are there ways of teleporting through walls, as I have seen many people do so and I tried it and it was glitch and didn't work well
what I meant is that I can go through the wall as if its pointing right, but can you go through at another angle, is there a map code for this?
Teleporting Through Walls
Moderator: Oleary15
- NUMA Profile: http://nmaps.net/user/SnakeekanS
- Steam: www.steamcommunity.com/id/BystanderN/
- Cowboy Magician
-I found a strange way around the problem. Assuming to 'wall teleport' going right, you just filled one tile with jumppads (not overlapping each other), to go left fill them in the same way but put two more layers of jumppads on them (so its 3 layers). and then it works Lol
thanks james I will try it, but if I cant do it, it doesn't matter. I will just wait until somebody else does it and then use their trick in one of my maps. (not copying their map but getting the one bit that I need) using (getdata dronies) if that makes sense, in order for me to make the maps. I would put in the next map that I use it in - inspired by (whatever user)
- Cowboy Magician
by layers, literally put one directly on top of the other. (and by filling a tile I meant putting 4 in a line at the top and 4 at the bottom -facing the same way)
i'll try it in a map, but not today
