Post a Run!
Postby TheRealOne » 2008.12.17 (03:31)
darkshadow wrote:
ska wrote:
Avarin wrote: Hey, how'd you do that? I'm sure that move has been done somewhere by someone before (because they all have), but it's my first time seeing it, and I can't figure out how to duplicate it.
That's two innovations from darkshadow in a couple of days!
Actually as meta ing pointed out previously this was his innovation. Also, I'm pretty sure I've done two in a day previously (I have quite a few others lying around that I might do when I feel like it).
Yea Meta ing was the first to apply that trick to that map. But i believe Kryx came up with that trick during his hacking days. I think he found it out when he figured out that you can fall on to a door and get the key under so he just applied the same speed but upwards. I also made a map out of this trick before this innovation came out. 124971, But i had no idea it was possible in two chimnies.
Postby Izzy » 2008.12.18 (00:49)
I just took 67-3 higshcore 0th.
On legit mode. :/
Postby aids » 2008.12.18 (19:59)
92595
highscore AND speedrun.
Postby Nexx » 2008.12.19 (09:43)
Life247 wrote:148573
on N Reality.
Beaten. :)
Postby Izzy » 2008.12.19 (20:49)
77-1 speedrun. I just took 0th with an innovation.
Still improvable by about 5 frames I think.
NUMA Profile: http://nmaps.net/user/Infernus
Postby Infernus » 2008.12.19 (23:05)
Woah. That is crazy, Izzy.
My Maps | Highscores as Dan_K
<LittleViking> Don't expect more than second base on the Dumbo ride.
Postby Izzy » 2008.12.20 (01:23)
Just took 62-3 speedrun with an innovation.
Postby darkshadow » 2008.12.20 (03:04)
Just took 75-0. It can be improved a ton as I've gotten over 168 with missed gold.
Edit: xaelar, I think you're just going to have to give up on doing the single jump at the bottom left (I initially did the same method as you and got much the same score but decided it wasn't worth going for it). (yes I am hoping you'll pull it off that way since it looks so much cooler)
Unreality's awesome mod
Postby xaelar » 2008.12.20 (18:59)
03-0 (on first try today...) and 75-0 are mine. brilliant innovations dark, if only Lim would see them ;D
Postby darkshadow » 2008.12.20 (19:19)
I would love to see what he could do with these.
Postby ToeFaceKiller » 2008.12.21 (21:37)
I just redid 90-3 in legit mode just to see if I could still do it, and for anyone who STILL has any doubts about that level =p It's .05 slower than my current run, so I might try to improve it later.
I love that innovation on 75-0 dark (=
Postby darkshadow » 2008.12.21 (22:03)
Thanks TFK, are you going to try it out?
Postby ToeFaceKiller » 2008.12.21 (23:19)
I'm havin' a real hard time with that reverse corner jump. I'll try again later.
edit: Just improved 90-3 by a bit (=
Postby ska » 2008.12.22 (05:45)
7aMaDX took 2 0th's the other day O_o. Quite impressive for a player with only 21 highscores...
Postby Rikaninja » 2008.12.22 (05:56)
Nice ska, which runs were they?
Oh and I have my first 2 0ths. They are equal first with quite a few other people; 67-1 and 73-0!
Postby ska » 2008.12.22 (16:00)
Rikaninja wrote:Nice ska, which runs were they?
speed runs though ;)
List of 0th scores for 7aMaDX:
56-3 - 137.950
97-3 - 140.775
Total: 2 0th scores
Triforce
Postby lookatthis » 2008.12.22 (18:10)
impressive a complete route change for 97-3 and an innovation for a stage that I considered maxed out. And to top it all off he/she took an 0th from xaelar woohoo.
Postby behappyy » 2008.12.22 (22:28)
67-0
took 8th
also took 5th on 77-3
Image]THANK IZZ'
Postby aids » 2008.12.23 (07:03)
behappyy wrote:67-0
took 8th
I'm guessing you're johnny_faneca...
I'm working on 60-2 speedrun at the moment, currently 8th.
Postby behappyy » 2008.12.23 (13:31)
Life247 wrote:
behappyy wrote:67-0
took 8th
What? No I'm behappyy. I got 13th on 60-2.
Image]THANK IZZ'
Postby ska » 2008.12.23 (17:45)
behappyy wrote:
Life247 wrote:
behappyy wrote:67-0
took 8th
You probably should have said it was just a speed run initially to avoid confusion.
I'm now a solitary frame behind xaelar on 12-0, I'll try again tomorrow ;P wish me luck
PS. since when do you have to 'y's behappyy?
Postby aids » 2008.12.23 (20:06)
ska wrote:PS. since when do you have to 'y's behappyy?
since he started stuttering. :o
good luck.
Postby ToeFaceKiller » 2008.12.23 (21:02)
ska wrote:You probably should have said it was just a speed run initially to avoid confusion.
Yes, can everyone please do that from now on. For anything other than a highscore (i.e. speedrun or underclock) please specify in your post, thanks.
Postby behappyy » 2008.12.24 (12:52)
57-0 took 9th.
Image]THANK IZZ'
Postby Rikaninja » 2008.12.25 (07:37)
I got something like 10 more highscores then when I last posted :) Though rightning them down here is another story :::}
Users browsing this forum: Google [Bot] and 49 guests
