Tool-Assisted Highscores/Speedruns
- Doublemember
It might sound simple, but I wouldn't be surprised if programming such a function was much harder than it sounds.zapkt wrote:Hmm this is interesting. We should see with Unreality, who has a lot of experience with modifying the game, if it would be possible to add a function in NReality (or a modified version of N dedicated to producing MBD runs) were you could automatically compute some stuff. For instance, having a button which would automatically produce the different possible runs for the next frame, and test which one lead to death, would be an interesting first step.
and then for every new N scoring contest ppl will run the AI once to figure the best route.
then the map creator will start to adapt to it and specifically make a human-almost-impossible route for the shortest path to nullify the best route calculated.
- Doublemember
If I happen to do something, I guess it would first find micro-optimizations at best.
- Doublemember
If I had to list a starting point (just for completion's sake), I would make each attempt that guides the ninja closest to the exit be the one that you branch from (which is essentially a form of virtual natural selection/evolution). However, you'd need to have a more in-depth approach than this. Ideally, you'd prune attempts where the ninja doesn't have a direct line of sight with the exit, otherwise you might get situations where the AI hopelessly gets stuck in a loop that results in constant dead ends. Also, maybe some kind of subroutine might be a good idea; for example, have a series of waypoints once a computer has determined that a certain section of the route has been optimised; this could also save on time/computation power.
The only thing I haven't tried yet is to invoke some null frames (or even pullback frames) somewhere before the launchpad. I have no idea if this would work, but it seemed to do the trick for 5-2. Raif clearly has some real-time experience on this level, and I've wondered for years why he never made an MDB. This level looks simple, but an optimized MBD/FBF of this level seems very tough. I'd also love to see Eddy, TRO, or anyone else have a crack it.
Complete 39-3 MBD which I've apparently never posted here before (probably because the route is slower)
Here's the faster (normal) route which was never completed
I also found this pointlessly cool looking jump
A bunch of NUMA maps which I've MBDed for reasons which are currently unknown to me.
Another incomplete demo which is about halfway done
Turn on grid and compare
00-1 sr (302f, 1f faster than Eddy (MBD), 3f faster than Kool)
00-3 sr (328f, 3f faster than Eddy (MBD), 5f faster than van)
91-4 hs (277.850, 4.875 faster than macrohenry)
I also tried 00-2 sr but I was only able to tie Eddy's MBD on that one.
Edit: Also did 82-2 because I saw it mentioned in the HS thread
82-2 hs/sr (142.175 / 473f, 0.025 / 1f faster than van/Eddy/macro)
83-4 Highscore (127.975, 4.475 faster than Eddy)
Shaved .8 seconds off my 36-2 mbd using an innov someone somewhere must have surely considered before. Guess I'm just talking to myself here at this point though. Kinda sad to see the community so dead.
I watched every run. I, personally, particularly enjoyed 91-4 and 83-4. Both of them were totally insane, especially the luck manipulation in 91-4. Thanks so much for your contributions, and I hope others will get to enjoy them as well. Cheers! :)Guess I'm just talking to myself here at this point though. Kinda sad to see the community so dead.
Wth are you talking about, this place is booming with activity.Raif wrote:Shaved .8 seconds off my 36-2 mbd using an innov someone somewhere must have surely considered before. Guess I'm just talking to myself here at this point though. Kinda sad to see the community so dead.
I kind of cannot even watch the demos :( I fired up my old Windows XP laptop, but N runs at like 1/4 speed and I'm too lazy to fix that. No other options :(
@van: Have you tried right click -> quality -> low? It looks like shit, but generally it makes N run better. I also find that old versions of NReality (v6d4 and v6g2) lag less than the most recent.
Also got a new MBD, 19-4 with my own route:
19-4 Highscore (192.600, 4.400 faster than Eddy)
P.S. Is there any replacement for #n-highscores with the recent death of irc.mountai.net? Well, it's not like anyone talked there for months anyway...
I don't know of any IRC replacements, unfortunately. In any case, that 192.600 run was pretty mind-bending. I expected some corner jumps, and I was not disappointed!Raif wrote:@ska: Thanks.
Another one, 92-1. Gold through one way innov by Fdan on underclock. I was initially planning on jumping out of the tunnel and getting the laser to fire into the upper wall (thereby avoiding the need to to wait for it on the way back), but it doesn't seem to be possible to manipulate the laser that way. The bb corner double is something TRO came up with when we were discussing this map years ago.
92-1 Highscore (161.250, 2.000 faster than macro)
96-4 Highscore (140.575, 6.425 faster than Eddy)
If my mind was bent before, it's now mush. That run was incredibly constructed. I think everyone will agree that the collection of the exit switch was sexy af.Raif wrote:Something I've been meaning to do for a while.
The format of the file is shown in this image: https://i.imgur.com/kLJXMJL.png
The above image is from an MBD of SL-A-03-03 I made yesterday (frame count: 290, score: 103.167, 3 frames faster than the 0th). File: https://cdn.discordapp.com/attachments/ ... 27028/1278
To watch place in "C:\Users\[user]\Documents\Metanet\N++\attract" and move all the other files in the folder elsewhere temporarily. Restart N++ if already running. Upon starting N++ the MBD will loop in the menu screen.
There is no frame count or score bar so one of the challenges of making a MBD this way is figuring out when it ends. You can figure this out by checking the last frame you can suicide (0C) before entering the exit. This will be the final frame of the demo.
Another challenge is that the frame counts and file sizes need to be kept updated and accurate (otherwise the demo won't work). One way around this is to start with a long enough demo so that you won't need to alter the length of the file/demo until it's finished.
One of the quirks of N++ is that you can press jump up to 3(?) frames before you hit a surface and still jump. However, this doesn't mean that the ninja will jump on this frame, it will still jump on the frame it hits the surface, so you need to account for that when MBDing in some cases (i.e. if you are making a frame perfect wall climb). This can also make it difficult to MBD stuff like 1-tile triples because you have no idea if the actions of the ninja match your inputs.
It's also possible to retrieve a demo from the server and do a sort of demo analysis.
First get the top 20 list from https://dojo.nplusplus.ninja/prod/steam ... l_id]&qt=0
replacing [steam_id] with your steam id (found on the url to your steam profile) and [level_id] with the level id of the desired level. The steam_id used needs to have been used with N++ recently. If you last used N++ hours ago it won't work.
For example for SL-A-03-03 (Level ID: 1278) this output is recieved: https://i.imgur.com/P6w4yZm.png
To look up a replay you'll need the replay ID from the top 20 list. For example the replay ID for Nightwish's demo on SL-A-03-03 is 1742854. It can be retrieved from https://dojo.nplusplus.ninja/prod/steam ... 42854&qt=0
The following data is received: https://i.imgur.com/ZcwIini.png
After decompressing the compressed data you get this which is already somewhat readable if you are looking to analyze someone's demo: https://i.imgur.com/qh0X2uf.png
I'm not sure if I'll be making more MBDs for N++ because quite honestly it's a pain in the ass compared to 1.4, due to lack of stuff like FBF, display state and frame count. And obviously the lack of easily editable demo data.
