Taken by a second :PMiBeM wrote:Thanks! I also took level 47-3
Okay, I thought that might be the case. cheers.MiBeM wrote:I'm not entirely sure what you mean by that. You can lure it away at the start so it's not in the way at the end like I accidentally did in my episode run but it doesn't really make a difference. Otherwise you have to be fast (or slow) enough to get past it.ska wrote:is that drone at the end a bottleneck?
it's a forum skin thing. retronet is the only one that has it.ska wrote:O_o
Weird... I don't have the "select all" text there... it just says "code" for me...
as an aside, if you're not using chrome or retronet, you won't be able to vote in polls, including the one about the bubble wrap dispenser.
Most of the runs I've just posted are only minor improvements to old ones. I was going to post them when I got 110-0, but for some reason I can't get that last frame!
Congrats - but watching the runs in demo mode shows there is a lot of room for improvement...MiBeM wrote:48-4. What an annoying level.
Took 40 :PMiBeM wrote:After taking episodes 40 and 49 today I now hold the 0th for every episode in the 40s column :)
Wow, well played. It doesn't get much better than that._danielr_ wrote:Took 40 :P
in case it wasn't clear i meant chrome the forum skin, not chrome the browserska wrote:weird.. my "new post" window is also messed up in chrome... handy to know - but i like chrome too much to cheat on my browser.
nice 27-2 macrohenry
Edit: Also got 50-4.
Good runs, MiBeM.MiBeM wrote:Took 50-1 by almost a second. This was pretty easy to get and I'm surprised no one has taken it since 2008.
Sweet runs, man. 50-1 is much cleaner than your first attempt, well done.MiBeM wrote:Took 50-1 by almost a second... Also got 50-4.
As for 50-4, check out the start by Darkshadow1416. I was going to try it, but never got round to it :P
Also messed around a bit more on 50-4 and figured out a pretty interesting route in my episode run. I think it might be a decent amount faster than the original one if executed perfectly.
One thing about this level I don't understand. Most of the time on the way back the thwumps will just zap you to death but sometimes you get through with seemingly equal speed. Any theories on what causes this variation?
This is something I also noticed when I highscored this level. It made me rage. I got the impression that your speed depends on where you land after the walljump on the E tile below the gauss.MiBeM wrote:One thing about this level I don't understand. Most of the time on the way back the thwumps will just zap you to death but sometimes you get through with seemingly equal speed. Any theories on what causes this variation?
Great run btw, you're becoming a really good speedrunner!
You just beat a six year old run... that's no small feat!MiBeM wrote:Took 57-3. Jumping off the corner right after the thwumps on the way back would be faster but I missed it.
Nice run Mibem, beating a Lim run is always impressive, however I have taken it :pMiBeM wrote:Took 57-3. Jumping off the corner right after the thwumps on the way back would be faster but I missed it.
Also took 57-1
Users browsing this forum: Majestic-12 [Bot] and 24 guests
