Post a Run!
Postby jasdanu » 2014.04.16 (18:50)
Not an amazing run but I would like to point-out that heightless corner kick though xD
Sig: Izzy
Postby ska » 2014.04.17 (02:33)
jasdanu wrote:Not an amazing run but I would like to point-out that heightless corner kick though xD
In the future, could you please reference map ID? Nice run btw. :)
Postby jasdanu » 2014.04.17 (18:38)
Oops I thought I had the map ID in there. Lemme go look for it.
Sig: Izzy
Postby jasdanu » 2014.04.17 (20:04)
Found it. Map ID is 185592. Here is an improved demo but I'm too lazy to go for the sub-600 which is very easy to pull off.
P.S. I just found out about the Facebook Page for Metanet but I can't join since it is a closed group. Anyone willing to add me (name is Daanish Kalotia)?
Sig: Izzy
Postby golf » 2014.04.17 (21:42)
jasdanu wrote:Found it. Map ID is 185592. Here is an improved demo but I'm too lazy to go for the sub-600 which is very easy to pull off.
Taking a stab here, able to beat jas by 4 frames so far:
Am working on a crazy innov that will easily break 600 frames, probably be sub-550 and maybe sub-500? (I'm not very good at estimating how much time innovs save... but I've done 2 proof of concept runs that tell me its definitely possible just very tricky/lucky)
Postby jasdanu » 2014.04.17 (21:57)
sub-550 is easily possible. I would be around the 543 mark if I didn't over jump near the Door entrance and hit a mine
Sig: Izzy
Postby golf » 2014.04.17 (22:00)
Well then I think sub-500 is doable for you with this innov. Got a few runs completed, all within 3 frames of each other actually.
Haven't been able to get any faster than this yet, sadly. I think I may top out around 560 or so, but I haven't been getting clean finishes and its not very often I get to even try.
Edit: Even though I can't get the awesome jumps to the gold that you can, still managed to break 550!
I'll leave it to you to break the 500 frame mark :) I have faith in you!
Postby jasdanu » 2014.04.17 (22:18)
Once I get that last jump-pad down I can break 500
Sig: Izzy
Postby golf » 2014.04.17 (22:27)
jasdanu wrote:Once I get that last jump-pad down I can break 500
Yeah that's definitely the hardest part since you have to get the angle just right. If I could get that jump to the left down, I could take my own stab at it too. Also, I was kinda hoping for some sort of admission at just how crazy this is to even try but maybe its not as far out there as I thought.
Postby jasdanu » 2014.04.17 (22:32)
Dear Lord. That last jump rips away at your soul. I've had 4 perfect runs ruined by a wrong angle. I'm still going to keep at it.
Sig: Izzy
Postby ska » 2014.04.21 (13:39)
beat ed on 196672 hs. I'm sure he'll crush my run, though...
NUMA Profile: http://nmaps.net/user/LouDog004
Postby LouDog004 » 2014.04.22 (00:01)
180146 - The rockets/tiling on this map are on point.
Postby ska » 2014.04.22 (09:21)
LouDog004 wrote:180146 - The rockets/tiling on this map are on point.
taken by 5.475 seconds to be precise :P
edit: add 214505 hs
Postby Tekeur » 2014.04.27 (01:02)
I did a new 0th on 05-4, that level was really frustrating 'cause sometimes I went too fast and bumped into the last drone, and I also failed the last jump about 20 times...
It's still possible to do better since I was a bit too slow at the beginning, I only did a nice finish.
Postby TheRealOne » 2014.04.27 (16:20)
Tekeur wrote:I did a new 0th on 05-4, that level was really frustrating 'cause sometimes I went too fast and bumped into the last drone, and I also failed the last jump about 20 times...
To what 05-4 are you referring?
Postby Tekeur » 2014.04.27 (16:32)
The metanet level 05-4 on N v2 (electric avenue). Maybe I should've posted that run in this topic : http://forum.droni.es/viewtopic.php?f=2 ... start=3050 ?
Postby alsojp27ace » 2014.04.27 (16:37)
Nice run, although this topic is mainly used for v1.4 user level runs, so its worth mentioning its a v2.0 run if you post it here.
The best place to post this would be here
Postby Tekeur » 2014.04.27 (16:46)
alsojp27ace wrote: Nice run, although this topic is mainly used for v1.4 user level runs, so its worth mentioning its a v2.0 run if you post it here.
Oh ok I didn't know thanks
Postby macrohenry » 2014.05.02 (15:33)
232374 hs
Postby ska » 2014.05.02 (16:15)
macrohenry wrote:232374 hs
very nice... i figured your route would be faster...
Postby macrohenry » 2014.05.04 (17:29)
232163 sr. Definitely improvable, but these 2 cjs look pretty cool. :D
Postby Tekeur » 2014.05.09 (01:24)
I took 214505 and 180146, by taking a slightly different road at the beginning on both of the levels
Postby EddyMataGallos » 2014.05.09 (05:56)
Tekeur wrote:I took 214505 and 180146, by taking a slightly different road at the beginning on both of the levels
This was the 160000th post on the forums :P
Postby TheRealOne » 2014.05.09 (20:51)
You sure? I think it was the 170762nd post. Perhaps there have been 10.7k deleted posts?
viewtopic.php?p=170762#p170762
Postby EddyMataGallos » 2014.05.09 (22:44)
That might be the explanation
