Postby _danielr_ » 2013.11.23 (12:21)
MiBeM wrote:Thanks! I also took level 47-3
Taken by a second :P
Postby ska » 2013.11.23 (13:50)
MiBeM wrote:
ska wrote:is that drone at the end a bottleneck?
I'm not entirely sure what you mean by that. You can lure it away at the start so it's not in the way at the end like I accidentally did in my episode run but it doesn't really make a difference. Otherwise you have to be fast (or slow) enough to get past it.
Okay, I thought that might be the case. cheers.
Postby 999_Springs » 2013.11.23 (22:50)
ska wrote:O_o
Weird... I don't have the "select all" text there... it just says "code" for me...
it's a forum skin thing. retronet is the only one that has it.
as an aside, if you're not using chrome or retronet, you won't be able to vote in polls, including the one about the bubble wrap dispenser.
Postby ska » 2013.11.24 (16:04)
weird.. my "new post" window is also messed up in chrome... handy to know - but i like chrome too much to cheat on my browser.
Postby MiBeM » 2013.11.24 (17:59)
Took 188-4 and 115-4, the latter with a bit of a sloppy jump after the bbcj, still very much improvable. After comparing my demo with danielr's several times I'm still not sure which route is faster for the end climb.
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby _danielr_ » 2013.11.24 (21:26)
Thank for the competition, MiBeM! ;)
Most of the runs I've just posted are only minor improvements to old ones. I was going to post them when I got 110-0, but for some reason I can't get that last frame!
Postby MiBeM » 2013.11.25 (16:00)
48-4. What an annoying level.
Speedruns and stuff
Postby ska » 2013.11.26 (03:56)
MiBeM wrote:48-4. What an annoying level.
Congrats - but watching the runs in demo mode shows there is a lot of room for improvement...
Postby MiBeM » 2013.11.26 (12:41)
Yeah, I compared them as well and I'm pretty sure a flawless run would be close to a second faster than mine.
Speedruns and stuff
Postby MiBeM » 2013.11.26 (15:05)
After taking episodes 40 and 49 today I now hold the 0th for every episode in the 40s column :)
Speedruns and stuff
Postby _danielr_ » 2013.11.27 (11:08)
MiBeM wrote:After taking episodes 40 and 49 today I now hold the 0th for every episode in the 40s column :)
Took 40 :P
Postby MiBeM » 2013.11.27 (16:02)
_danielr_ wrote:Took 40 :P
Wow, well played. It doesn't get much better than that.
Speedruns and stuff
Postby macrohenry » 2013.12.01 (19:36)
Took 27-2 speedrun as well. :D
Postby 999_Springs » 2013.12.01 (22:25)
ska wrote:weird.. my "new post" window is also messed up in chrome... handy to know - but i like chrome too much to cheat on my browser.
in case it wasn't clear i meant chrome the forum skin, not chrome the browser
nice 27-2 macrohenry
Postby MiBeM » 2013.12.02 (13:11)
Took 50-1 by almost a second. This was pretty easy to get and I'm surprised no one has taken it since 2008.
Edit: Also got 50-4.
Speedruns and stuff
Postby ska » 2013.12.02 (19:25)
MiBeM wrote:Took 50-1 by almost a second. This was pretty easy to get and I'm surprised no one has taken it since 2008.
Good runs, MiBeM.
Postby _danielr_ » 2013.12.03 (00:31)
MiBeM wrote:Took 50-1 by almost a second... Also got 50-4.
Sweet runs, man. 50-1 is much cleaner than your first attempt, well done.
As for 50-4, check out the start by Darkshadow1416. I was going to try it, but never got round to it :P
Postby MiBeM » 2013.12.19 (15:00)
Improved on 52-2, which was one of my earliest 0ths and the only one from before 2012 that hasn't been taken from me yet.
Also messed around a bit more on 50-4 and figured out a pretty interesting route in my episode run. I think it might be a decent amount faster than the original one if executed perfectly.
Speedruns and stuff
Postby MiBeM » 2013.12.20 (12:30)
Took 52-4 and ep 52.
Speedruns and stuff
Postby macrohenry » 2013.12.22 (17:15)
Took 78-3. That was easy after highscoring that level for days.
Postby MiBeM » 2014.01.01 (12:03)
For my first run in 2014 I took episode 54.
Speedruns and stuff
Postby MiBeM » 2014.01.21 (17:49)
Took 57-3. Jumping off the corner right after the thwumps on the way back would be faster but I missed it.
One thing about this level I don't understand. Most of the time on the way back the thwumps will just zap you to death but sometimes you get through with seemingly equal speed. Any theories on what causes this variation?
Speedruns and stuff
Postby macrohenry » 2014.01.21 (20:00)
MiBeM wrote:One thing about this level I don't understand. Most of the time on the way back the thwumps will just zap you to death but sometimes you get through with seemingly equal speed. Any theories on what causes this variation?
This is something I also noticed when I highscored this level. It made me rage. I got the impression that your speed depends on where you land after the walljump on the E tile below the gauss.
Great run btw, you're becoming a really good speedrunner!
Postby ska » 2014.01.21 (21:24)
MiBeM wrote:Took 57-3. Jumping off the corner right after the thwumps on the way back would be faster but I missed it.
You just beat a six year old run... that's no small feat!
Postby alsojp27ace » 2014.01.21 (23:48)
Nice run Mibem, beating a Lim run is always impressive, however I have taken it :p
Also took 57-1
