N2High Save Files Upload Thread
Moderator: EddyMataGallos
Postby shomman » 2015.08.06 (01:36)
Had the idea of the History of a 0th on the N2High suggestions thread, and Eddy said he would be able to do it but we'd need a lot of save files to make it worth while.
I've found that the forums don't allow .hs2 files to be uploaded. Does anyone have any suggestions of how we can do this? Sidke has unlocked this so thanks
If everyone could upload their .hs2 files that'd be awesome.
And click to see the list of my personal 6 favourite features to put in n2high :)
Total Level Score (including only top 10's) - would mainly be something of interest
Ska mentioned in september 2013 - When exporting a "no ties" 0th rankings, even though your program says "0th rankings (no ties).txt" the file I got was just "0th rankings.txt" which replaced my existing file. A very minor thing, but nevertheless something you might want to fix on your next version. Cheers!
Overall top 10 changes - Just include all improvements - People can look at the level and notice if they have gone down. Otherwise it'll be too big, as you said.
The ability to create lists of of "Episode Mediocrities" and "Episode Sets", as per this thread
forum.droni.es/viewtopic.php?f=72&t=10270&p=173394&hilit=mediocrity#p173394
top 5 rankings as a separate function
top 3 rankings as a separate function
25-2-15.hs2
(177.9 KiB) Downloaded 1323 times
06-02-15.hs2
(177.83 KiB) Downloaded 1215 times
23-01-15.hs2
(177.33 KiB) Downloaded 1369 times
1-12-14.hs2
(175.96 KiB) Downloaded 1305 times
8-11-14.hs2
(175.47 KiB) Downloaded 1308 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 :):(
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.08.06 (12:52)
I will add more after another post.
Also, sho, you accidentally upload same score file twice. And the more crazier thing is that score file you attached is actually score file that exist in N2high folder, and it is called scores2.hs2. xD
20141228.hs2
(176.77 KiB) Downloaded 1256 times
20141220.hs2
(176.66 KiB) Downloaded 1244 times
20141217.hs2
(176.57 KiB) Downloaded 1261 times
20141215.hs2
(176.53 KiB) Downloaded 1260 times
20141214.hs2
(176.51 KiB) Downloaded 1296 times
Postby shomman » 2015.08.06 (22:45)
Ah ok yeah I was just testing while sidke was trying to get it working.
Uploaded my 5 earliest on previous.
7-03-15.hs2
(178.01 KiB) Downloaded 1302 times
2-03-15.hs2
(178.07 KiB) Downloaded 1232 times
1-03-15.hs2
(178.06 KiB) Downloaded 1213 times
28-02-15.hs2
(178.05 KiB) Downloaded 1309 times
26-02-15.hs2
(177.92 KiB) Downloaded 1152 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.06 (22:47)
5 more
16-03-15.hs2
(178.25 KiB) Downloaded 1290 times
14-03-15.hs2
(178.17 KiB) Downloaded 1356 times
11-03-15.hs2
(178.06 KiB) Downloaded 1257 times
9-03-15.hs2
(178.02 KiB) Downloaded 1318 times
8-03-15.hs2
(178.02 KiB) Downloaded 1261 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.08.07 (00:29)
5 more
20150610.hs2
(179.28 KiB) Downloaded 1260 times
20150606.hs2
(179.17 KiB) Downloaded 1310 times
20150413.hs2
(178.47 KiB) Downloaded 1303 times
20150322.hs2
(178.31 KiB) Downloaded 1326 times
20150222.hs2
(177.83 KiB) Downloaded 1232 times
Postby oxymoron93 » 2015.08.07 (00:35)
5 more to round up my scores files from June. xD
20150629.hs2
(179.52 KiB) Downloaded 1259 times
20150627.hs2
(179.52 KiB) Downloaded 1240 times
20150626.hs2
(179.48 KiB) Downloaded 1281 times
20150625.hs2
(179.49 KiB) Downloaded 1340 times
20150616.hs2
(179.41 KiB) Downloaded 1290 times
Postby shomman » 2015.08.07 (01:59)
Finished March started April.
