Post a Run!
Postby ska » 2014.11.18 (16:08)
I've got what I believe is a very good run on my map: 234047. I'd be grateful if people rated/commented it, too.
The only spot I know can be improved with certainty is the launchpad bit on the bottom-left; you can squeeze through the launchpads without wall-jumping, but I've only done it once. (I pulled it off the first time I tried it, funnily enough, but couldn't repeat it; so I'm guessing it's tough to do consistently, but I'm no Eddy...)
Ded to the first person who beats my score!
Postby golf » 2014.11.21 (00:09)
Got a nice run on here - http://www.nmaps.net/234053
Went into it thinking that he had screwed up and forgot to reset the map in NED before submitting, but seems like that's not the case. Just an odd, difficult jumper. By the way, does anybody know if the jumps off the tops of doors is still possible in v2?
Postby EddyMataGallos » 2014.11.21 (00:13)
golf wrote:Got a nice run on here - http://www.nmaps.net/234053
Not only possible, but easier too ;) Doors are less sensitive in Nv2.0. Nice run by the way :D
Postby golf » 2014.11.21 (00:16)
Thanks! But, since you replied with a huge smiley face, I expected to reload the map and see that you've beaten me. I feel slightly disappointed, but not so much that you should feel like it has to be done :P Still want to see you on irc again. But don't join right now, I'm on my way out to work for the evening.
Also, interesting to know about the v2 doors, thanks.
Postby ska » 2014.12.14 (05:55)
Got a chance to get back on my old laptop and make an NReality run. 234278 hs
Can anyone find a faster route? You can obviously clean off some frames near the end at the very least.
Postby golf » 2014.12.15 (02:25)
234199 hs. Was reminded that I had a dedication map that I hadn't played yet, so had to go and get something special done there :)
Postby ska » 2014.12.17 (04:23)
golf wrote:234199 hs. Was reminded that I had a dedication map that I hadn't played yet, so had to go and get something special done there :)
nice one.
234329 hs on a new krusch map. Pretty chuffed with this run. Make sure you guys drop him a comment and a rating; I strongly recommend this map. I think it would be a great episodic map.
Edit: 234333 hs/sr
Edit 2: 234338 hs
Postby Izzy » 2014.12.19 (07:47)
ska wrote:
golf wrote:Edit 2: 234338 hs
Taken.
Postby ska » 2014.12.19 (08:57)
Izzy wrote:
Taken.
Tak3n.
I knew about that thwump jump; not sure why I didn't bother using it.
Postby EddyMataGallos » 2014.12.19 (16:07)
ska wrote:
Izzy wrote:
ska wrote:Edit 2: 234338 hs
Taken.
Tak3n.
T4ken.
Postby alsojp27ace » 2014.12.19 (16:39)
ska wrote:
Izzy wrote:Taken.
Tak3n.
T4ken.
*Take5*
Postby EddyMataGallos » 2014.12.19 (17:45)
ska wrote:
Tak3n.
T4ken.
*Take5*
-Ta6en-
Postby ska » 2014.12.20 (03:09)
EddyMataGallos wrote: -Ta6en-
7aken
(not really, but I just wanted to point out that it was odd that Izzy initially quoted "golf" even though golf never even posted or played the map. I guess that was a mistake stemming from the fact that I had quoted golf, and Izzy probably just did some careless copy pasting work.) Also, I was wondering about a route that involved getting some more gold on the way back to avoid the bottleneck, so good job, guys!
Postby golf » 2014.12.20 (20:16)
Nothing spectacular in and of themselves, but I improved 52-4 and 75-1 today by 5.4 and 5.5 seconds respectively. Those were 2 of my 4 worst levels, and it brings me 10.9 seconds closer to Lim's total score. Less than 60 seconds till I pass him now!
Postby ska » 2014.12.24 (12:40)
234220 hs
I challenge Eddy and macro to beat it.
Postby ska » 2014.12.30 (10:51)
http://www.nmaps.net/234461 my own map. metanet inspired. please give this a shot (rate and comment plskthxbai)
234461
(ID above for easy selection)
Edit: well done, Eddy!
Postby ska » 2015.01.04 (06:13)
61805 HS
Postby macrohenry » 2015.01.04 (13:23)
ska wrote:61805 HS
Seems like xaelar beat you there. :P
Postby ska » 2015.01.05 (05:48)
macrohenry wrote:
ska wrote:61805 HS
yes, but jp has taken it to a new level...
edit: took 123456 hs
lol
Postby golf » 2015.01.15 (04:20)
Its barely squeaks into the top 5, but I'm really proud of my new 58-3. Used a version of the new route to pick up the gold I was missing, along with a couple hundred more frames for about 6 seconds improvement. I did get an agd-1 that was 4 frames faster, but after spending over an hour and a half tonight I'm satisfied with what I've done. Plus, xela and Lim are too far ahead for me to be able to bypass them without another drone cycle.
I also really like the first run I got where I beat the drone and got the cycle I finished with. I squeezed past the drone with probably only a single frame to spare... too bad it was agd-1. Saved the demo from infunity before submitting my agd run since I just really love that dodge :)
Couple things I want to say about this route. For some reason the perpindicular jumps off the curves to get the switches were really tough for me. I think I wasn't getting enough height off the previous jump to get a solid connection with the ground when trying to jump. Secondly, the little tile skip to get the last of the gold in the top middle is a lot harder than it looks. Many good runs were spoiled by screwing that up :/
Postby ska » 2015.01.15 (04:52)
golf wrote:Its barely squeaks into the top 5, but I'm really proud of my new 58-3. Used a version of the new route to pick up the gold I was missing, along with a couple hundred more frames for about 6 seconds improvement. I did get an agd-1 that was 4 frames faster, but after spending over an hour and a half tonight I'm satisfied with what I've done. Plus, xela and Lim are too far ahead for me to be able to bypass them without another drone cycle.
smooth runs!
Postby Hendor » 2015.01.15 (17:27)
golf wrote:For some reason the perpendicular jumps off the curves to get the switches were really tough for me. I think I wasn't getting enough height off the previous jump to get a solid connection with the ground when trying to jump.
I improved this level too recently and those were pretty annoying as well. Seemed like the one frame where I skipped was always the one I chose to jump in.
Postby macrohenry » 2015.01.15 (20:15)
137745 hs. Of course it's much faster not to collect the gold behind the doors, but I wanted to take the challenge of an all-gold run. Challenge completed! ^_^
Postby EddyMataGallos » 2015.01.15 (20:56)
That was ridiculous, nice job man :D
Postby Hendor » 2015.01.15 (20:59)
You're crazy. That was amazing.
