Tags are being uncooperative
Moderators: Rose, Sunset
Postby bobaganuesh_2 » 2008.12.20 (21:05)
ever notice when submitting a map the tag boxes will appear right in the middle of the text box? And if you don't click in one at a certain time they will dissapear and renderyou unable to submit a map cuz you haven't filled in the vanished tabs? It's VERY annoying
Postby MattKestrel » 2008.12.20 (21:45)
God, that happens to me whenever I try and give a map just one tag. Very annoying.
Postby George » 2008.12.20 (22:36)
You might want to post that up on nmaps.uservoice.net.
Postby Rikaninja » 2008.12.21 (09:02)
That has only occured to me about twice. And that was with my first couple of maps. It doesn't happen to me anymore and I don't know why ;?
Postby bobaganuesh_2 » 2008.12.22 (02:15)
George wrote:You might want to post that up on nmaps.uservoice.net.
the url doesn't exist apparently. Or I am really inept.
Postby Nexx » 2008.12.22 (09:14)
bobaga_fett wrote:the url doesn't exist apparently. Or I am really inept.
It's nmaps.uservoice.com
Postby amomentlikethis » 2008.12.24 (00:34)
I've never had this problem.
Hi.
Postby Brainwasher » 2008.12.28 (21:12)
I had to get a new computer because of this: my old computer was too slow to agnowledge clicking inside the tags before they disappeared.
I still have that problem, but I can click the tags boxes now.
Atob and others thinks it is having n open, but unfortunately, it is not that easy.
Now back from life.
Postby EdoI » 2008.12.29 (20:42)
It happens to me when I'm using IE. When I'm using Opera, Firefox or Safari tags boxes are on their places.
Postby origami_alligator » 2008.12.29 (22:04)
EdoI wrote:It happens to me when I'm using IE. When I'm using Opera, Firefox or Safari tags boxes are on their places.
NUMA was designed to look good in all browsers, except IE wouldn't load everything correctly. That's why everything is aligned to the left in IE and in most other browsers it is centered.
My quick-fix solution would be to get a browser other than Internet Explorer.
Postby Brainwasher » 2008.12.29 (22:54)
and juno does it too
Now back from life.
NUMA Profile: http://nmaps.net/user/lookatthisisgoodatn
Postby lookatthisisgoodatn » 2009.01.05 (13:52)
Is N on? If so, close it after saving the data into a notepad first, should work.
