Does 2/6 Equal 1/3?
Only I will use a mathematician, physicist, and computer scientist varient... and it's not a joke:
The mathematition (yes): 2/6 = 1/3 just by reducing it. No mathematician would ever have you prove something like this that is trivially true, so it can be considered true without proving it since it has already been proven by the properties of division and mathematicians are lazy. We don't write what we don't have to. (At least I don't... usually... OK sometimes I do)
The physicist (no): although 2/6 does, in fact, equal 1/3, 2/6 probably implies that 6 things were measured, and 2 of them were some case, so 2/6 is more accurate than 1/3 is, therefore, mathematically equal, but not equivalent in usefulness. You would use significant figures and error bounds, not unreduced fractions, but oh well.
The computer scientist (depends on it's data type): If we allow 2/6 and 1/3 to be floating point (or some other number type), they are equal. If, however, we create an object consisting of 2 values: numerator and denominator, that the object representing 2/6 does not equal the object representing 1/3
The layman (inconclusive): I don't care. This topic is stupid.
Quad Erat Demonstrandem (yes, I know I didn't really prove anything. I just like saying that)
Mathematicly seen Yes
In real life seen No (depends on situation though)
I had an old shooter game where I had 100 kills and 5 Deaths. I think it's 100/5 and not 20/1. 100/5 is harder to get and different then 20/1
- Doublemember
he just trolled everyone in this thread that took this question seriously. How bored are you people?
But I didn't, no-one ever does, and I would, no-one ever will
Can't you see it's all flown out of my hands and our clothes are all too often ripped and our teeth are all too often gnashed and it lasts as long as it possibly can but I just don't accept this.
I just don't accept this at all.
Faces sweaty, arms and legs, what a glorious set of stairs we make.
We kill everyone with arrowheads, arrowheads, arrowheads. Thank god that's over.
I just trolled everyone for FIVE STRAIGHT PAGES WITHOUT SAYING A DAMN THING.Deathconciousness wrote:Kablizzy is a very clever troll
Did you troll everyone for 30/6 pages, or 15/3 pages?Kablizzy wrote:I just trolled everyone for FIVE STRAIGHT PAGES WITHOUT SAYING A DAMN THING.Deathconciousness wrote:Kablizzy is a very clever troll
The distinction is potentially important.
- Doublemember
let me be the one to give you a formal golf clapKablizzy wrote:I just trolled everyone for FIVE STRAIGHT PAGES WITHOUT SAYING A DAMN THING.Deathconciousness wrote:Kablizzy is a very clever troll
*clap*
- Doublemember
- NUMA Profile: http://nmaps.net/user/topolord
Wait, how did you make that backwards b?Kablizzy wrote:FIVE STRAIGHT PAGES WITHOUT SAYING A DAMN THING.
- MBTI Type: ISFP
There, I said it.
I don't know why I was thinking of this post today, but I'm curious to know:blue_tetris wrote:I'm going to opt for the Suki method of solving this problem.
Which fight do you figure is more fair: A fight of 1 against 3, or a fight of 2 against 6?
Clearly, 2 against 6 is fairer. A person alone can't size up a group of opponents as well as a couple; and three people act in concert well, while six people just tend to get in each other's way and one or two would have to sit out while the first few are getting fought off.
If the 2 people were split up to fight half of the 6 guys each, that would make the fight essentially 1 to 3, making it the unfair advantage to the 6.
So as long as you divide 2/6 in half then you get 1/3.
Only if the meaning you attach to the forward slash is "and" instead of mathematical division. In that case, you're saying "if you divide 2 and 6 by 2 each, you get 1 and 3" or "if you have two groups, one of 2 and the other of 6, and you divide each into two groups of the same size, then the first will become two groups of 1 and the second will become two groups of 3."Manus Australis wrote:I don't know why I was thinking of this post today, but I'm curious to know:
Either way, it's not mathematical division; you've redefined the meaning of that operator. Let's try to avoid this so we don't run into problems like, "if you have a rectangle whose height / width is 1/3, and you have another whose height and width is 2/6, then the second rectangle has four times the number of pennies as the first!"
]THANK IZZ'- Bayking
In what number system?
For example, this does not hold in the number system of integers modulo 4.
[2]/[6]
=> [2] * [6]^-1 where [a]^-1 refers to the multiplicative inverse of [a]
=> [2] * [2]^-1 (6 mod 4 = 2)
however, there is no mulitplicative inverse of 2, so you cannot express 2*(6^-1) as an integer in Z[4]
But let's try [1]/[3]
=> [1] * [3]^-1
=> [1] * [3] (the multiplicative inverse of 3 in Z[4] is 3. ([3]*[3]=[9]=[5]=[1]))
=> [3]
So there you have it. In this number system, 2/6 does not exist, and 1/3 is 3.
