Great job! You make kool's run look downright sloppy by comparison...macrohenry wrote:Beat the drone in 04-4 for a lead of almost 100 frames.
Yeah that start is awesome. The drone dodge makes for great theatrics as well. Great run Macro.ska wrote:Great job! You make kool's run look downright sloppy by comparison...macrohenry wrote:Beat the drone in 04-4 for a lead of almost 100 frames.
EDIT: Also took 91-2 with a sweet (imo) innov.
Is there really no thwump trickery on 41-0 with the speedrun route? Regardless, nice runs. Good to see some activity, even if it's only speedrun.EddyMataGallos wrote:A bit of activity in the sr territory product of a boring afternoon: 41-0, 43-0, 55-1 and 67-4.
You can get horizontal propulsion if you jump a bit less and hit one of the bottom thwumps, but it doesn't save anything. I don't think you can get downwards propulsion which is what would actually help.ska wrote:Is there really no thwump trickery on 41-0 with the speedrun route? Regardless, nice runs.EddyMataGallos wrote:A bit of activity in the sr territory product of a boring afternoon: 41-0, 43-0, 55-1 and 67-4.
Woah woah let's hope Kool doesn't read this brah.ska wrote:Good to see some activity, even if it's only speedrun.
Also, I'd like to discuss this:
Whoever wrote this, where did you get the number 2-5 frames? I did a few quick fbf tests in ned and I'm completely convinced that most if not all cornerjumps with more than a little speed are frame perfect. Does anyone have any more throroughly tested information on this? I'd like to know for sure.
First of all: big ups for finally providing a truly polished run on 91-2.MiBeM wrote:Took ep 91 and improved my 91-2 0th a little on the way. Got a bit impatient with the last 2 levels and didn't clean them properly but posting here just because it's so quiet.
Secondly: I do actually recall reading that in the Wiki ages ago (and being perplexed by the wording). I didn't contest it, though, since I figured the author meant hitting it on a sharp incline.
By that I mean something like this userlevels demo that I just threw together:
Note that FBF doesn't work on my computer (due to my computer not accepting simultaneous click+keyboard inputs properly for N), so my run is only meant to be a proof-of-concept test. This run has 18 frames between first contact and the jump, although I suspect there are certain speeds and trajectories that will have an even larger tolerance. I have now reworded the Wiki article in question to more accurately address this very valid point, MiBeM. Thanks for bringing it to my attention once more!
While looking through that article, I noticed the example for the rcj was not quite as impressive as it could be. So I changed it to use Eddy's rcj in 51-0.ska wrote:I have now reworded the Wiki article in question to more accurately address this very valid point, MiBeM. Thanks for bringing it to my attention once more!
Great! Good to see the Wiki is evolving slightly faster than its biological counterparts.golf wrote:While looking through that article, I noticed the example for the rcj was not quite as impressive as it could be. So I changed it to use Eddy's rcj in 51-0.ska wrote:I have now reworded the Wiki article in question to more accurately address this very valid point, MiBeM. Thanks for bringing it to my attention once more!
Did a super clean run on ep 92, 9 frames from sum of 0ths.
haha. nice. what's funny about your 32-3 is that your highscore 0th would still be 19th place on the speedrun board (as of writing).EddyMataGallos wrote:Nice ep run bro, sr eps gotta start being cleaned like that. Took a couple 0ths while on a break from studying: 32-3 and -4.
thanks though :P
I can't play atm because of lag, but I'd like to see your run! :)_danielr_ wrote:Level 14808 sr. Can you beat the thwump to the top? Under 400 frames? :)
I got 392 f. I'll wait a bit before submitting the run to see if anyone else wants a go.ska wrote:I can't play atm because of lag, but I'd like to see your run! :)_danielr_ wrote:Level 14808 sr. Can you beat the thwump to the top? Under 400 frames? :)
EDIT: I've submitted it now :)
Some really nice runs here. Well done!macrohenry wrote:Tried some speedruns and took 90-2, 96-4, 98-0, 99-0 and (didn't really plan to do so) Ep95. Also tied 95-2 and 97-3.
Thanks! Some months ago I lost my .sol, that's why I'm currently playing through all the episodes again and taking 0ths along the way. Just grabbed 07-4, Ep07, 62-3, Ep 62 and 76-3.ska wrote:Some really nice runs here. Well done!macrohenry wrote:Tried some speedruns and took 90-2, 96-4, 98-0, 99-0 and (didn't really plan to do so) Ep95. Also tied 95-2 and 97-3.
Well done!macrohenry wrote:Thanks! Some months ago I lost my .sol, that's why I'm currently playing through all the episodes again and taking 0ths along the way. Just grabbed 07-4, Ep07, 62-3, Ep 62 and 76-3.ska wrote:Some really nice runs here. Well done!macrohenry wrote:Tried some speedruns and took 90-2, 96-4, 98-0, 99-0 and (didn't really plan to do so) Ep95. Also tied 95-2 and 97-3.
