Yes, by Raif. ;)nadroj347 wrote:Awesome runs Eddy! 81-1 must have been a pain - btw - has an MBD ever been made for that level?
Metanet 0ths Thread
Incidentally, this was—and probably still is—the greatest difference between a legit 0th and an MBD.macrohenry wrote:Yes, by Raif. ;)nadroj347 wrote:Awesome runs Eddy! 81-1 must have been a pain - btw - has an MBD ever been made for that level?
Really awesome 81-4 route and great execution too!alsojp27ace wrote:Its not much compared to Eddy's recent rampage, but taken 81-4 and tied 52-1 (both with innovs).
Took 93-0. Only 17 seconds of TLS missing.
@JP, Yeah, awesome reroute there JP. And not only was the route great the execution was there to back it up. It appears you have held off macro in his attempt at the route. Hopefully you can hold off Eddy as well and keep the 0th all to yourself.macrohenry wrote:Really awesome 81-4 route and great execution too!alsojp27ace wrote:Its not much compared to Eddy's recent rampage, but taken 81-4 and tied 52-1 (both with innovs).
@macro, nice little innovation there on the bottom. That saves quite a lot over Eddy's run and you kept the rest of the run just as clean if not cleaner than Eddy and built an even bigger lead with that top left innovation. Nice job.
I am wondering if anyone is will to go for Raif's top right gold collection method.
Nice! You crushed 58-0 that right side look real pretty.macrohenry wrote:Took 32-3, 58-0 and tied 86-2. :)
Retook 81-4, 93-0 and 58-0. Took 52-1 and 32-3. Ownage on Ep52.
@jp: Awesome route change in 81-4, I was sincerely stunned when I saw it. I knew there had to be a way to get rid of that crappy wj that broke the flow on the previous route. As for 52-1, very clever change.
@macro: Nice couple innovs on 93-0, the beginning one saves quite a bit, and the ending one, damn that was clever. I wonder if its also worthwhile on MBD, since Raif doesn't do it. Also, I believe you are around 5 secs away from glory! Go man, you can make it for the following rankings :D
(van retook 81-0 btw)
Nice innov on 47-0, took it back. Also retook 81-0. Maybe we can see a comeback from van?
Took Ep00 and 51-3. Sorry for the 1 frame lead here, I was originally just going to reduce my diff.
EDIT: And 68-1 is my goodbye till the 15th ;)
not sure how i feel about livestreaming highscores. when i used to highscore it involved a lot of screaming things like "noooo" and "why did you do that" and "aaagh one frame". i agree that numa maps would be better
- Member
- NUMA Profile: https://www.nmaps.net/user/nadroj347
That wouldn't be too bad - maybe pretty entertaining to watch :P999_Springs wrote:when i used to highscore it involved a lot of screaming things like "noooo" and "why did you do that" and "aaagh one frame".
Whoooooaaaaaaaaaaaa - props man! A truly incredible feat! The level of mastery just keeps climbing...macrohenry wrote:Took 47-0 with an innovation and reached 72k! Finally! :)
Took 58-4.
Took 17-3 and 85-3 with fucked up ending. But I'll be doing Ep85 soon so I'll leave the improvement for then.
EDIT: Took 1-3, 8-1 and 14-3. Retardedly lost like .2 on 1-3 (ghost with Kool to see what I mean).
I noticed the 1-3 before I even read your comment about it; (since I almost always watch the 1st run before the new 0th to have more of an appreciation on the improvement(s); I am amazed that there was as much potential as your run implied.)EddyMataGallos wrote:Nice route jp, I might take a shot at it to see how fast it is later.
Secondly: tough break on 85-3... is a corner push even faster than the standard ending that macro utilizes in the first place?
Thirdly: well done on taking my 08-1. I'm actually a bit glad you out-edged me to the final ascent; since I was expecting my run to have a slight lead up until the last bit, which was sub-optimal. Keep them coming!
Thanks man, regarding 85-3, I found out its almost as fast (slightly slower) to do the corner push. The reason I'm doing it though, is that if you go as fast as I do in my run, you can't do macro's method (or you can try risking going through the bullets!) This is what I mean:ska wrote:I noticed the 1-3 before I even read your comment about it; (since I almost always watch the 1st run before the new 0th to have more of an appreciation on the improvement(s); I am amazed that there was as much potential as your run implied.)EddyMataGallos wrote:Nice route jp, I might take a shot at it to see how fast it is later.
Yeah I know, I also cried xD That happened several times (faster runs too) until I decided I wouldn't go for that shit. Before that I had gotten a 179.100 AGD -1 run by going through the bullets, so I thought it might be consistent, but its not.
EDIT: Actually there is a workaround on this that I didn't do on that demo. Can't believe I didn't do that earlier xD Waiting a little bit on the middle chamber should be enough to make the chaingun detect you and avoid that ending.
It's interesting that a smooth run trumps the reg ending... although i understand it, now that I can see how you totally manipulate the drone... Good luck... I can see you totally winning it (the episode) by 2-3+ seconds...EddyMataGallos wrote:Thanks man, regarding 85-3, I found out its almost as fast (slightly slower) to do the corner push. The reason I'm doing it though, is that if you go as fast as I do in my run, you can't do macro's method (or you can try risking going through the bullets!) This is what I mean:ska wrote:I noticed the 1-3 before I even read your comment about it; (since I almost always watch the 1st run before the new 0th to have more of an appreciation on the improvement(s); I am amazed that there was as much potential as your run implied.)EddyMataGallos wrote:Nice route jp, I might take a shot at it to see how fast it is later.
EDIT: Actually, there is a workaround on this that I didn't do on that demo. Can't believe I didn't do that earlier xD Waiting a little bit on the middle chamber should be enough to make the chaingun detect you and avoid that ending.
PS: i am currently drunk... so whatever i am saying is probably irrelevant... but hopefully i am in the ballpark..
