the collaborative N pastebin!
works with n1.4
works with n2
as seen on tv
new version is live http://paste.droni.es/
http://paste.droni.es/ http://paste.droni.es/ http://paste.droni.es/ http://paste.droni.es/
new features:
N2 data compatible! - you can now collaborate in n2 with an option to convert it to n1.4 data for numa submissions!
NReality compatible! - minor, background and foreground images are not yet supported, but nreality drone types are!
how-to:
step 1: make a new paste
the front page may be bleak and uninviting, but everything you need to start collaborating is right here. paste your data right into the open text area, and hit "Paste as New Map". assuming your map's data is valid, you'll be sent to your paste's page.
step 2: share your paste
http://paste.droni.es/78176772918c526f85843b8e
this is your paste's page. you can now copy the url and send it to your friends. when they go to the page, they'll be able to view your map and copy its data to be loaded in their N.
step 3: make some edits
when done making edits to the map, it can be pasted into the available text area under "New Paste:". submit the map as an edit by using "Paste as Edit", or if it is completely unrelated, use "Paste as New Map".
step 4: view the progress
pastes that have been submitted as edits may have their modifications over pastes viewed by going "older". as seen in
http://paste.droni.es/129a9561c576176002271fc3
you cannot view any future edits of a map unless you link directly to those edits. the handling of branching edits is not something i care to implement.
other:
if you come across any bugs, let me know please so i can fix them
if you have any feature requests, let me know please so i can maybe implement them
it is not planned on having accounts to log into, it will forever be completely anonymous
paste dot two
- Raigan and the Horse-Woman
what was wrong with the old system? last i remember every map was already loaded on the same hash URL and it was a matter of clicking between themsidke wrote:you cannot go "newer" from a newly loaded page because of the possibility of multiple edits.
you can still visit up and down the history, here is an example:Sunset wrote:what was wrong with the old system? last i remember every map was already loaded on the same hash URL and it was a matter of clicking between themsidke wrote:you cannot go "newer" from a newly loaded page because of the possibility of multiple edits.
post map 1, hash abc
post map 2 as edit of map 1, hash def
post map 3 as edit of map 2, hash ghi
post map 4 as edit of map 3, hash jkl
post map 5 as edit of map 2, hash xyz
if you link to /abc, map 1 will be shown
if you link to /jkl, maps 1, 2, 3, and 4 will be shown
if you link to /xyz, maps 1, 2, and 5 will be shown
bug fixes:
- drones now do not disappear when converting from 2.0 to 1.4
- drone pathing is now parsed and coverted correctly
- n1.4 demo data should now be able to be posted along with a map
- RoboBarber
hey sidke you're the best thing.
- Quarks
- NUMA Profile: http://www.nmaps.net/user/Spackal
hello...?
Bounce pads don't seem to agree with the paste site: http://paste.droni.es/54d571c81d5d49a595f35fb6
There should be one of each pad facing away from the bounce block (this was uploaded with v2 data)
