Yeah, that's really all I do too :( Was hoping for some great insight from our grandmaster :) I'm not going to go for the 0th there, just will need to do it again when I retry the episode soon. Its a nice run you've got anyways, I think the final jump at the end is just as important as the corner propulsion for a 0th run.EddyMataGallos wrote:Oh yeah it is for me too, unfortunately I don't have any method for it but trying to fall on the 'proper spot' of the corner (which tends to cause a lot of deaths). As you can see from my run, I didn't even get the propulsion, as I was just focusing on surviving it :P Macro might have it, as in order to pull off a 0th run you better not leave things to luck.golf wrote:Thanks Eddy, although apparently I was thinking of van instead of you. I knew there was .025 (me), then .050 (Lim), and then a .075 that I thought was yours lol. Worst part is that I got 3 agd runs after that one that were slower...
Do you have any advice on a tip/trick to more consistently survive that first fall off the corner kick? That's the most frustrating part of the run for me.
Post a Run!
Haha sorry to dissapoint. Thanks, the final jump is indeed very important as well, it does save a lot. The thing is, for a 0th, every bit is important :Pgolf wrote:Yeah, that's really all I do too :( Was hoping for some great insight from our grandmaster :) I'm not going to go for the 0th there, just will need to do it again when I retry the episode soon. Its a nice run you've got anyways, I think the final jump at the end is just as important as the corner propulsion for a 0th run.EddyMataGallos wrote:Oh yeah it is for me too, unfortunately I don't have any method for it but trying to fall on the 'proper spot' of the corner (which tends to cause a lot of deaths). As you can see from my run, I didn't even get the propulsion, as I was just focusing on surviving it :P Macro might have it, as in order to pull off a 0th run you better not leave things to luck.golf wrote:Thanks Eddy, although apparently I was thinking of van instead of you. I knew there was .025 (me), then .050 (Lim), and then a .075 that I thought was yours lol. Worst part is that I got 3 agd runs after that one that were slower...
Maybe try to land on the last bit of the 4-tile instead of the corner. About there:golf wrote:Do you have any advice on a tip/trick to more consistently survive that first fall off the corner kick? That's the most frustrating part of the run for me.
Not sure if it helps though.
Are you sure that will be enough of a slope to survive? Seems like the bottom of that curve is shallow enough that you'll still die, especially since you have to stay pretty well centered to get the last piece of gold. I really don't want to have to do the same route as the ending, since that's going to be so much slower.macrohenry wrote:Maybe try to land on the last bit of the 4-tile instead of the corner. About there:golf wrote:Do you have any advice on a tip/trick to more consistently survive that first fall off the corner kick? That's the most frustrating part of the run for me.
That could be a nice advice, maybe consider it as some approximation trick, that is, try to aim to the end of the slope; then, if you start pressing left after taking the gold, you might hit the beginning of the corner which is what you want to survive the fall, and get the propulsion. You could try that, I haven't tested it so I'm just talking.golf wrote:Are you sure that will be enough of a slope to survive? Seems like the bottom of that curve is shallow enough that you'll still die, especially since you have to stay pretty well centered to get the last piece of gold. I really don't want to have to do the same route as the ending, since that's going to be so much slower.macrohenry wrote:Maybe try to land on the last bit of the 4-tile instead of the corner. About there:golf wrote:Do you have any advice on a tip/trick to more consistently survive that first fall off the corner kick? That's the most frustrating part of the run for me.
I don't think falling on the slope is effective either, that's almost flat and would kill you, that's why I thought that maybe the trick is that you get the impression that you are going to fall there, but eventually you turn and hit the beginning of the corner, thats the only explanation.
Edit: also 26 back from xela after almost 5 years.
Hey, nice runs! I think 26 would be ideal for a triple bounceblock jump if somebody was so inclined.golf wrote:Tied 11, and took 4 with a 2 second innovation :)
Welcome to 2007!▲▪►▪▼◄▲ wrote:Oh. Okay.
Tough level. Very nice run.golf wrote:98-3 highscore. Its not a 0th, but I'm really proud of what I was able to do on such a difficult level. This makes me think, should we have a "Runs that would be 0th if it wasn't for Eddy" thread? XD
- Legacy Elite
Thanks :) Only problem is it means I erased my old 0th run that was the first to take Lim down. I did think ahead to save the demo off of infunity though, before submitting and overwriting my score. If I say so myself, that was a pretty sexy run too, with a dodge between chaingun bullets coming out of the heart of the volcano.Hendor wrote:Nice run. That Mt Doom route is sexy.
Looks like you can try your hand at the sexy route on your path back to 590+ Hendor :P
- Legacy Elite
EDIT: Look at this:
Very odd glitch in that other run of macro's. I've seen it before on a couple highscores somewhere in the 50's column, I think, but definitely not for as long as that one is. I forget what the explanation we came up with was though.
