N v2.0 0ths
Moderator: EddyMataGallos
I can provide it to you, but sadly hacked scores over 65536 frames (2 bytes) make the program crash, and by the way the scores are codified when you download them, I don't think there is any workaround (unless you have access to M&R database, which we don't). I can explain this in detail if anyone wants to understand why this happens. I could implement a pseudofix, to make the program skip those levels, but that would end up skipping most levels so it makes no sense :P Thats why I haven't already reuploaded the program. I was even working on a GUI which was going pretty good, but I won't finish that until the scores thing gets fixed.alsojp27ace wrote:This topic seems pretty much dead, but taken 07-4 and 08-4.
I've lost my copy of Nv2 High (and none of the downloads in that thread seem to work), does anyone have a copy they can upload?
Also, you need a new poll :)
I've asked M&R to fix this, if not hacking, at least implementing a limit of 50000 frames on the Metanet levels or so, simple measure which would allow the program to keep working.
EDIT: Btw, did you actually read the full post?
EddyMataGallos wrote:Attachments not working? MEGA links are right here:Code: Select all
[v3.0] https://mega.co.nz/#!8BZn0ZLL!ED_5VVynnu3HsnPcc-YRiwX-30NFMzasw3qNSCSjQOE [v2.0] https://mega.co.nz/#!FVoSTYhJ!EpqbQlRKQ6a2Kw3aU2MjknBA-7dzE06nj3ymF268XfE [v1.0] https://mega.co.nz/#!pJwlHSZT!BZiLQySDsNOAlZW121kztD9RUQMCBBGDgT5n6PZa18Y
here you goalsojp27ace wrote:Also, you need a new poll :)
New poll question: You discover a cure for cancer. However, you know that widespread use of this cure will lead to the extinction of plankton in 500 years. Which of these would you be most likely to do?
note that the question doesn't specify that you HAVE to do the option you chose, only which one you are MOST LIKELY to do. remember to use retronet or chrome (forum skin, not browser) to vote.
i'm going to disgrace myself in this thread by posting here without actually taking a 0th to write in it, because i'm lazy. i promise i'll start playing this game again sometime
real shame that m&r haven't fixed hacked scores even though they tried to
- Member
Improved by 1 more frame, pretty happy with that run, could be maxed.EddyMataGallos wrote: I recently took 18-1 by cleaning 2 frames over what we thought was maxed, by just changing the jumps.
And dan has later cleaned one more frame. So what the fuck, you guys can go ahead and see the difference between our runs and the rest and make theories if you want.
Damn, indeed it could, well done cooper :)cooperverdon wrote:Improved by 1 more frame, pretty happy with that run, could be maxed.EddyMataGallos wrote: I recently took 18-1 by cleaning 2 frames over what we thought was maxed, by just changing the jumps.
Btw, I think this should be moved to the highscoring forums.
new poll up, even though i've only taken a few top10s and no 0ths since last question
i think i'm going to ask metanet to make all my future financial decisions because it's too scary if i have to make them myself
bitcoins are arseholes that started the year at $310 and collapsed as low as $153 yesterday making me look like an idiot
Soon would be a good time to buy imo. (I suggest you wait a few days to see if it steadies; if it does, then buying seems like a good idea to me.) Don't go too crazy though; bitcoins are, like a lot of crypto-currencies, highly volatile. I'm glad I was wary about investing in them. In some respects, betting on bitcoins is like betting on the weather, since there are too many variables for most people to predict with a high degree of accuracy.999_Springs wrote:thanks for moving the thread eddy
