Metanet 0ths Thread
Two things about this run.
1) I use an innovation that I think I thought of initially years ago.
2) Yes, I'm aware that the top-left part can be done much cleaner, but my 0th is only designed to be temporary and for someone else to capitalise on my innovation.
Thanks for doing that. You've clearly executed the vision I had for the level. :)macrohenry wrote:Taken. There's still a lot of room for improvement since you can add more low jumps.
Thanks.alsojp27ace wrote:Great innov, and very cleanly executed too. I'll match your 3rd innov in an episode with one for 12-4, I spent about 10 minutes trying to do that last jump before I gave up:
As for 12-4, it's funny; as soon as I loaded 12-4 and saw what map it was, I immediately thought, "I bet you it's a double-jump on the bounce block." I'm shocked it hasn't been used, but not that shocked, since the guasses are a fucking nuisance; then combined with the rocket and the triple thing at the end... plus you don't even save that much time...
Yeah I'm amazed how often I see what should be obvious innovs when playing through levels. In regards to the gauss and rocket, both are pretty easy to avoid if you just stick to the left side of the final bounce block, I personally don't find it any more difficult than going for the launchpad and getting Eddy's jump off the curvy tile.ska wrote:Thanks.alsojp27ace wrote:Great innov, and very cleanly executed too. I'll match your 3rd innov in an episode with one for 12-4, I spent about 10 minutes trying to do that last jump before I gave up:
Edit: Taken
So this is actually something I have always wondered about, but never spent the time figuring out. I think everyone knows at this point that for some reason when holding either left or right on a BB while descending you will force the BB lower with the same amount of vertical momentum. I do not know why this to be the case. Maybe someone with experience getting in to the code could figure that out. I suspect that this survival issue is connected to that bug/quirk in someway, though I can't be sure.ska wrote:I'm pretty pleased with the run itself; although I'm not sure if I lost time by the clipping on the middle descent. I know for a fact that you don't need to clip it to survive the fall onto the bounceblock, but survival is a little random... maybe something to do with horizontal movement? (Paging TRO for an expert opinion.) During testing, I was able to get all the gold by glancing the bounceblock without "landing" on it, and then wall jumping off the bottom-right, although this is also tricky, and again, I'm not sure if it's faster.
I had success surviving when NOT holding a direction when landing on the BB.
This is possible
https://www.youtube.com/watch?v=ahUo8bojQBs
Edit: Wait, has anybody else noticed the new 0th on 1-3, or did I completely miss a discussion somewhere? Our good friend VotedStraw from 2.0 has beaten Eddy by 5 frames there!
Very nice 18-4; I remember your 104.4 run, so it's good to see you have reclaimed that 0th. As for 1-3, you'd think a 2.0 veteran dropping by to snatch a 0th off Eddy would have been memorable; as it turns out, he must have taken the 0th in the last week (according to my December 4 file, Eddy has the 0th.) I'm sure someone with a daily file can give you a more accurate date of acquisition. Regardless, that is a really good run, and I hope that VotedStraw joins the forum and continues to submit some stellar runs.golf wrote:18-4, after losing it more than a year and a half ago. Also, my first 0th in quite a while.
Re: TRO's demos; really interesting demos you've got there. That second one with the deflection off the 1-tile seems obvious in hindsight, but how much faster is it compared to a bounceblock pass-through or a direct drop to the bottom? Due to the latter example being more beneficial from horizontal momentum, can you put the exit in the bottom left corner to illustrate the differences in each route? (If you decide to test them that is.) Cheers.
Edit: This just in: Votedstraw has taken 90-3. Not taken on NReality, although the run looks legit to me. Still, if anyone has a contact for this guy, let's get him on board. He also has a top-20 score on 00-0.
Edit 2: After a quick google, he seems to be aware of NReality, but it's difficult to establish whether these are the same person, although I don't think we have any reason to suspect that he's not, other than the fact that one is VotedStraw and one is VotedStraw61372. Perhaps he forgot his login password? I'm a bit confused about the whole thing, honestly.
Edit 3: I think I've cracked the case; VotedStraw is none other than FDan! (Pay attention to the URL.)
Cracked by myself over a year ago ;)ska wrote:Edit 3: I think I've cracked the case; VotedStraw is none other than FDan! (Pay attention to the URL.)
Also, dafuq is going on with this late non-NReality hype. We've been working on cleaning that list guys, not the way around...EddyMataGallos, on 13 Nov 2013 wrote:He pretty much is FDan James.james_S wrote:Btw did Votedstraw reveal who he was??
I had had FDan as a contact on Youtube for a year already when N 2.0 was released, and we had messaged and so on. Then I forgot about that, but when I went back to see my inbox, his messages were now under the name "Voted Straw".
This is the aforementioned account: http://www.youtube.com/user/Fdanism
I mean its not a completely sure fact but it pretty much is. He was a hardcore underclocker so I just hope he did not underclock his runs in N v2.0 as well.
