Npoints Season 4 has begun, and will be run by Thunder.
Week one has levels from Spackal, Andrew_99, [urlwww.thewayoftheninja.org/nv2.html?l=158210]Andrew_99[/url], chaos111, and Btoasterboy.
Edit: Table here
A reminder of how it works:
There is NO SIGN UP. Simply playing a map will enter you into the contest, causing you to be entered into the table and your points to be tallied.
Each Monday, 5 maps will be published, and competed on until the following Sunday. On that Sunday the points will be tallied. No demos submitted after the tallying will count.
Each level is titled as follows, depending on the week this season: [S4W1] Made by shomman - Title_Here
This [S4W1] tag is intended to make searching for the levels easier, as is the changing of accounts each season (this season is "Npoints 4")
Points are allocated as follows:
0th = 10 points
1st = 9 points
2nd = 8 points
3rd = 7 points
4th = 6 points
5th = 5 points
6th = 4 points
7th = 3 points
8th = 2 points
9th = 1 point
Good luck!
Npoints Season 4
Moderator: EddyMataGallos
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 ![]()
Other Stuff
Thanks Nyan!
I'm going away for these holidays, so i'll miss a week entirely.
This combined with the upload failure last week pretty much rules me out to win this season with pzylL intense level of playing :(
I'll have to settle for 2nd or 3rd*, depending on how well toast goes. Seems like he's pretty time stripped.
Edit: I think I just won't bother with Npoints this season. Can't really be bothered anymore with the levels. I will probably play some of the more fun ones, if I feel like it.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Thanks Nyan!
- NUMA Profile: http://nmaps.net/user/SnakeekanS
- Steam: www.steamcommunity.com/id/BystanderN/
due to issues npoints is postponed for a week , week 9 starts - Monday 3rd august