True, I'm not using the numbers 1/3 and 2/6, but rather the number represented by 2 divided by 6 and 1 divided by 3 where division is multiplication by the mulitplicative inverse (as division is in the normal number system. x * 3 = 1, therefore x = 1/3. Same operation, Different number system. Different result)
CORECT ANSER TO KALBIZZO'S QUESSION;Exüberance wrote:Correct Answer to Kablizzy's Question:
[2]/[6]
=> [1] * [3]^-1
=> [3]
FOR WHAT DEFNITION OF SIX???????? IF U HAVE 6 IS ACTUALY 2 THEN NO WAI
SO THEIR U HAVE TI 2/6 DOES NOT EXIST BECOSE 6 IS 2 BECUASE WE'VE FOR SOME REASON DECIDED THAT IT'S APPROPRIATE TO CONSIDER A SYSTEM WHERE 6 DOESN'T EXIST FOR A PROBLEM IN WHICH 6 IS EXPLICITLY IN THE PROBLEM STATEMENT
Kablizzy: "Does 2/6 equal 1/3?"
Exuberance: "I'm going to assume, for zero reason, that you're talking about colors. Neither of those is a color, so clearly the answer is 'non-applicable'. Praise me."
- Beyond a Perfect Math Score
And there are a lot of dumb posts in this thread. And some good ones. Thanks for telling me about Cantor's Diagonal Argument!
a=b
Add a to both sides.
2a=b+a
subtract 2b from both sides.
2a-2b=a-b
Factor out 2 from the left side.
2(a-b)=a-b
divide both sides by (a-b).
2=(a-b)/(a-b)
Simplify the fraction.
2=1?!?!?!?!?!?!?!?!?!!? AH!!!!!!!!!!!!!!!!!!
Let your head asplode.
And according to this since 2=1, 1/3=2/3 and 2/6=1/6, and we all know that 2/3 so does no equal 1/6, therefore 1/3 does not equal 2/6.
- The Rose in Spanish Harlem
Also, TheRealOne has an undefined step when he divides by a-b.
/joke.DemonzLunchBreak wrote:I hate this thread.
I was just adding more irrelevance to and irrelevant thread.
Try this one, then:DemonzLunchBreak wrote:I hate this thread.
let a and b be any real numbers
let t = a + b
t = a + b
(a - b) t = (a - b) (a + b)
at - bt = a^2 - b^2
a^2 - at = b^2 - bt
a^2 - at + (t/2)^2 = b^2 - bt + (t/2)^2
(a - t/2)^2 = (b - t/2)^2
Two paths from here, since taking a square root gives two answers...
Taking the negative square root:
a - t/2 = -(b - t/2)
a - t/2 = t/2 - b
a + b = t
...this merely confirms our given, meaning that we didn't do anything wrong in the previous steps.
Taking the positive square root:
a - t/2 = b - t/2
a = b
QED, given any real numbers a and b, a = b. Therefore, all numbers are actually all the same number, and are just different names for that one number.
Let's try this with, to make an especially meaningful case, a = 0 and b = 1:
let t = a + b, so t = 1
t = a + b ==> 1 = 0 + 1
(a - b) t = (a - b) (a + b) ==> (0 - 1) (1) = (0 - 1) (0 + 1); -1 = -1
at - bt = a^2 - b^2 ==> (0)(1) - (1)(1) = (0)^2 - (1)^2; -1 = -1
a^2 - at = b^2 - bt ==> (0)^2 - (0)(1) = (1)^2 - (1)(1); 0 = 0
a^2 - at + (t/2)^2 = b^2 - bt + (t/2)^2 ==> (0)^2 - (0)(1) + (1/2)^2 = (1)^2 - (1)(1) + (1/2)^2; 1/4 = 1/4
(a - t/2)^2 = (b - t/2)^2 ==> (0 - 1/2)^2 = (1 - 1/2)^2; 1/4 = 1/4
So y'see, we've made completely valid statements so far. Absolutely nothing wrong with them.
But just to be sure, let's take the negative square root to verify this:
0 - 1/2 = -(1 - 1/2) ==> -1/2 = -(1/2)
Yep, negative one-half certainly equals negative one-half.
