Postby Izzy » 2008.10.19 (23:24)
Do you have a neat route change that you can't pull off? Is that chain of corner jumps just too hard for you? Do you think that you can actually get that damn piece of gold without wasting 80 frames? Is slipping under that drone even possible? What about that thwump corner jump? Will it even help in the long run? Can I dodge that rocket and still get that switch? What if I do a triple jump instead? Why are you asking these questions? Do you think we know the answers? CAN YOU STOP NOW?
Welcome to the Post an Innovation thread, where either you're too impatient to do that run yourself, or you enjoy watching others succeed (otherwise it would be in Post a Run or the 0ths thread).
Post your innovations here and Eddy/van/notIzzy will steal them and get a 0th with them.
Postby claire » 2008.10.21 (20:50)
Sorry, I get it now.
Bacardi
Postby Meta Ing » 2008.10.21 (21:41)
claire wrote:I don't get it.
Can we tell you to make a map involving dancing bears and Chuck Norris as an uber boss?
... Or what?
No I don't think so...
He means, if you can see some way to get a quicker run on any level, but you aren't able to pull it off, describe what you are trying to do and someone will (at least try to) do it.
I'm pretty sure that's what he means anyway...
Quotes (Click to open):
Kablizzy: Click
TOO BAD!
Postby aids » 2008.10.21 (23:42)
example:
Meta_Ing, here's how I would route a no-switch-agd on "The Execution of the Clown." I can't for the life of me jump on the left between the mines, but you sure can!
jump down to the exit
jump between the 3-4 or 4-5 mines and land on the mouth
jump onto the 3 tile and reverse jump up to the nose
cornerjump up to the door above you and collect the gold
jump down to the mouth and onto the wall
finish by walljumping up to the exit switch and fall to complete
does that help? :)
PS: the picture messes up after collecting the gold, unless you can pull that off.
Bacardi
Postby Meta Ing » 2008.10.22 (00:22)
Hmm... It looks like a good route, although the only problem is that you need to slow down significantly in order to jump between the mines, so your wall jump is more vertical, and you barely get any extra momentum to make the corner jump any higher.
Thanks though.
Kablizzy: Click
TOO BAD!
Postby Hendor » 2008.10.22 (03:10)
Thought about this one a while back. Don't know if it's possible or not. Worth putting it out there. On a second look, I really don't think it's possible.
Postby aids » 2008.10.22 (05:05)
Hendor wrote:Thought about this one a while back. Don't know if it's possible or not. Worth putting it out there. On a second look, I really don't think it's possible.
you started in the middle of the level, so I'm confused.
Postby Izzy » 2008.10.22 (12:31)
Nice innovation Hendor.
I'll try it out later, but I'm pretty sure somebody will have done it already.
/me glances at xela
Postby aids » 2008.10.23 (03:07)
oooh, a cornerjump off the third from the right tile? nice find.
Postby ladeda » 2008.10.23 (22:19)
Uh, what about gameplay where you jump to different parts of a map on a preselected route, but you can only go on each route once? It'll be a real puzzle where you must find the proper path to all the gold and to victory without locking yourself into one of the parts!
"Tomorrow you will rule the world, but not today." -Miss Favro, my art teacher
Postby TribulatioN » 2008.10.24 (04:07)
Life247, I tried so many times, and I can't get it,
It's really hard, I got to the nose corner jump, but that's it, still nice route.
Postby ska » 2008.10.25 (15:07)
here's a classic conundrum - jump between the mines on 37-3!
With all the in-between mine jumping i have seen lately.. why not!?
Postby xaelar » 2008.10.25 (15:42)
ska wrote:here's a classic conundrum - jump between the mines on 37-3!
It's pretty easy why nobody has done it jet.
1) in-between mine jumps with mines laying on the ground are much much harder to do
2) it wouldn't be much faster
3) I don't like that level ;)
Postby Izzy » 2008.10.26 (15:36)
How about a moving thwump corner jump?
Postby Izzy » 2008.11.01 (22:15)
129-2 speedrun.
Look at my run at the beginning of the second chamber. Instead of holding the jump button, you can fall and go between the thwump and the wall. If done properly, it can cut off about 30-40 frames.
Postby darkshadow » 2008.12.05 (23:15)
Anyone want to use kryx's method for 03-0 speedrun in highscore mode. It should be a 0th.
Unreality's awesome mod
Bacardi
Postby Meta Ing » 2008.12.06 (01:30)
darkshadow wrote:Anyone want to use kryx's method for 03-0 speedrun in highscore mode. It should be a 0th.
Well it's my method technically... kryX just nearly perfected it.
But yeah, I think it's worth a shot.
Kablizzy: Click
TOO BAD!
Postby Izzy » 2008.12.08 (12:23)
92-2 speedrun.
My run involves triple jumping on the bounceblock, walljumping on the next one, and hitting the corner. I've been able to make it to the switch without hitting the corner by getting a perfect triple jump and walljumping at the perfect height.
I've only done this twice and hit the floor at 270 frames (DAMN WALLSLIDES).
MBTI Type: ESFJ
Postby jackass » 2008.12.08 (12:39)
you sure your talkin about the right level?
Check Again
[align=center]Image
Postby Izzy » 2008.12.08 (20:19)
It was 92-2. I haven't got the patience to try it again. Well, for now.
Postby rambo5252 » 2008.12.08 (21:14)
lol izzy whats a triple jump....i dont no how to do a good double jump
Thanks Toasters for the siggy
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
Postby rambo5252 » 2008.12.12 (21:18)
Ok i think i got a good one for 100-1
right at the beggiing fall down corner bounce(?) onto the platform wall jump then wall jump off the thwump coming down the wall jump between the to bounce pads
I could show you but i dont have the level data for that level =/
Other sigs
Postby Izzy » 2008.12.14 (21:19)
24-3 speedrun.
It is possible to, after the two walljumps on the right, to corner jump and then walljump the tile directly to the exit.
I can't pull it off again for some reason.
Postby darkshadow » 2008.12.18 (03:23)
I'm pretty sure my beginning for 62-2 is faster. My top-20 demo is a horrible example but I don't feel like putting together a good run with a clean beginning.
Postby Izzy » 2008.12.21 (19:28)
62-3 speedrun.
This run is very possible, I just don't have the patience to do it cleanly.