I've got almost daily files at some points from April on
03-04-15.hs2
(178.44 KiB) Downloaded 1284 times
29-03-15.hs2
(178.41 KiB) Downloaded 1194 times
25-03-15.hs2
(178.35 KiB) Downloaded 1219 times
19-03-15.hs2
(178.27 KiB) Downloaded 1265 times
19-03-15.hs2
(178.27 KiB) Downloaded 1220 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:01)
Each post requires words.
12-04-15.hs2
(178.48 KiB) Downloaded 1199 times
11-04-15.hs2
(178.46 KiB) Downloaded 1261 times
10-04-15.hs2
(178.46 KiB) Downloaded 1237 times
09-04-15.hs2
(178.46 KiB) Downloaded 1222 times
09-04-15.hs2
(178.46 KiB) Downloaded 1206 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:03)
Almost finished April
23-04-15.hs2
(178.57 KiB) Downloaded 1205 times
21-04-15.hs2
(178.56 KiB) Downloaded 1175 times
15-04-15.hs2
(178.5 KiB) Downloaded 1217 times
14-04-15.hs2
(178.49 KiB) Downloaded 1156 times
12-04-15 (2).hs2
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:05)
Into May
12-05-15.hs2
(178.82 KiB) Downloaded 1149 times
10-05-15.hs2
(178.81 KiB) Downloaded 1316 times
04-05-15.hs2
(178.74 KiB) Downloaded 1214 times
03-05-15.hs2
(178.73 KiB) Downloaded 1299 times
25-04-15.hs2
(178.67 KiB) Downloaded 1177 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:21)
Almost Finished May.
June july is the most hectic i think
25-05-15.hs2
(178.88 KiB) Downloaded 1096 times
24-05-15.hs2
(178.88 KiB) Downloaded 1153 times
18-05-15.hs2
(178.85 KiB) Downloaded 1331 times
12-05-15.hs2
(178.82 KiB) Downloaded 1173 times
10-05-151.hs2
(178.81 KiB) Downloaded 1210 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:23)
May Finished exactly. How Neat.
31-05-15.hs2
(179.02 KiB) Downloaded 1255 times
30-04-15.hs2
(178.98 KiB) Downloaded 1235 times
28-05-15.hs2
(178.94 KiB) Downloaded 1266 times
27-05-15.hs2
(178.94 KiB) Downloaded 1113 times
26-05-15.hs2
(178.93 KiB) Downloaded 1290 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.08.07 (02:38)
My July.
20150713.hs2
(179.58 KiB) Downloaded 1252 times
20150711.hs2
(179.6 KiB) Downloaded 1238 times
20150710.hs2
(179.6 KiB) Downloaded 1281 times
20150709.hs2
(179.59 KiB) Downloaded 1146 times
20150701.hs2
(179.54 KiB) Downloaded 1270 times
Postby oxymoron93 » 2015.08.07 (02:41)
Some daily files from late July are coming.
20150724.hs2
(179.58 KiB) Downloaded 1219 times
20150723.hs2
(179.57 KiB) Downloaded 1230 times
20150722.hs2
(179.58 KiB) Downloaded 1300 times
20150721.hs2
(179.57 KiB) Downloaded 1254 times
20150720.hs2
(179.56 KiB) Downloaded 1224 times
Postby oxymoron93 » 2015.08.07 (02:43)
I was drunk on 26th...
20150730.hs2
(179.67 KiB) Downloaded 1347 times
20150729.hs2
(179.65 KiB) Downloaded 1186 times
20150728.hs2
(179.61 KiB) Downloaded 1291 times
20150727.hs2
(179.6 KiB) Downloaded 1220 times
20150725.hs2
(179.59 KiB) Downloaded 1209 times
Postby oxymoron93 » 2015.08.07 (02:46)
My latest 5 files. Yeah, I downloaded my latest just now, so I can upload 5 of them. xD
20150807.hs2
(179.69 KiB) Downloaded 1226 times
20150805.hs2
(179.71 KiB) Downloaded 1216 times
20150804.hs2
(179.71 KiB) Downloaded 1238 times
20150801.hs2
(179.69 KiB) Downloaded 1346 times
20150731.hs2
(179.68 KiB) Downloaded 1213 times
Postby shomman » 2015.08.07 (08:32)
The very similar titles are ones that are in the same day. 07-06-15 comes before 7-06-15 in the day etc.