Anyway, NRealitized that 1-3 back. Rest of the 0ths will have to wait though, I should have spent this time studying xD
Since we use different routes, I'm guessing you meant Eddy's execution of van's route, double typo there :P Is your current score the one you took the level with though? Just to keep track of the scores you know.ska wrote:(Mr_Lim's execution of Eddy's route seemed almost optimal; and my route proved faster than even that)
Edit: I've also noticed on the highscores that sometimes it capitalizes the J in my name and sometimes it doesn't, any idea what might be causing this?
I'm pretty sure I haven't relogged or anything between 0ths
I feel like Kool right now... Really? Just a single frame?macrohenry wrote:Took 13-3 and 18-4. ;)
This was my first night of trying to retake it, when you still only had .550. After as much trouble as I've had with this, I don't know if I can take it for even just another single frame. That's where I started off, essentially, and it took me 6 hours or so of play to finally break my plateau.[00:50] * @golfkid puts shotgun in mouth of 1.4 bounceblock physics, and pulls the trigger
[00:50] <@golfkid> http://pastebin.com/hUzfx08X
[00:51] <@golfkid> Seriously
[00:51] <@golfkid> Improved 6 frames to be 1 behind macro literally 3 hours ago
[00:51] <@golfkid> After 15 minutes or less
[00:51] <@golfkid> Haven't been able to even tie him
[00:51] <@golfkid> Had this happen god knows how many times
[00:51] <@golfkid> I'm done
Nice innov man, not sure if it had already been mentioned, but I have a vague memory of seeing discussions about that change, and how it was faster. I might be wrong though.alsojp27ace wrote:Nice runs macro, taken 14-2.
Anyways, mine again. Cracked one more frame in 13-3 and regrabbed 12-4 too.
Nice runs on 18-4 golf and macro, tricky level. Come on golf, can't give up at this point! Don't stay Kool now.
EDIT: 90-3 is back to me, too. Just Kooled him. I'd like this dude to use NReality though, so if you're reading this, well, you know. At least join the community man xD
Well there go all my 0ths again lol, and VotedStraw now has a .925 run on 90-3. I agree that I'd prefer it if he was using NReality, if I'm honest I'm a little suspicious.EddyMataGallos wrote:Nice innov man, not sure if it had already been mentioned, but I have a vague memory of seeing discussions about that change, and how it was faster. I might be wrong though.alsojp27ace wrote:Nice runs macro, taken 14-2.
Edit: I managed to get a top-20 run on 90-3 even with my terrible chimneying, although funnily I'm 3rd in the NReality rankings.
Hah lol, me too, specially now with this .925 run. And he didn't even get a proper ending after the tunnel, his lead is all chimney. Someone has to somehow comunicate with him, and the only way I know is making an username message xD But I don't want to mess the boards even more, specially 90-3. Although I guess we could ask M%R to delete it afterwards.alsojp27ace wrote:Well there go all my 0ths again lol, and VotedStraw now has a .925 run on 90-3. I agree that I'd prefer it if he was using NReality, if I'm honest I'm a little suspicious.
- Legacy Elite
Demo analysis for 90-3 (4th rank) - [VotedStraw61372, 149.925]
000. LJ - 1 frame
001. L - 4 frames
005. LJ - 1 frame --- Frame Perfect Corner Shove including the direction change.
006. L - 1 frame
007. RJ - 1 frame
008. R - 44 frames
052. RJ - 1 frame
053. R - 4 frames
057. J - 1 frame
058. LJ - 4 frames
062. L - 1 frame --- Near perfect chimney after the PJ
063. J - 2 frames
065. Nothing - 1 frame
066. J - 1 frame
067. LJ - 7 frames
074. L - 1 frame --- Perfect WJ
075. LJ - 1 frame
076. RJ - 8 frames
084. R - 2 frames
086. J - 2 frames
088. Nothing - 1 frame
089. J - 1 frame --- Perfect chimney
090. Nothing - 1 frame
091. J - 1 frame
092. LJ - 7 frames
099. L - 1 frame --- Perfect WJ
100. J - 1 frame
101. RJ - 8 frames
109. R - 2 frames
111. Nothing - 1 frame
112. J - 1 frame --- Another Perfect chimney
113. Nothing - 1 frame
114. J - 2 frames
116. LJ - 6 frames
122. L - 5 frames
127. LJ - 1 frame
128. L - 1 frame -- More perfect jumping, seems very suspect to go for 2 jumps in the top chimney rather just a plain WJ after the insane jumping he just pulled off.
