Postby EddyMataGallos » 2014.12.05 (23:29)
Nice innov man, that drone always frustrated the heck out of me, its not just a bottleneck, you can't go slower either, there's just this little frame window in which you have to pass, iirc.
Btw, I think its about time you have a go at the occupy xela movement, isn't it?
EDIT: I just realized that the fastest non-cj run for 11-0 is 149.225. For those that are using that route (golf?, Hendor?), I have a 150.500 non-cj route:
That was my first completion with it, 150.475, it can definitely be cleaned and you can beat Melchoir with it. 151 is probably not plausible for both bottleneck and cleaning issues, but its definitely worth a shot.
Postby ska » 2014.12.07 (06:24)
Not really an innovation, so much as a possible opportunity. A couple of years or so ago, swipenet took 06-3; however, his beginning uses a slower method. The launchpad route in the bottom-right corner (compare swipe to my run or xaelar's for example) is considerably quicker. (maybe 0.2-0.25 seconds faster.) Since the level is relatively long (about 1200 frames), swipenet's run is clean enough aside from this slower start to make up time and outrun xaelar. Consider this a big hint for Eddy or macro, or anyone else for that matter, to try to nab it.
P.S. I am having trouble pasting demo data into NHigh's demo analysis... has anyone else ever had this issue? I've never had it before (Using 2.0.1)
Postby EddyMataGallos » 2014.12.07 (15:46)
ska wrote:Not really an innovation, so much as a possible opportunity. A couple of years or so ago, swipenet took 06-3; however, his beginning uses a slower method. The launchpad route in the bottom-right corner (compare swipe to my run or xaelar's for example) is considerably quicker. (maybe 0.2-0.25 seconds faster.) Since the level is relatively long (about 1200 frames), swipenet's run is clean enough aside from this slower start to make up time and outrun xaelar. Consider this a big hint for Eddy or macro, or anyone else for that matter, to try to nab it.
Oh so had anyone done that route already? If not, its an innovation! It's of course a mixture of previous routes though.
Regarding NHigh, its working fine for me. What's happening with yours?
Postby ska » 2014.12.10 (16:17)
I don't know, but I got it working again; it was probably just a bug.
Postby Izzy » 2014.12.12 (02:25)
It's probably been mentioned already, but grabbing the switch on 35-3 right after the walljump should definitely save a bit of time. Messed up the double a couple of time after getting it that way. :(
Postby ska » 2014.12.12 (05:01)
I must have missed this part of your reply. I would have just called the launchpad route the "normal" route. I certainly won't take and credit for being an "innovation". For some reason swipenet used a slightly slower wall-jump route; perhaps under the mistaken belief that it was faster than the wall-jumps.
Izzy wrote:It's probably been mentioned already, but grabbing the switch on 35-3 right after the walljump should definitely save a bit of time. Messed up the double a couple of time after getting it that way. :(
It is known; it's just not that easy.
MBD for proof:
Postby EddyMataGallos » 2014.12.12 (23:47)
Oh no, I meant my 11-0 no-cj route. It takes parts from 2-3 different routes, plus a new ending. I don't think this had ever been used before, hence why I called it new route, or innovated route.
Postby TheRealOne » 2014.12.16 (03:09)
57-4
Are either these possible while still avoiding the rocket?
Normal (Down, Up, Down, Up): 225f --- Current route.
Wall Jump and Only One Double Jump (Up, Down, Up): 209f --- Easy, but will probably get caught by the rocket.
Double Jump to Backwards Wall Jump (Down, Up): 190f --- Definitely possible with current route, but hard and a complete run ruin-er if failed.
Postby ska » 2014.12.16 (06:31)
TheRealOne wrote:57-4
Man! That' a nifty idea.
Postby alsojp27ace » 2014.12.16 (13:26)
Woah that last one looks awesome, that would definitely be the fastest if someone can pull it off.
I tested the first one and was running into the rocket all the time, this way avoids the rocket and I found it to be slightly faster too:
Edit: Taken
Postby vankusss » 2014.12.16 (16:36)
Nice finds.
This is a faster beginning:
works also with the rocket:
Postby alsojp27ace » 2014.12.16 (16:49)
vankusss wrote:Nice finds.
I sat here for about a minute thinking I swear I tried that jump, before I realized you raised the ground :p
That said, you could try something like this:
Postby vankusss » 2014.12.16 (16:54)
alsojp27ace wrote:I sat here for about a minute thinking I swear I tried that jump, before I realized you raised the ground :p
It's not raised in the first map, you need a cj. I raised it out of lazyness, to prove the rocket part. I hoped it would confuse people, so +1 me.
Postby alsojp27ace » 2014.12.16 (17:03)
Ah yeah I just went and re-watched it, it certainly had me confused for a bit, I've never gotten the hang of that kind of cj.
Postby ska » 2014.12.16 (23:08)
well done, JP! I'm looking forward to this map breaking 160!
Postby TheRealOne » 2014.12.17 (03:43)
Edit: Taken
Nice work JP. I had a feeling that the two options I showed weren't the only possibilities; the previous route to your 0th just seemed unnecessarily slow. Great innovation and run executing it.
Things are escalating quickly. This map definitely has a lot left in it with these innovations and some cleanliness.
Postby ska » 2014.12.17 (12:24)
154232 hs (used several minor innovations to secure the 0th by half a second.)
occupy xaelar
Postby alsojp27ace » 2014.12.19 (01:05)
For occupy xaelar, if you have a look at my 38-4 run, I'm convinced there's enough time left in cleaning to grab that first gold and still beat the same drone cycle.
My fingers just aren't quick enough for that first jump though, I hit the mine every time.
Edit: An example run with a purposefully slower start, so it's definitely possible for those of you with quick fingers:
Postby ska » 2014.12.19 (01:54)
alsojp27ace wrote:For occupy xaelar, if you have a look at my 38-4 run, I'm convinced there's enough time left in cleaning to grab that first gold and still beat the same drone cycle.
It's interesting, because I was shortlisting this 0th as a possible candidate for de-xaelaring, but I think we'd need an N veteran with expertise in mathematical networks to determine the most optimal route (or close to it.)
Postby macrohenry » 2014.12.20 (16:48)
82-3
Start
Current (117f):
New (crappy execution, 100f):
Gold in the middle
Current (366f):
New (355f):
Postby EddyMataGallos » 2014.12.23 (22:13)
Hmm, for some reason I kind of rememeber the first innov, I thought there was an MBD using that but its not in the collection.
Regarding the second one, I have a slightly faster one (349f):
That thing has much more potential though, I think. Specially by doing this:
Man that must save a bunch :P
Postby ska » 2014.12.24 (02:11)
Woah, did Eddy just come up with an innovation by himself? Freaky.
Postby EddyMataGallos » 2014.12.24 (02:23)
Postby ska » 2014.12.24 (05:38)
that's the creepiest picture of Milhouse I've ever seen...
(He looks way older...)
Postby ska » 2014.12.28 (04:15)
Sorry for the double post, but watch my speedrun for 162-1; it's a pretty axiomatic innovation, but if you nail it with an optimal route, there's a chunk of time to be taken off.
