How to easily transmit the newest 10 maps into userlevels
*First off, open this: http://nmaps.net/userlevels
*Triple click all data or click and press ctrl+A
*Right-click and select copy or press ctrl+C
*Open up your userlevels text file
*Scroll to the bottom
*Right-click and select paste, or press ctrl+V
*There you go! Save the file and open up N to play the last 10 maps easily!
Sidenotes:
*I do this every hour, I recommend you do too, as the hot maps page is constantly being updated.
*You can add alot more by using: http://nmaps.net/userlevels?count=50
*Try not to have more than 3/4000 at a time in your userlevels as it might crash your computer
Well there we go! The easy way to add many maps to userlevels!
Sidenotes:
The redesign of NUMA actually has a display limit of 45. 4000 and 9999999999 don't work.[quote="Evil_Sire"]Sidenotes:
*You can add alot more by using: http://nmaps.net/userlevels?count=9999999999
*Try not to have more than 3/4000 at a time as it might crash your computer[/quote]
- Oops Pow Surprise
You can still use user levels in NReality. Just copy the userlevels.txt from the original N folder to your NReality folder.
This is a pretty good idea, thanks (=
you know, you can do the same thing for users and tags as well.
(for self-advertisement purposes only)
http://nmaps.net/userlevels?count=50&st ... _alligator
Just add in your queries (&q=), tags come first. Author searches require %3A in place of the colon. The count and start info is there for you. &start= doesn't register sometimes when your &count= is at a fairly high number, and sometimes it doesn't register if you go straight to &start=150 or some other large number like that. You have to go in increments of 10 and get to 150 before you can actually get the 150 query.
The userlevels search function is just as touchy as the normal Nmaps.net search function, meaning title: searches don't work and there will be truncated results. Until that gets fixed this is what you have to live with.
