Lil'n's N Mapmaking Tourney
NUMA Profile: http://nmaps.net/user/clarify
Postby lil'n » 2009.01.03 (20:49)
I have decided to make a tourney to challenge the best of mapmakers. Here's how it works.
Each competitor will be assigned with a number.
I will randomly choose a number from a box.
The numbers that are chosen back-to-back will be assigned to face each other.
Scoring:
Fun:?/10 points.
Aesthetics:?/10 points
Use of enemies:?/10 points
Overall:?/30 points
You can use anything in your maps for the contest.
You cannot use NReality by any means necessary
You must submit all maps to NUMA.
You can't use maps before 2009.
You must have a link to the map provided on this forum.
I will judge all maps.
I will PM the scores to the competitors, but the winners will be publicly announced.
Contestants
1:...
Enjoy!
EDIT:I have decided to let people use manual editing. And the tourney winner gets to be the new judge.
NUMA Profile: http://nmaps.net/user/tinkers7777
Postby tinkers7777 » 2009.01.03 (20:59)
Your tourney idea is quite frankly boring. Spice it up more.
Postby Rose » 2009.01.03 (21:32)
This is basically a cross between Neditor and Paradigm Shift, both of which I'm a part of already. If you can come up with something completely original, then I'll join.
Postby lil'n » 2009.01.04 (00:00)
maxson924 wrote:This is basically a cross between Neditor and Paradigm Shift, both of which I'm a part of already. If you can come up with something completely original, then I'll join.
It's kinda hard to make a comepletely original contest when so many contests are almost the same. I am trying to make a fun contest and I am trying to make this as original as possible.
Sig made by GTM. Thanks again!
:D
Postby lil'n » 2009.01.04 (14:40)
After a little consideration, I have decided to cancel this entire thing because I have found an idea that has never been done before.
:D
