NPoints Season 3
Moderator: EddyMataGallos
Postby shomman » 2015.01.08 (11:08)
Hi all.
I am aware that Johan made a topic about Season 1, however much has changed since then, and as such this is the topic for Season 3. This will be updated probably each week.(Original Topic)
Season 3 will be run by THUNDER and myself. The account name will be Npoints Official Season 3
We will be starting on Monday the 12th of January.
For Week 1, we have maps from Andrew_99, XandoToaster (BtoasterBoy), Meta_Ing and THUNDER
The Npoints Season 3 table can be found here
Edit: New table, can be found here (Special Thanks to Oleary for helping with it)
If you would like to submit a map, you can PM me here, or find me on either of the chats (hopefully).
A reminder of how it works:
There is NO SIGN UP. Simply playing a map will enter you into the contest, causing you to be entered into the table and your points to be tallied.
Each Monday, 5 maps will be published, and competed on until the following Sunday. On that Sunday the points will be tallied. No demos submitted after the tallying will count.
Each level is titled as follows, depending on the week and which level it is: [W1L1] Made by shomman - Title_Here
This [W1L1] tag is intended to make searching for the levels easier, as is the changing of accounts each season.
Points are allocated as follows:
0th = 10 points
1st = 9 points
2nd = 8 points
3rd = 7 points
4th = 6 points
5th = 5 points
6th = 4 points
7th = 3 points
8th = 2 points
9th = 1 point
Good luck!
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 :):(
Other Stuff
Image Thanks Nyan!
NUMA Profile: http://nmaps.net/user/Oleary15
Postby Oleary15 » 2015.01.08 (22:08)
"12/01/15"
From where I am from this looks like it is starting on December 1st, 2015, haha.
NUMA Profile: http://nmaps.net/user/SnakeekanS
Steam: www.steamcommunity.com/id/BystanderN/
Postby THUNDER » 2015.01.12 (00:57)
I run this mainly getting help from shomman
Postby ska » 2015.01.12 (12:45)
Oleary15 wrote:"12/01/15"
I think when it comes to dates intended for an international audience, you should use the month name to resolve ambiguity. i.e. 12/Jan/2014
Postby shomman » 2015.01.12 (23:22)
Ahh yeah good idea Ska, edited the original post.
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby THUNDER » 2015.01.19 (20:16)
remember we need to edit this again - table (spreadsheet)
Postby shomman » 2015.01.19 (23:19)
Npoints Season 3 Week 2!
Last week was dominated by pzylL, who took away all 50 possible points. This was despite the efforts of Btoasterboy (42 points) and the moderate involvement of Oleary15(17 points). pzyIL vengefully retook multiple 0ths Btoasterboy took from him and was rewarded for his efforts.
This week we have maps from blacklef, XandoToaster (BtoasterBoy), THUNDER and Rektangles.
Good luck everyone.
The Npoints Season 3 table can be found [https://onedrive.live.com/view.aspx?res ... E6ISVvAL08)]here[/url] (Special Thanks to Oleary for helping with the new table)
0th = 10 points
1st = 9 points
2nd = 8 points
3rd = 7 points
4th = 6 points
5th = 5 points
6th = 4 points
7th = 3 points
8th = 2 points
9th = 1 point
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