7-06-15.hs2
(179.19 KiB) Downloaded 1264 times
07-06-15.hs2
(179.19 KiB) Downloaded 1238 times
6-06-15.hs2
(179.17 KiB) Downloaded 1218 times
06-06-15.hs2
(179.16 KiB) Downloaded 1243 times
03-06-15.hs2
(179.1 KiB) Downloaded 6164 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (08:35)
4 Save files from the 8th of June! Something must have happened that day. Maybe that was cooper getting grandmaster day.
09-06-15.hs2
(179.24 KiB) Downloaded 1200 times
8-6-15.hs2
(179.19 KiB) Downloaded 1218 times
8-06-15 (2).hs2
(179.2 KiB) Downloaded 1234 times
8-06-15.hs2
(179.19 KiB) Downloaded 1284 times
08-06-15.hs2
(179.18 KiB) Downloaded 1263 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (08:37)
Tick Tock
14-06-15.hs2
(179.39 KiB) Downloaded 1214 times
13-6-15.hs2
(179.35 KiB) Downloaded 1141 times
13-06-15.hs2
(179.34 KiB) Downloaded 1299 times
12-06-15.hs2
(179.32 KiB) Downloaded 1256 times
11-06-15.hs2
(179.29 KiB) Downloaded 1212 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (08:38)
On the clock.
24-06-15.hs2
(179.5 KiB) Downloaded 1138 times
18-06-15.hs2
(179.43 KiB) Downloaded 1125 times
16-06-15.hs2
(179.43 KiB) Downloaded 1206 times
15-06-15.hs2
(179.41 KiB) Downloaded 1298 times
14-6-15.hs2
(179.39 KiB) Downloaded 1220 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.08 (00:42)
26th to the 7th I was on holidays :)
18-07-15.hs2
(179.55 KiB) Downloaded 1217 times
17-07-15.hs2
(179.55 KiB) Downloaded 1205 times
13-07-15.hs2
(179.6 KiB) Downloaded 1302 times
7-07-15.hs2
(179.58 KiB) Downloaded 1223 times
26-06-15.hs2
(179.48 KiB) Downloaded 1261 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.08 (00:44)
Finished July. Now just a few from August.
30-07-15.hs2
(179.67 KiB) Downloaded 1357 times
28-07-15.hs2
(179.61 KiB) Downloaded 1161 times
26-07-15.hs2
(179.59 KiB) Downloaded 1222 times
21-07-15.hs2
(179.56 KiB) Downloaded 1262 times
18-7-15.hs2
(179.56 KiB) Downloaded 1159 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.08 (00:46)
Just a few to go.
05-08-15.hs2
(179.71 KiB) Downloaded 1231 times
04-08-15.hs2
(179.71 KiB) Downloaded 1139 times
3-08-15.hs2
(179.7 KiB) Downloaded 1255 times
03-08-15.hs2
(179.69 KiB) Downloaded 1211 times
01-08-15.hs2
(179.69 KiB) Downloaded 1200 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.08 (04:10)
Finally Finished.
08-08-15.hs2
(179.7 KiB) Downloaded 1207 times
7-08-15.hs2
(179.7 KiB) Downloaded 1289 times
07-08-15.hs2
(179.7 KiB) Downloaded 1190 times
06-08-15.hs2
(179.71 KiB) Downloaded 1220 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
NUMA Profile: http://nmaps.net/user/XandoToaster
Steam: www.steamcommunity.com/id/XandoToaster
Postby XandoToaster » 2015.08.11 (05:52)
shomman, oh my god, have you ever heard of zip files
I formatted my titles as "scoresyyyy-mm-dd" so that when they're organized alphabetically, they'll also be organized chronologically. I have 26 files from November of 2014 through August of 2015. It's probably not as complete as shomman's collection, but it may fill in some gaps.
scores.zip
(1.06 MiB) Downloaded 1186 times
Today is just a really good day, ya know?
2nd place in Npoints Season 3
Nv2 Column Run King
