Tricks
Moderator: EddyMataGallos
Pure
Postby fx64 » 2016.06.18 (21:02)
i want to do that tricks (http://n.wikia.com/wiki/Tricks) but i could not. can anyone explain how to do them. when u jump, how u jump etc.
Postby EddyMataGallos » 2016.06.18 (21:37)
Tile tricks (like corner jumps) aren't possible in N 2.0, only in N 1.4, sadly. As for thwump and bounce block tricks, they are doable, the only real advice I can give you is to practise by jumping onto the corners of bounce blocks and thwumps and trying to jump, when you get it, try to repeat it by mimicking what worked previously. You'll get a feeling of how it works with time. I suggest practicing on test levels or levels where the situation can be approached easily, like 90-0 (in v1.4) for bounce block corner kicks, for instance.
Believe me there's no magic trick, the only way to learn is to practice with different situations heavily and get used to the feeling. As a general rule for bounce block double/triple top/side jumps though, is that you should train your timing correctly, that's the key concept, it's definitely not just mashing the key 2/3 times as quick as possible, that doesn't work, just like it doesn't work for triple tile jumps (which are possible in 2.0 as well, but a little harder than in 1.4).
NUMA Profile: http://nmaps.net/user/SpartaX18
Postby SpartaX18 » 2016.06.19 (13:32)
Well, tile corner jumps are somewhat present in 2.0, however, not in the known by 1.4 players form. It's impossible to get as big of a boost as in 1.4, but the tcj's are doable if executed at the right speed and angle.
Postby EddyMataGallos » 2016.06.19 (14:15)
Well yeah, but that's basically a normal jump except executed from a corner, not what is explained in http://n.wikia.com/wiki/Tricks
Pure
Postby fx64 » 2016.06.19 (18:26)
i tried corner jumps and corner kicks on test levels but i could not do them.
at least, i could do the other tricks .
i will continue to try.
NUMA Profile: http://nmaps.net/user/XandoToaster
Steam: www.steamcommunity.com/id/XandoToaster
Postby XandoToaster » 2016.06.20 (03:13)
For what it's worth, cooperverdon has made a lot of test levels over the years which are good for practicing on. If you search "cjcv" then you can find some for practicing the bounce-block jumps. They are hard to time though. You'll notice on map 120918, I was only able to get 2 of the jumps in a row, and that was after an hour of just playing that level. Once you do the jump once, it gets easier to time after that, because you have a better idea of how to time it, but it never really gets easy. I don't know that anyone can do them consistently.
Today is just a really good day, ya know?
2nd place in Npoints Season 3
Nv2 Column Run King
Pure
Postby fx64 » 2016.06.24 (08:35)
i could not do "one block jump"
is it timing or what?
are you pushing the jump button two times?
jump middle of the block and jump?
i will be happy if anyone explains the trick.
Postby SpartaX18 » 2016.06.24 (11:17)
One block jump? Do you mean a pop? That is, a frame-perfect stationary wall jump (like in 02-4)?
Pure
Postby fx64 » 2016.06.24 (16:09)
SpartaX18 wrote:One block jump? Do you mean a pop? That is, a frame-perfect stationary wall jump (like in 02-4)?
yes. to do it you must be very fast i think.
Postby EddyMataGallos » 2016.06.25 (15:36)
If you mean walljumping on a wall that is only one block high, yes, there is no timing there, it's just hitting jump twice very fast :P It's not that fast though, with some practise you'll get the hang of it.
Postby SpartaX18 » 2016.06.26 (16:12)
Well, timing is always needed. In this case, you have to time the landing for example. But i know, that's very far-fetched to say.
It's really easy to do with pausing, but i'm absolutely not encouraging to do it this way (may cause severe conscience issues).
