enemies
Postby Slayr » 2008.11.18 (01:08)
i hav seen some ppl make enemy drones stay still and i would like 2 know how they did it.
and here is a random lvl i made
NUMA Profile: http://nmaps.net/user/hoohah2x2sday
Postby Hoohah2x2sday » 2008.11.18 (01:17)
if i understand what ur asking, then u want to no how to make a drone stay in the same spot as u put in in the eidtor right?
well, place the drone where u want it, and then immediately go to the textbox (level data). The drone should be the last group of text in the box. Simply add "nan" to the end of the code, and then load the level again. when u play it, the drone shoud stay still.
I hope this helped =]
[spoiler=Friend Codes][/color]Wii: 8621-9472-7857-7226
CoD WaW: 1633-8997-2496
SSBB: 2835-9815-6521
Guitar Hero 3: 3909-8090-0912
Guitar Hero World Tour: 1204-2586-5555
Guitar Hero Metallica: 4125-1367-1917
Message me if you add me so I can add you![/spoiler]
Wizard Dentist
Postby SkyPanda » 2008.11.18 (05:25)
An alternative method is to place locked doors around the drone you want immobilised.
Like so:
But Hoohah2x2sday's method is probably the best to use.
Postby TribulatioN » 2008.11.18 (05:47)
SkyPanda wrote:An alternative method is to place locked doors around the drone you want immobilised.
Like so:
That works, but it's not really aesthetically pleasing.
And make sure you put it in the right place, you don't wanna make a ghost drone..
Wizard Dentist
Postby SkyPanda » 2008.11.18 (05:51)
TribulatioN wrote:but it's not really aesthetically pleasing.
Personally, I think it looks fine, the only problem with that method is that it uses a large amount of objects, which is why code-editing is probably a better method.
Postby a happy song » 2008.11.18 (05:53)
You really think it looks ok? Hmm.
Regardless, the use of doors to keep a drone stationary is entirely redundant when you can just edit the code in the same amount of time. there's no need for at all unless you don't know the code edit.
Wizard Dentist
Postby SkyPanda » 2008.11.18 (06:32)
atob wrote:You really think it looks ok? Hmm.
Yep. Like a little drone-in-a-box :)
Postby Rikaninja » 2008.11.18 (10:24)
This is a code for a chingun drone:
6^588,516,3,0,2,2
Change the 3 to a 9. This will make the drone still.
6^588,516,9,0,2,2
But of course the numbers may be different but there will be the same amount of number so you have to change the 3rd number to a 9. There are other ways to do this.
MBTI Type: ESFJ
Postby jackass » 2008.11.18 (11:20)
basically just muck up the 3rd number so it becomes a NaN ... thats what makes it still
[align=center]Image
Postby Hoohah2x2sday » 2008.11.18 (11:59)
u dont even have to worry about changing numbers, adding anything to the end of the code will nan it anyway. i prefer to just type nan =P
