Logik 2 - "The Waiting"
Moderator: zoasBE
Postby unoriginal name » 2008.11.16 (21:23)
It's finally here, what you all used to be waiting for. Logik 2, limping to the finish.
I had nothing to do with arrangement of these levels, which are ALL the levels received. In some agreement I was unaware of, the managers promised to put every level received in the pack. While I did not know this, I still apologize for all of the bad levels within, some of which I must admit are mine.
Does it look like I'm distancing myself from this badly managed wreck? Well, I am. I don't like how this ended up, at all. Blame any technical errors on behappyy. . . . Yeah, whatever, just play it. Sigh.
EDIT: behappyy has fixed the errors.
Logik 2-The Waiting.txt
(81.83 KiB) Downloaded 572 times
Postby Pikman » 2008.11.16 (21:40)
Just to point out a few things -
1. There is no map 9-1.
2. Whichever map is supposed to be 4-1 is not labeled.
3. There are some weird squares in between levels.
4. You spelled "waiting" incorrectly in the topic title.
5. The me/gloomp collabs were not included. :(
Postby notsteve » 2008.11.16 (22:01)
pikman, you weren't in the pack, we never received that level...
on the other side, don't blame gloomp or behappyy for anything, it was mostly just due to several technical difficulties....techno abondoning us, no one having time to put the thing together, bad overall organization, me deleting the files when they were finally done...
Postby behappyy » 2008.11.16 (22:22)
Yay it's finally out. I fix the few problems and I also asked animator if he could make sig tags for the people who contributed.
Bellow is the fixed version. Gloomp will update it later.
(81.83 KiB) Downloaded 516 times
Image]THANK IZZ'
Postby Evil_Sire » 2008.11.16 (22:44)
I'd give it a 3/5. Why? Because there were some really bad levels in there, some of it felt like the map creators were trying way too hard to be PALEMOON. And most of it was unpolished stuff.
But saying that, some of it was really awesome, and I enjoyed most of the pack. Kudos!
EDIT: Downloaded gloomp's
Postby TribulatioN » 2008.11.16 (22:46)
Evil_Sire wrote:I'd give it a 3/5. Why? Because there were some really bad levels in there, some of it felt like the map creators were trying way too hard to be PALEMOON. And most of it was unpolished stuff.
what a contradiction.
Well I found the map to be quite fun, bad maps set aside.
Postby handofgod » 2008.11.16 (23:13)
wow we totally blew all of our hard work
EDIT: this is also old, my style has changed a ton since then.
Postby Pikman » 2008.11.17 (01:24)
notsteve wrote:pikman, you weren't in the pack, we never received that level...
It was posted on pastebin as gloomp/kisler, and I thought gloomp PMed it to whoever was in charge at the time (Condog?)
Wizard Dentist
Postby SkyPanda » 2008.11.17 (08:55)
I have no idea what this is, and it sounds like you guys are still trying to sort it all out, but i'd just like to throw in that I really liked the design in "8-4 Aloof Zepher" (Apart from the random drone train). :p
Postby unoriginal name » 2008.11.17 (16:56)
SkyPanda wrote:I have no idea what this is, and it sounds like you guys are still trying to sort it all out, but i'd just like to throw in that I really liked the design in "8-4 Aloof Zepher" (Apart from the random drone train). :p
Thanks. <3
Postby golf » 2008.11.17 (19:21)
Since you didn't realize that there was a promise made that all the maps were going to be included, maybe you could release a "Director's Cut" or something similar that gets rid of the bad maps, and makes a higher quality pack overall. As a contributing mapper, I would completely understand if some (or all) of my maps got sacked in this Director's Cut because they didn't make the grade. This way, you still have the original promise of all maps in the pack, and you have a high-quality pack that is minus the worse maps.
Postby handofgod » 2008.11.17 (22:57)
golfkid wrote:Since you didn't realize that there was a promise made that all the maps were going to be included, maybe you could release a "Director's Cut" or something similar that gets rid of the bad maps, and makes a higher quality pack overall. As a contributing mapper, I would completely understand if some (or all) of my maps got sacked in this Director's Cut because they didn't make the grade. This way, you still have the original promise of all maps in the pack, and you have a high-quality pack that is minus the worse maps.
ooooooo snazzy. I like.
Postby notsteve » 2008.11.17 (23:22)
yes, but too much work
if there is a next one, it will have hand selected mappers so we wont run into this problem
Postby unoriginal name » 2008.11.18 (00:55)
notsteve wrote:yes, but too much work
No, not too much work. I'm totally doing it. Awesome idea golfkid.
Or I'm probably doing it. I'm an awful procrastinator, so I'm not giving a release date until I'm done, if then.
Postby TribulatioN » 2008.11.18 (02:28)
After 90+ minutes of playing this pack, I've decided, that 9-3: Rockets Three, is my favourite.
It's taken up 30 of those 90 minutes. And all 30 minutes were enjoyed.
Can't Touch This
Postby BNW » 2008.11.18 (03:03)
Once you get past episode 1, it starts to get better, but then you seriously doubt the integrity of this pack when there are simple and easy maps stacked between epic and terribly hard maps.
Could have been better, but I completely understand what happened.
3.5/5
Sigs!
Wizard Dentist
Postby SkyPanda » 2008.11.18 (05:18)
gloomp wrote:Thanks. <3
Hahaha I guessed it was yours ;)
Postby Riobe » 2008.11.18 (07:28)
Some were ok, and some were fantastic (0-4 blew my mind). Still, Overall good pack.
Postby notsteve » 2008.11.18 (23:25)
TribulatioN wrote:After 90+ minutes of playing this pack, I've decided, that 9-3: Rockets Three, is my favourite.
heh thanks :D
i was debating over submitting that one actually..
NUMA Profile: http://nmaps.net/user/mahi_mahi
Postby Mustardude » 2008.11.19 (04:22)
Some levels were too metanetish!
Good though!
Check out the pack thread, click the picture above
wordblamcreator wrote:mahi_mahi has the french flag up! He must be surrendering...
mahi_mahi wrote:It's the Russian flag.
Postby Condog » 2008.11.19 (04:38)
Mustardude wrote:Some levels were too metanetish!
Good though!
O_o How can a level be too metanetish? You can never have enough Metanet!
If we do this directors cut, i could help out more than i did originally. If someone else trimmed the pack down, i'd be happy to sort out a nice order for them.
Postby TribulatioN » 2008.11.19 (05:05)
heh thanks :D
Well I'm glad you did!
Edit: Oh yeah, I found the metanetism to be quite interesting, and rather fun.
Postby unoriginal name » 2008.11.19 (18:11)
Condog wrote: If we do this directors cut, i could help out more than i did originally. If someone else trimmed the pack down, i'd be happy to sort out a nice order for them.
Sure, we'd love you on board. When we pick everything, we'll send the levels your way.
Postby golf » 2008.11.24 (17:58)
Since there's really no place else to put this, here's an AGD run I got of 2-4: Circulosis Syndrome.
Can anybody beat this?
Postby Why Me » 2008.11.24 (18:08)
golfkid wrote:Since there's really no place else to put this, here's an AGD run I got of 2-4: Circulosis Syndrome.
There. It's not that hard. Non-FBF'd, too.
Users browsing this forum: Google [Bot] and 17 guests
