Chimneys
Moderator: Oleary15
Octave
Postby Armaghan » 2014.04.28 (07:51)
cool eddy i didnt know that. and ya afterall im not a cheater u know it cuz u have seen my run in nreality but do u know any way how to contact cineva to tell her about my run and also tell her i dont cheat? cu z u know it but she doesnt.
EDIT: can u tell me how to wall jump faster and how to jump on sharp edges and how to jump from one way panels.
Thank you
Octave
Postby Armaghan » 2014.04.28 (08:05)
thanks eddy i didnt know that before. so now u know that im not a cheater but any idea how to contact cineva cuz i wanted to tell her as well that im not a cheater.
and eddy can u tell me:
1. how to wall jump faster
2. how to jump on edges of blocks
3. how to jump from one way panels
4. way to contact cineva
Thank you Eddy.
Postby EddyMataGallos » 2014.04.28 (12:02)
Armaghan wrote:thanks eddy i didnt know that before. so now u know that im not a cheater but any idea how to contact cineva cuz i wanted to tell her as well that im not a cheater.
Thank you Eddy.
1.- Sorry I guess this is just a matter of experience, you realize which techniques work better for walljumping in different situations. But as some general guidelines:
• Keep jump pressed as much as possible, this mantains your vertical speed. The more you release jump inbetween jumps, the more momentum you will lose and hence waste time.
• Walljump as soon as possible, that is, as soon as you reach the wall, to avoid wasting frames and achieve as much vertical speed as possible.
• After the walljump, if you have to go to the opposite side, change direction immediatly, to ensure reaching the opposite side in the least amount of frames as possible. If on the other hand you don't have to change direction, well, don't change direction at all, just keep pressed your directional arrow key without releasing.
• Regarding how close to the wall to jump, to initialize the walljumping process, it depends on what you want to do. If you want to do several walljumps, don't jump too early, or you will have lost vertical momentum by the time you reach the wall. Always play with horizontal and vertical momentum and wth time you will dominate this.
2.- I assume you are talking about the corners, those are called corner jumps or cjs in short. Now, this is pure practise, (a cj is not always possible btw), but its all about timing. When you jump towards a corner, you have a small window of frames in which you can actually hit jump again and make a jump off the corner that gives you extra power, extra speed, extra height, or a mix of them. A corner jump is not just a jump of the corner by the way, it has to have one/some of this characteristics.
Now, in regards to the resulting corner jump, there are two factors: the speed at which you approach it, and the angle at which you approach it. They will both determine the cornerjump resulting angle, and power (most of the times). Depending on what you want to achieve with the cj, you might want to do a high cj, or maybe a lower cj that takes you farther. Evidently, if you do a high cj you dont have as much horizontal momentum as doing a lower cj. Dominating the cj is something you'll do with a lot of practise, I'm not only talking about the timing of them, but about knowing exactly how to approach it depending on the resulting cj you want. After dominating this, if you want to reach a higher deal of skill, you will have to start bearing in mind the game's irregular behaviour, as a lot of times you will find situations in which some cj's don't follow this general rules I explained, they can also be mastered, but you will need more practise. Finally there are some that can't even be explained xD But these are really rare. Defintely there's still things to be learnt in regards to N's physics engine.
3.- I'm not sure what you mean here. If you mean to walljump from a oneway panel, then, unlike in tiles, you have to keep pressed the directional arrow key towards the oneway panel for the walljump to be done, which makes it a pain in the ass to chimney in oneway tunnels. This also happens in doors and thwumps, and bb's iirc.
On the other hand, if you mean jumping through the "hard side" of a horizontal oneway panel, you have to walljump as soon as the head of the ninja is about to hit the oneway. There's not a single frame, you have a wide range of frames depending on the vertical speed you are approaching it of course. And hence you have several different possible results. You can do a perfect walljump through the oneway, this is harder but you still tend to have several frames to accomplish this, and in this case its just as if the oneway panel wasnt there. It can also happen that you walljump a little late or a little early, in which cases you will still pass through the oneway, but you will lose part of your vertical speed/momentum. Of course, there is a point, either doing it too early or too late, in which the ninja won't pass through and will just crash against the oneway as intended originally.
4.- People in Nv2.0 tended, at least when I played on a regular basis, to comunicate with each other via the titles of their maps, which was partly the reason of the existance of loads of shitty maps, but thats another topic. You can create a map and write in the title what you want to tell to Cineva, and just hope for him to read it. To increase the chances, I'd personally wait until I see that he is active, either because he just published a map or because he is highscoring recent levels, and then publish your level, so the chances he sees it are much higher.
There's also the v2.0 forums, but I have no idea if Cineva is registered there. If he is, the thing is much easier to solve.
And finally, why did I write my answer so extensively? Because I was bored and I like to theoritize how things work.
Octave
Postby Armaghan » 2014.05.01 (12:04)
Thank you so much eddy it was really helpful
NUMA Profile: http://www.nmaps.net/user/thrasher26
Postby thrasher26 » 2014.05.14 (23:15)
Buenas chimeneas! :D
2nd -88.900 en http://n.infunity.com/numa.php?mapID=226905
22th? -88.950 en http://n.infunity.com/numa.php?mapID=121027 (creo que puedo mejorar al menos por un frame)
Postby EddyMataGallos » 2014.05.14 (23:58)
thrasher26 wrote:Buenas chimeneas! :D
Hey thrasher buenas chimeneas, 121027 es el mapa chimney por excelencia, por eso hay tanta gente y es dificil entrar en el Top-20 :P
Postby thrasher26 » 2014.05.15 (00:01)
Gracias Eddy.
Lo acabé de hacer :P de ultimo pero aparezco jajajaja