129. LJ - 2 frames
131. R - 4 frames
135. L - 2 frames
137. Nothing - 8 frames
145. R - 3 frames
148. Nothing - 3 frames
151. R - 1 frame
152. Nothing - 18 frames
170. R - 6 frames
176. RJ - 8 frames
184. R - 21 frames
205. Nothing - 7 frames
212. L - 17 frames
229. LR - 1 frame
230. R - 16 frames
246. LR - 1 frame
247. L - 18 frames
265. LR - 1 frame
266. R - 18 frames
284. Nothing - 10 frames
294. L - 8 frames
302. LR - 1 frame
303. R - 82 frames
385. RJ - 2 frames
387. R - 1 frame
388. J - 2 frames
390. Nothing - 1 frame
391. J - 1 frame --- Perfect chimney
392. Nothing - 1 frame
393. J - 1 frame
394. LJ - 9 frames
Just to show a comparison to Macro's run, who chimney everything instead of doing every other like the other top runs:
Demo analysis for 90-3 (12th rank) - [macrohenry, 149.700]
000. R - 55 frames --- Doesn't go for the CS
055. RJ - 3 frames
058. Nothing - 1 frame
059. J - 2 frames
061. Nothing - 2 frames --- A mixture of 1 and 2 frame gaps
063. J - 2 frames
066. J - 1 frame
067. LJ - 9 frames
076. L - 2 frames --- Two frame WJ
078. LJ - 1 frame
079. RJ - 5 frames
084. R - 2 frames
086. J - 2 frames
088. Nothing - 1 frame --- Again a mixture
089. J - 2 frames
091. LJ - 8 frames
099. L - 2 frames --- Another two frame WJ
101. LJ - 1 frame --- Direction holds slipping in to the chimneying, (ie. not always jnjnj.)
102. J - 1 frame
103. Nothing - 1 frame
104. J - 2 frames
106. RJ - 8 frames
114. R - 2 frames
116. RJ - 2 frames
118. Nothing - 2 frames
120. J - 2 frames
122. LJ - 11 frames
133. L - 1 frame
134. LJ - 1 frame
135. J - 1 frame
136. Nothing - 2 frames
138. J - 1 frame
139. RJ - 3 frames
142. R - 5 frames
147. Nothing - 2 frames
149. L - 15 frames
164. LR - 3 frames
167. R - 18 frames
185. RJ - 7 frames
192. R - 24 frames
216. LR - 1 frame
217. L - 20 frames
237. LR - 2 frames
239. R - 17 frames
256. LR - 1 frame
257. L - 16 frames
273. LR - 2 frames
275. R - 16 frames
291. LR - 1 frame
292. L - 6 frames
298. LR - 3 frames
301. R - 92 frames
393. J - 2 frames
395. Nothing - 1 frame
396. J - 3 frames
399. Nothing - 1 frame --- Chimneying of varying jump quality
400. J - 2 frames
402. Nothing - 1 frame
403. J - 1 frame
404. LJ - 2 frames
406. L - 6 frames
I thought that you had finally gotten everything cleared up and moved on over to China. Good to know you haven't forgotten about us, and apparently are still able to connect on some level. Can't wait till you get all set up again and you can come back and join the party on irc.Hendor wrote:Hey guys, nice runs all, though I admit I haven't seen them. I still haven't got my computer set up in China since I moved here ~10 days go. Should be settling down soon, so, til then...
Okay, I could have sworn someone had already made the connection, so I used Cunningham's law to get to the bottom of it. (Cunningham's Law states: "the best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer.") So by claiming that it was me that cracked it, I knew I'd get to the bottom of who found it and when :P Certainly FDan's use of underclock on NReality made me suspect he was a cheater. Why would you use NReality when underclocking, then use 1.4 for highscoring? Maybe he felt that his underclocked runs weren't getting enough attention?EddyMataGallos wrote:Cracked by myself over a year ago ;)ska wrote:Edit 3: I think I've cracked the case; VotedStraw is none other than FDan! (Pay attention to the URL.)Also, dafuq is going on with this late non-NReality hype. We've been working on cleaning that list guys, not the way around...EddyMataGallos, on 13 Nov 2013 wrote:He pretty much is FDan James.james_S wrote:Btw did Votedstraw reveal who he was??
Anyway, NRealitized that 1-3 back. Rest of the 0ths will have to wait though, I should have spent this time studying xDSince we use different routes, I'm guessing you meant Eddy's execution of van's route, double typo there :P Is your current score the one you took the level with though? Just to keep track of the scores you know.ska wrote:(Mr_Lim's execution of Eddy's route seemed almost optimal; and my route proved faster than even that)
I agree. Not only because of 90-3, but also because of his new 01-3 run, that bottom gold room looks too perfect to me.ska wrote:My vote is to ignore VotedStraw in the official 1.4 rankings.
Retook 13-3.
Man you are on like a next level innovation/route change tear! I love it. I feel like you are able to look past the current top runs and see the level as a whole with out influence. Awesome run.alsojp27ace wrote:Yeah agreed, looking at TRO's analysis, that's too much perfect chimneying.macrohenry wrote:I agree. Not only because of 90-3, but also because of his new 01-3 run, that bottom gold room looks too perfect to me.ska wrote:My vote is to ignore VotedStraw in the official 1.4 rankings.
Taken 90-0
