparently you guys know how it works, or at least Unreality does.
-----EDIT-----
Here's the link: http://forum.therealn.com/viewtopic.php?f=18&t=1046
- Sonnet
- NUMA Profile: http://nmaps.net/user/Rdy-kun
Good thing I don't see signatures.
- Beyond a Perfect Math Score
It's quite simple. Here's how the drone data works:MyCheezKilledYours wrote:So um,
#^OriginalDroneData^NRealityDroneData
So just place a chaingun wherever you want your forcefield drone to be, with whatever navigation you want your forcefield drone to have. Then look at the chaingun code and make sure those #'s fit this scheme:
Obviously that 16 will need to be put there since that's what makes it a forcefield drone. But "x", "y", "path", etc. are just labels so you know what the #'s correspond to. The point is to set them as you want and then make sure the 0 and the 16 are there.
THEN you add a new "^" at the end, followed by the required #'s. The article says:
Don't get confused. Right below that, the article goes through each thing and tells you what it's for and provides a default value for that field. You don't want to play with the forcefield drone's characteristics? That's just fine. In that case, replace each field name with its default value and you're done.
Remember to save the code if you want to playtest because the NReality code will go away if the map is played.
at least for me
<Meta> I'm meta?
( #n-highscores )
- NUMA Profile: http://nmaps.net/user/Empire
For everyone else: If your transparent update isn't working, can you load NUMA maps? And vice versa, for those who can't load NUMA maps, is your transparent update working?
I think I can help out those for whom transparent update loads but they can't load NUMA maps (as I'm also in that group occasionally). I've recently been paying attention to the way my NReality behaves and it's kind of strange. Here's what happens:
I open it up and just let it sit there until transparent update loads or not (it doesn't always load). Then I click "userlevels". If transparent update has loaded, the map # in the field is 136604 and NReality won't load any NUMA maps. If transparent update hasn't loaded, the map # in the field is 111791 and NUMA maps will load (though NReality maps will be messed up). Very strange. But you can get both to work by opening NReality and immediately going to the userlevels area, then waiting for transparent update to load (and restarting if it doesn't). Then both features will work.
Can anyone else corroborate this? It's absolutely possible it's just my computer - I have no idea what to think about it.
Consider your experience confirmed.Avarin wrote:@Skyflyer: No idea. Can't help you there.
Unreality's awesome mod
For me everything works perfectly. Anyone to confirm?darkshadow wrote:Consider your experience confirmed.Avarin wrote:@Skyflyer: No idea. Can't help you there.
by any chance, are HQX files openable by macs?Skyflyer wrote:No one knows a way to get Nreality for mac? I wanna try the blue_tetris column... People on N Troubleshooting said that I should try NReality (because N wasn't working then) and I had specified earlier that I had a mac... I hate using bootcamp so... Any ideas?
<Meta> I'm meta?
( #n-highscores )
Edit: Oh wait, I think you're right, I probably can open them.
- MBTI Type: ISFP
I open it up and just let it sit there until transparent update loads or not (it doesn't always load). Then I click "userlevels". If transparent update has loaded, the map # in the field is 136604 and NReality won't load any NUMA maps. If transparent update hasn't loaded, the map # in the field is 111791 and NUMA maps will load (though NReality maps; will be messed up). Very strange. But you can get both to work by opening NReality and immediately going to the userlevels area, then waiting for transparent update to load (and restarting if it doesn't). Then both features will work.
I happens to me too. But finally a solution to my problem ;P
I believe NReality saves your demos in the same .sol file that N v1.4 does. Did it not used to do that or something?Brainwasher wrote:so is nreality finally legal and using .sol? or do you still need to convert to .swf (illegal)?
- Sonnet
Yeah, when nreality first came out, there was a big debate because you had to convert your .sol file to a .swf file, which everyone said was illegal. Now that it doesn't need that, I'll have to get the download onto a CD (prevents frequent .sol corruption because of priority placement and .sol activity pull).Avarin wrote:I believe NReality saves your demos in the same .sol file that N v1.4 does. Did it not used to do that or something?Brainwasher wrote:so is nreality finally legal and using .sol? or do you still need to convert to .swf (illegal)?
I don't know if this is a one-off or whether the problem has been solved...
Could someone please fix this!?
Where's Unreality?
- NUMA Profile: http://nmaps.net/user/_underscore_
Tain't workin for me neither...999_Springs wrote:I don't know whether to post this here or in the "Is NReality not working?!?!?" thread, but I'm getting all those problems coming back again, with transparent update not working, and n.infunity.com either doesn't load or redirects to quotaless.com/404 "Acceptable Use Policy", a page which also doesn't load. (WHAT!!?!?!?)
Where's Unreality?
Credit to GTM for my amazing sig.
I emailed Unreality about it, so hopefully it'll be fixed soon. Until then, it sucks.
When will this be fixed? (Soon, in a while, far off?)
