Want a ded? / Shameless Plug
Postby bufar » 2008.11.01 (20:59)
Nothing in the rules says I can't do this, so here goes nothing.
Whoever has the 0th place run on this map by the end of November gets a ded. I won't just say "dedicated to so-and-so" in the description, it'll be an actual ded. Just not a DDA this time, sorry.
Good Luck and Have Fun.
Postby Izzy » 2008.11.01 (21:18)
I have my run submitted, but I fear It will be beaten.
Postby isaacx » 2008.11.02 (21:45)
on speedrun or highscores?
Postby bufar » 2008.11.03 (23:56)
Since there's no gold, doesn't it not matter?
Postby isaacx » 2008.11.04 (02:38)
bufar wrote:Since there's no gold, doesn't it not matter?
well, highscores is how much time you have left, and speedrun is how much you spent, i think i'll just use speed run :|
Postby bufar » 2008.11.04 (04:36)
But since there's no way to add time, wouldn't time left and time spent yield the same results?
Postby Izzy » 2008.11.16 (21:24)
Golfkid's run is messed up. O_o
Postby golf » 2008.11.16 (23:22)
Yeah, I did it before he changed the level code to include a no walljump mod.
Postby bufar » 2008.11.17 (01:38)
I never changed the level code. The "Created" and "Last Modified" dates on NUMA are 2008-11-01. The date you uploaded your run is 2008-11-05.
Postby golf » 2008.11.17 (15:40)
Hmm. I know I was able to get walljumps in while playing it with Nreality. I wonder if the updates didn't load for some reason when I started the flash that time. On a semi-related note, peave_bear's run seems to have the same problem as mine, also uploaded on the 5th.