So let's move on to what is usually considered the more relevant result of the square root (the principle square root, as it's called):
(0 - 1/2) = (1 - 1/2)
...add t/2 to both sides, as we did above:
0 = 1
Because every number can be expressed as itself times the multiplicative identity (1), and 1 actually equals 0, then this means that every number is actually 0 in disguise.
For the numbers relevant here:
6 = 6 * 1 = 6 * 0 = 0
3 = 3 * 1 = 3 * 0 = 0
2 = 2 * 1 = 2 * 0 = 0
1 = 1 * 1 = 1 * 0 = 0
So all of these numbers equal each other and should be freely interchangeable; we can substitute any of these numbers in for any other one of these numbers.
So 2/6 = 1/3 is the same as stating 6/1 = 1/3, which is clearly false.
(I, for the record, know what's wrong with the above. Anyone else? It isn't division by zero -- that's amateur crap.)
If he thinks that the last few pages have had anything at all to do with his actions, that's his delusion.Techno wrote:Haha. Kablizzy's still on the troll-mobile. Poor saps. :/
Foiled incorrectly. (a - b)(a +b) = a^2 - 2ab + b^2. (a - b)(a + b) != a^2 + b^2.t = a + b
at - bt = a^2 - b^2
a^2 - at = b^2 - bt
a - t/2 = t/2 - b
a + b = t
a - t/2 = b - t/2
a = b
- Demon Fisherman
(a - b)(a + b) = a^2 - 2ab + b^2. is wrong.
(a - b)(a + b) = a^2 - ab + ab - b^2 = a^2 - b^2.
What do I know, though. I'm a businessman.
Please tell me where you got -2ab, though. Because I see a * b and then I see -b * a. And none of that adds to -2ab.
The Real N Sex on the Xerox Space Pimp Online Super Fluffy Pack 1! Super Fluffy Pack 2! Super Crunchy Pack! Mother Thumping Impossible: 2005 MotY! Time is on My Side: 2006 PMotY! Survival map king! Best humor award! Best satire award! Best voice award! Inadvertently intimidating! Assholier than thou! Gdubs is totally back! WIS 14! Cyberzone creator! Clique creator! Most lines on IRC! Ventrilo moderator and regular! Certified Dungeon Master! Most modest person ever! ENTP! Incorrigible alcoholic! CHA 19! AMERICAN! Least pretentious! Elitist extraordinaire! Liberal libertarian! Incapable of experiencing love! Check Safe! Commodore of the Eldritch Seas! Archmagus of the Eleventh Hall! Sheriff of the Uncharted West! Godfather of the IRC Mafia! Pun enthusiast! Quadster! Challenging Dunbar's number! Wikipedian!Approves of 4th Edition! 1,000 Blank White Cards! radio_free_tetris! Migratory! INT 18! Doesn't know when he's being genuine, therefore cannot form lasting relationships with people! Really into black chicks! Even more into Indian chicks and Blasians! Hates moderators! Loves the C word! Tronster! Thinks we should play more Worms! Always wins iSketch! Owns a Wii! Plays as Pikachu in Smash Bros! Wrote literotica! Wrote anime fanfic! Sorta into Asians! Lived and loved the 80's and 90's! Chattiest sig! Cyberzone ][ creator! Operand of the Greater Space Pimp Continuum! Helped lead the forum move!Wizard Date! Participated in the blue_tetris takeover! Pithiest one-liners! Walkin' on, walkin' on broken glass! Seems to have an invisible touch! Economist! Mario hackster! Owner of the most complex D&D campaign setting! Micromanagerial! FREEDOM is all-American! Slowly distancing! Supports the Democrats! Supports the old GOP! CATO Institute fanboy! Penn and Teller fan! Large, in charge, and on a barge! Heralded by community as genius hero! Proud yet humble recipient of the Mare & Raigan Award for 2008! CON 9! Dave of Nazareth! Communist is annoyed with me! Not half bad at images! F.Y.I. I am a medic! It's a spook house, lame ball. Too bad! Space Pimp II: Rags 2 Bitches! F.Y.I. I am a spy! Entire team is babbies! STR 10! Sorta appreciating scythe and atob again, for new reasons! Played CS:S briefly! Welcome to Nebraska! Do you think you can Live! Heist! Portrayer of the mighty 88 Shells! Joyous proprietor of the future estate of Kablizzy and blue_tetris! It's Batmen all the way up! They brought crystals to a sceince fight; that's a good way to lose your cat! Even SlappyMcGee! I'm about to run out of either primates or sexually transmitted diseases! One-upper! Toaster oven clairvoyant Mythomaniac! That's the Magic of Macy's! Half of Half! Spend all my time making love, all my love making time!
