Post a Run!
Postby golf » 2008.11.21 (14:34)
Took several 0ths on low NUMA maps: 4, 8, 10, 18, and 37.
Postby Nexx » 2008.11.21 (21:43)
I can't beat Etz's AGD run on this map, but I'd like to see someone else take a crack at it: 119555
His run isn't on NReality, he just posted it in a comment. It's 1233 frames.
Postby TheRealOne » 2008.11.21 (22:10)
golfkid wrote:Took several 0ths on low NUMA maps: 4, 8, 10, 18, and 37.
Took the 0th on #4 highscore and speedrun, but they are pretty bad runs though so they wont stand long.
Postby ToeFaceKiller » 2008.11.22 (00:01)
Avarin wrote:I can't beat Etz's AGD run on this map, but I'd like to see someone else take a crack at it: 119555
Donee with 1207 :)
Postby Izzy » 2008.11.22 (02:30)
Donee with 1207 :)
Beaten with a crappy 1203.
Bacardi
Postby Meta Ing » 2008.11.22 (15:15)
Took 115002 (highscores) back from xaelar. Less 'between-the-mines' walljumps, more corner jumps.
Edit: Faster. Still going for faster.
Also, took 119555 with a 1139 frame AGD.
Quotes (Click to open):
Kablizzy: Click
TOO BAD!
Postby ToeFaceKiller » 2008.11.22 (21:12)
Amazing 115002 Meta Ing, seriously. Took 119555 by a few frames, so very improvable still.
edit: 1105 frames
Postby xaelar » 2008.11.24 (12:53)
Meta Ing wrote:Took 115002 (highscores) back from xaelar. Less 'between-the-mines' walljumps, more corner jumps.
Beeeeeeeeaten
Postby golf » 2008.11.24 (19:25)
Retook 4. That was a good run by TheRealOne, but I ended up with what I think is a lucky bounce at the exit switch.
Postby darkshadow » 2008.11.25 (21:28)
Although it's far from maxed I still like the route on my 5832 speedrun.
Unreality's awesome mod
Bacardi
Postby Meta Ing » 2008.11.27 (22:22)
03-0 speedrun. New method, and still improvable.
Also, (although I'm not posting this one for speed), does anyone notice anything slightly unusual about one of the bounceblock double jumps in this demo?
Paste that into the replay box in userlevels.
Kablizzy: Click
TOO BAD!
Postby golf » 2008.11.28 (04:09)
I think what happened was your second jump ended up being a either corner jump or a wall-jump off the block there. Worked out really nice for you, but I bet you would find it hard to redo consistently.
Bacardi
Postby Meta Ing » 2008.11.28 (05:31)
I think you're right, golfkid. I'm pretty sure it was a corner jump.
I don't think I'll ever be pulling that off again.
Kablizzy: Click
TOO BAD!
Postby eru_bahagon » 2008.11.28 (10:55)
I think this thread should help : http://metanet.2.forumer.com/index.php? ... 19200&st=0&
See first post, and first "replay" (txt line) of zapkt.
Postby Izzy » 2008.11.28 (12:17)
Meta Ing wrote:03-0 speedrun. New method, and still improvable.
I actually did that multiple times (consistently) while working on this demo:
And strangely, I know I've done a bounceblock CJ going up (double and from a normal jump) , but died.
Postby Nexx » 2008.11.30 (08:51)
Postby xaelar » 2008.11.30 (13:36)
beaten
Postby ska » 2008.12.01 (01:44)
xaelar wrote:beaten
beaten
Postby xaelar » 2008.12.01 (13:31)
ska wrote:
xaelar wrote:beaten
beaten
Alert! fast demo Alert! fast demo Alert!
beaten
Postby ska » 2008.12.02 (09:10)
xaelar wrote:
ska wrote:
xaelar wrote:beaten
beaten
beaten
BEATEN!
just kidding
Postby Nexx » 2008.12.03 (19:02)
Next challenge: 147529 (author:29403)
Can any of you beat the second zap drone when getting an AGD? You'd have to be quite fast, methinks.
Postby xaelar » 2008.12.03 (21:24)
I did what I could.
NUMA Profile: http://nmaps.net/user/Infernus
Postby Infernus » 2008.12.04 (01:08)
Check out my bounce-block corner jump on 147802.
^_^
My Maps | Highscores as Dan_K
<LittleViking> Don't expect more than second base on the Dumbo ride.
Postby Izzy » 2008.12.04 (01:36)
Faster, without the Bounceblock cj.
I see a faster route that involves a different cj that I have pulled off many times.
Postby Infernus » 2008.12.04 (01:46)
Nice, Izzy.
I've done the first bounce-block corner many times but the gauss always gets me. I suppose you could do one of those fancy double jumps with the second jump off of the side on the last bounce-block to get around the mine and land closer to the door. Is that what you were thinking?
