Nlympics [last update 11th of May, '09]
Moderator: zoasBE
Post your records here.
- Attachments
- NLympics.txt
- (52 KiB) Downloaded 536 times
- NUMA Profile: http://nmaps.net/user/nan__d_chaser
Well, that's why I need a new one.Nan__d_Chaser wrote:Well, it's just a survival with spammed enemies; doesn't look like olympics.
BTW I forgot to say that there are some changes from the last version that was on old forum.
I don't get the point of the archery
chimney jumping is fine, even if a little cheap.
Long Jump is far too unprecise for measuring
In the bouncing with a triple jump I could reach the other side without touching the ground
I really don't like the high jump, the flinging idea is very badly done and has nothing to do with jumping. all you needed was two walls to wall jump off, or even just one wall would have done fine. there is an optimum point about halfway through the jump which you will reach the highest point off. then just have z snapped one-ways to land on, instead of gold.
The hurdles are fine, but they should double back on themselves to get more variations in the scores. Otherwise, you'll get scores of about 240 frames and thats it. maybe have launchpads or mines instead of a ceiling
Thwump riding is perfect
Bounceblock Breaking is fine, even if its a little frustrating
Mines and hurdles. have one or the other, not both. Theres a lot of different things can be done with mines that are better than this. precision jumping for example.
the next two wallclimbing things are too short. everyone will eventually get the same number of frames.
Timed jumping has a limit of about 163 frames...
One-way jumping needs closer spaced mines, because it is possible to jump between them, and that will be the comp there, also, vary the vertical or horizontal distance between the platforms for a bit of difficulty. even craft it so there is more than one route up.
Free-fall is good. also has even a little thought into how it looks.
Pole-vault is too similar to the diagonal climb.
Perpendicular Frenzy is good
There are many touch-ups needed to be made, this feels very unfinished currently. I'll be glad to help
But
where's the reverse high jumping one? Where's the decathlon? Where's the race with a crazy and annoying tileset?
peking^
Point of archery:
When you step on 1 field distance with thwump, it goes away. When the twump gets in collision with the wall, see where the drone was (in which field). The field has number, that is a number of points. If the drone was between two fields, you add .5 to lower number.
Did you think about high jumping like this?
Onewall jumping will be fixed soon.
What is reversed jump?
Decathlon could be done by using teleporters, what do you think?
Can you fix the rest of those that you criticed? You said you'll be glad to help, so I'll be waiting for you to fix or make some.
I'll pm you some improvements
peking^
3-Point Shot. It's not great, but it's ok.
So I have added Riobe's map and onewall climbing is fixed.
peking^
Romaniac, I expected some maps from you, you said it will be done.
And please, send some records on NLympics record thread.
I added Survival: Delaying the inevitable. Made by formica. Such a great map...
P.S.
I am really sorry for triple(!) posting, but it's an update and it doesn't fits to be an edit. Beside that, it bumps the topic.
--EdoI has made me remove the map tag--
Shortest: Y
I'm glad that there's still someone interested for this, since I've always considered to be a good idea with poor feedback. Here's the deal:Neil_Bryan wrote:You know, EdoI, I will post an Nlympics too, for 2009! But there are some (no, a lot) of different things from the original Nlympics that have changed. Is it okay for you to let me post my made Nlympics 2009? Here's one of the maps:
This map pack is not periodic. Send me maps that you have made for the project. I will definitely (and be glad to) put it in the map pack here, you will be credited for everything you've made and I'll tell to squibbles to credit you in the All-in-one Map Pack/Author Catalog. I like the map you've made, and I'll put it here when you post me other stuff you've made. No need for creating another NLympics. You can PM me the maps.
Shortest: Y
Chimney climbing, Swimming, Running, Uphill Climbing (w/ Laser), Thwump Cannon Blasting and Heptathlon, all by Neil_Bryan, added. I removed two maps, Running (it had glitch) and High Jumping (it was simply awfull), both by me.
Shortest: Y
--EdoI made me remove the map tag--
Oh, I also found teraza's map in Numa "Welcome to the Olympics". Just asking: can you post his map too?
EDIT: map tag of teraza's map is removed
Shortest: Y
Neil_Bryan, I added your map for the needs of competition.
You jump above launchpads. Be careful not to hit them, or you'll be launched back to the starting point.
--Sorry, EdoI, if I post it here. If I post any more maps, I'll PM it next time.--
Oh yeah, I knew about the Running glitch where you get killed when you start.
Shortest: Y
